Old 01-18-2015, 11:05 AM   #169
indy's Avatar
1962 22' Safari
kansas city , Missouri
Images: 22
As you progress with your GT things you may want to consider, I ran water proof LED strip lights with a remote under the trailer and LED inside our cabinets and wow what a difference, call me crazy I also added LED in the medicine cabinet in the bath.
indy is offline   Reply With Quote
Old 01-18-2015, 10:34 PM   #170
GlamperGirl
'65 GT 20' my winter project
SuperBowl. Yes David. Go Seahawks. :-). Derald that was some game!
thumbelinadj is offline   Reply With Quote
Old 01-19-2015, 05:49 PM   #171
GlamperGirl
Trailer back. Welding starting. Removing steel at tongue. There was no drain at the tongue and water could seep in of course. The inside was incredibly thin at a each Y section where water pooled. Happens all time apparently on old tongues.
Old 01-19-2015, 05:50 PM   #172
GlamperGirl
Name:	ImageUploadedByAirstream Forums1421711391.516789.jpg
ID:	230748. Where water pooled and lots of pitting
Old 01-19-2015, 05:51 PM   #173
GlamperGirl
Name:	ImageUploadedByAirstream Forums1421711439.844017.jpg
ID:	230749 cut out this section and you can see all that rust inside Click image for larger version
Name:	ImageUploadedByAirstream Forums1421711473.728505.jpg
ID:	230750Click image for larger version
Name:	ImageUploadedByAirstream Forums1421711490.314218.jpg
ID:	230751Click image for larger version
Name:	ImageUploadedByAirstream Forums1421711504.815824.jpg
Old 01-19-2015, 06:01 PM   #174
2007 22' International CCD
Rest of it doesn't look too bad?
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 01-19-2015, 06:15 PM   #175
GlamperGirl
Nope not bad. I love using that plasma cutter. Dang I might like welding
Old 01-19-2015, 08:35 PM   #176
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Welding is an acquired skill. Just takes quite a bit of practice to get the metal to flow the way you want it too. But I'm sure you can learn. The frame looks much better now than before. Sand blasting saved you a bunch of time wire brushing and a better result. Fix the weak spots and you're starting the rebuild!
I hear the seahawks did in fact go and are now heading to the big bowl or something like that.
David
Old 01-19-2015, 08:40 PM   #177
Just be careful. Old-style arc welding is how I got some scars a bit close to certain tender bits.
Safety first, and make sure your welding tools are in good repair. Insulated handle slid off the stinger when I was trying to free a stuck rod. Rod got red hot, then broke loose and hit me end first in the thigh. Note: A) flesh sizzles like awful, and B) an open circuit welder will shock the heck out of you. I should have been wearing a heavy apron. Nuff said.
Modern wire-welding hardware is much easier to use, but you still gotta wear all the safety gear. ☺️
KE4GNK/AE
Old 01-19-2015, 11:13 PM   #178
1965 20' Globetrotter
Sacramento , California
Images: 13
Thumbelina, here's a link to a thread I was fortunate enough to receive today from a member about fixing up and installing windows...thought you might like to see what she did as I see you are getting ready to work on your windows too. I Am so enjoying watching your progress. It's like gazing into the looking glass for me.
http://www.airforums.com/forums/f109...-78136-30.html.
(Maybe you have already seen it)
Jayne
"It's always something!" --Roseanne Roseannadanna
jakes_mama is offline   Reply With Quote
Old 01-19-2015, 11:57 PM   #179
GlamperGirl
LED is a must do Indy!
I pulled the rest of the left over wire out today. We are bare metal.
The welder Matt managed to accomplish a few things in four hours of work today on the frame. Thank you Airstream Angel for the Millermatic 251 and the auto lift
Name:	ImageUploadedByAirstream Forums1421733325.422975.jpg
ID:	230757   Click image for larger version
Name:	ImageUploadedByAirstream Forums1421733352.421509.jpg
Name:	ImageUploadedByAirstream Forums1421733373.974143.jpg
Old 01-19-2015, 11:59 PM   #180
GlamperGirl
Name:	ImageUploadedByAirstream Forums1421733554.069610.jpg
Old 01-20-2015, 05:02 PM   #181
GlamperGirl
Picked up steel today in Everett, WA. Started to see the frame straighten out after removing part of Click image for larger version
Name:	ImageUploadedByAirstream Forums1421794915.628830.jpg
ID:	230792rusted steel on the tongue. Weakness apparently can make a frame torque. Click image for larger version
Name:	ImageUploadedByAirstream Forums1421794896.525050.jpg
Old 01-21-2015, 03:37 PM   #182
GlamperGirl
Welder thinks we use squares to replace the closed up area at frame where water collected and rusted interior of tongue Click image for larger version
Name:	ImageUploadedByAirstream Forums1421876206.024345.jpg
ID:	230855Click image for larger version
Name:	ImageUploadedByAirstream Forums1421876219.693195.jpg
ID:	230856Click image for larger version
Name:	ImageUploadedByAirstream Forums1421876232.860698.jpg
ID:	230857Click image for larger version
Name:	ImageUploadedByAirstream Forums1421876250.413730.jpg
Your thoughts
1963 Globe Trotter Winter Project Chrjbenn 1960 - 1964 Globetrotter 15 05-28-2013 06:23 AM
1968 Airstream Sovereign - Needs restoration - Great winter project! eBay Watch Airstreams on eBay 0 10-02-2011 05:30 PM
Winter project time toastie Electrical - Systems, Generators, Batteries & Solar 3 11-03-2006 05:34 AM
