Old 02-18-2015, 10:37 PM   #239
GlamperGirl
I like engineering thoughts! Married to one- once and he was awesome on the "How to skin a cat".
Aerowood used 10/32 pan head screws and 10/32 bolts and installed floating self locking nutplates at all the old pop rivet locations. I didn't see where he had mentioned this bar.
So I am even more lazy because that nutplate work looks like it will take a long time
No idea how that works.
I am feeling like this could be a good idea. Do you still rivet in the nutplates? That is alot to buy. Will be going to Tacoma Screw and or Fastenal tomorrow.
Thank you!!!
thumbelinadj is offline   Reply With Quote
Old 02-18-2015, 10:46 PM   #240
2007 22' International CCD
Nut plates (at least the type I'm familiar with) have a floating nut part and a tab that retains it with two rivet holes. Typical ones are designed to have enough friction that the bolt or screw won't back out by itself. It allows the bolt or screw to have some slop for alignment but stops the nut from rotating. Typically found on airplane access panels. They would be s PITA to initially install on the top side of frame member bottom flanges, but if yo have the frame flipped over it would not be too bad.
1/4 turn fasteners would be major overkill but I used some on my van conversion for the propane fill cover I built. Yeah, engineering approach.
KE4GNK/AE
Old 02-18-2015, 10:48 PM   #241
PITA: engineering term that means "pain in the @ss"
KE4GNK/AE
Old 02-18-2015, 11:10 PM   #242
GlamperGirl
Loctite instead? Dang I don't want to be lazy but I don't want to kill myself over thinking,
Old 02-19-2015, 12:04 AM   #243
I'd suggest lock washers instead. Loctite can be a pain to remove.
KE4GNK/AE
Old 02-19-2015, 12:51 AM   #244
GlamperGirl
Lock washers it is
Old 02-19-2015, 05:05 AM   #245
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Hold on, while thinking this thru. There are a couple of advantages to just staying with rivets. The method is consistent. And the use of similar metal avoids increased corrosion that is unavoidable result of mixing metals.
Is there a need for the easier access offered by threaded fasteners?
I would think by this point dealing with rivet removal should be easy once access is needed. Fastening with rivets is cheaper, easier/quicker, lighter, and most importantly not creating the mixed metal battery that WILL accelerate corrosion.
After putting a new mast on a boat years ago, and carefully coating each fastener with lanolin to reduce corrosion. It was disappointing to see it showing up in just three years or so.
Disregard if it a done deal. Just a point to consider if not.
Cheers Richard
tevake is offline   Reply With Quote
Old 02-19-2015, 07:13 AM   #246
pbearsailor's Avatar
Port Hadlock , Washington
Me too. I'd stay with rivets. They work fine.
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 02-19-2015, 09:09 AM   #247
GlamperGirl
Not done yet. Concerns are the seal. Aluminum flat bar would help with that. Easy access at grey tank.
Im working in it Saturday and Sunday.
I still have time to mull It over.
Dena
Old 02-19-2015, 03:55 PM   #248
(-1 Rivet_
REDSLED88's Avatar
1965 20' Globetrotter
Jackson , California
I don't think it really matter
I think it looks fine, I'd go with it. I could care less personally what the bottom of this thing is going to look like. As long as it keeps dirt/debris and critters out, them I'm good. It will probably get a little wet under there, but then it can just drain back out.
I will probably be going with rivets on outside, and then just making an access location with bolts or machine screws, maybe tapped to hole on an inspection section.
I wouldn't over think it. Rivets are cheap and easy, and you know how to replace pop rivets now, so no biggie if you ever really had to get back under there. Hopefully you won't.
TIMK
Thanks in advance!
TAC CA-77
REDSLED88 is offline   Reply With Quote
Old 02-19-2015, 06:23 PM   #249
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Nut plates are easy to install except it takes another handful of specialized tools. It's the tooling that makes them east to install. I'm sure glad I didn't have to buy all of tooling at one time but acquired it all through out the years. It's all about the tools.
Old 02-19-2015, 06:39 PM   #250
Can you give us details about the tools needed? Pictures?
KE4GNK/AE
Old 02-19-2015, 06:49 PM   #251
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
Ah Kip, please tell me you have the nut plate drill that drills and countersinks the #40 holes too. I've only used it once but it was fantastic.
truckasaurus is online now   Reply With Quote
Old 02-19-2015, 07:35 PM   #252
Aerowood's Avatar
Arvada , Colorado
Yes I have a Winslow drill but it's at home and I'm in Virginia right now otherwise I'd post a picture of it
1963 Globe Trotter Winter Project Chrjbenn 1960 - 1964 Globetrotter 15 05-28-2013 05:23 AM
1968 Airstream Sovereign - Needs restoration - Great winter project! eBay Watch Airstreams on eBay 0 10-02-2011 04:30 PM
Winter project time toastie Electrical - Systems, Generators, Batteries & Solar 3 11-03-2006 04:34 AM
