Old 02-02-2015, 10:33 AM   #211
2007 22' International CCD
It's only a game. In the larger scheme of things it does not matter a bit.
Rich, who didn't bother watching game or commercials.
KE4GNK/AE
Old 02-02-2015, 11:34 AM   #212
GlamperGirl
Photos of insulation installation- please share how you installed and attached. I am planning to use the Rigid Panels. Home Depot had cut square pieces at 70% off that I picked up last month. Enough for a double layer. Many thanks.
thumbelinadj is offline   Reply With Quote
Old 02-02-2015, 12:54 PM   #213
GlamperGirl
Thank you Becky! The most detailed Insulation thread. TERRIFIED OF THE BELLY PAN http://www.airforums.com/forums/f476...n-58333-4.html
Old 02-11-2015, 11:02 PM   #214
GlamperGirl
Following the method PBearSailor used on his floor. Putting the fiberglass fabric on the floor in entry way, kitchen and bath area. Seaming with bi-directional strip and on the edges. Using epoxy to biscuit the flooring and coat tClick image for larger version
Name:	ImageUploadedByAirstream Forums1423720888.626687.jpg
ID:	232231Click image for larger version
Name:	ImageUploadedByAirstream Forums1423720913.883242.jpg
ID:	232232he whole floor. West Marine in Seattle was fabulous. One of the staffers has an airstream and is going to help out. Woot woot!
Old 02-12-2015, 05:29 PM   #215
GlamperGirl
'65 GT 20' my winter project
Pop rivets and elevator bolts for the floor and belly pan purchased today. Click image for larger version
Name:	ImageUploadedByAirstream Forums1423787349.581339.jpg
Name:	ImageUploadedByAirstream Forums1423787333.412640.jpg
Old 02-13-2015, 06:50 PM   #216
Central , Mississippi
I was in your area last week...good thing you have inside work area. I noticed it was slightly damp.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-13-2015, 10:27 PM   #217
GlamperGirl
Dang I was in Denver working last week.
Old 02-14-2015, 05:28 AM   #218
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My sons live in Denver. We visit there frequently. The Rockies are spectacular. It is much drier than your beautiful Seattle. And it doesn't have any of those seahawks you like so much.
You have a nice bag of large flange rivets for your new belly pan. Panama Red and I got sore shoulders while drilling and squeezing in these big rivets. He invented a nifty way to push the drill with his floor jack. I found I was able to wedge my elbow against the floor and push the drill with my wrist. And I did purchase an air powered riveter which saved all that squeezing the hand riveter. Tools take some of the load off this tired old body!
You may have it easier as you can carefully flip your frame upside down like the factory does.
David
Name:	1406 Belly Pan Done.jpg
Old 02-14-2015, 08:59 AM   #219
GlamperGirl
Well the rivets sound like a good idea. Until you start reading anything about what Aerowood does. He used on his belly pan install pan head screws and nut plates. Dang why do I read the forums at night.
Old 02-14-2015, 09:05 AM   #220
(-1 Rivet_
REDSLED88's Avatar
1965 20' Globetrotter
Jackson , California
Well, not all of us can do what Kip does.... I wish, but you know, do what you can.
I'll be using those rivets as well, and then just have an "inspection" section which will be screwed down using SS bolts or large machine screws, probably 1/4-28, where I either tap the frame, or make a rail to tap to, or maybe even those automotive clips to attach screws to. Probably make the inspection area around the water tanks, but everything else will be riveted. I hope I never have to go back under there.
TIMK
Thanks in advance!
TAC CA-77
REDSLED88 is offline   Reply With Quote
Old 02-14-2015, 03:32 PM   #221
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Yeah but the factory used large flange pop rivets on both my 66 and my 86. And both had galvanic corrosion between the steel frame and the aluminum rivet after many, many years. Both new belly pans will outlast me. Your rivets will work fine.
David
Old 02-14-2015, 06:47 PM   #222
GlamperGirl
Very happy to report my floor is down. Bolts on with 3m sealant and Loctite. Cleaned up my end c-channels and reusing them.
We removed the gantrys and built a simple frame and set the shell down.
Now we can flip chassis and leverage the car lift.Click image for larger version
Name:	ImageUploadedByAirstream Forums1423964773.074066.jpg
My workers are skilled and one not so skilled. I have ZERO skill when it comes to this so between the three of suits good. But I have awesome guidance from all of you.
Name:	ImageUploadedByAirstream Forums1423964570.767821.jpg
ID:	232440Click image for larger version
Name:	ImageUploadedByAirstream Forums1423964604.484318.jpg
ID:	232441Click image for larger version
Name:	ImageUploadedByAirstream Forums1423964618.453454.jpg
ID:	232442Click image for larger version
Name:	ImageUploadedByAirstream Forums1423964663.808873.jpg
ID:	232443Click image for larger version
Name:	ImageUploadedByAirstream Forums1423964675.043762.jpg
ID:	232444Click image for larger version
Name:	ImageUploadedByAirstream Forums1423964695.813718.jpg
Old 02-14-2015, 07:56 PM   #223
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
Fantastic!
OH Dena:
That looks great.
I finally enlisted my ex-bro-inlaw for past couple days to help out.
Just about to post some pics.
You have chosen the right (and same) products I've been using.
Did you decide on your insulation??
Keep the faith.
Cheers
Del
Del Gurney is offline   Reply With Quote
Old 02-14-2015, 08:35 PM   #224
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Nice progress in the positive direction there Glamper Girl!
You are pulling together some very good materials there.
Make sure that you use gloves and clean technic while using the epoxy.
It can become quite irritating if allowed on the skin. Especially with prolonged repeat exposure. Try to find a ribbed roller as well as squeegee for wetting out the cloth. The guy at the fiberglass shop should be able to set you up with the tools. Some ventilation is a good idea while wetting out large areas.
Oh , it wasn't just a game. Rather an excellent Super Bowl that was headed for a super outcome, till it didn't. Had that play worked, it would have been regarded as an out of the box master stroke .
Good you can move on into your project.
I really enjoy your writing and go for it spirit in your rebuild.
Cheers Richard
tevake is offline   Reply With Quote
1963 Globe Trotter Winter Project Chrjbenn 1960 - 1964 Globetrotter 15 05-28-2013 05:23 AM
1968 Airstream Sovereign - Needs restoration - Great winter project! eBay Watch Airstreams on eBay 0 10-02-2011 04:30 PM
Winter project time toastie Electrical - Systems, Generators, Batteries & Solar 3 11-03-2006 04:34 AM
