Old 12-30-2014, 03:13 PM   #127
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Oops, that's the front hold down plate that is welded to the frame, the front skin and C channel rivets it it. That is a fairly easy skin to replace
Old 12-30-2014, 03:26 PM   #128
GlamperGirl
1965 20' Globetrotter
Seattle , 98133
For sure
http://on.fb.me/1rK58cN link to Glamper Girl on FB
thumbelinadj is offline   Reply With Quote
Old 12-30-2014, 04:45 PM   #129
GlamperGirl
Seattle , 98133
The exposed floor in the state post shell lift off
Name:   ImageUploadedByAirstream Forums1419983049.660297.jpg
Name:   ImageUploadedByAirstream Forums1419983066.578947.jpg
Name:   ImageUploadedByAirstream Forums1419983077.250695.jpg
Name:   ImageUploadedByAirstream Forums1419983089.315572.jpg
Name:   ImageUploadedByAirstream Forums1419983101.283756.jpg
Name:   ImageUploadedByAirstream Forums1419983114.218700.jpg
Name:   ImageUploadedByAirstream Forums1419983127.223645.jpg
Old 12-30-2014, 04:46 PM   #130
GlamperGirl
Seattle , 98133
Name:   ImageUploadedByAirstream Forums1419983146.156282.jpg
Name:   ImageUploadedByAirstream Forums1419983156.157638.jpg
Name:   ImageUploadedByAirstream Forums1419983166.409267.jpg
Name:   ImageUploadedByAirstream Forums1419983178.177396.jpg
. Some lovely drawings from the build I guess on the wheel well.
Name:   ImageUploadedByAirstream Forums1419983207.514460.jpg
Old 12-30-2014, 04:52 PM   #131
Sacramento , California
Images: 13
That's probably what mine looks like underneath too...I shudder to think.
"It's always something!" --Roseanne Roseannadanna
jakes_mama is offline   Reply With Quote
Old 12-30-2014, 05:44 PM   #132
pbearsailor's Avatar
Port Hadlock , Washington
Congrats Dena! That's a big step forward.
Cheers,
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 12-30-2014, 08:01 PM   #133
GlamperGirl
Seattle , 98133
I feel so happy to have crossed the chasm.
Old 12-31-2014, 07:53 AM   #134
dbj216's Avatar
1986 34' Limited
1966 24' Tradewind
Conifer , Colorado
Happy New Year! You earned the "shell off" merit badge! Yea.. Clap Clap Clap! Not very many of us vintage Airstream enthusiasts get that far. I have not.
Now you can address the subfloor and frame and rebuild them as necessary. You're going to be a busy lady in 2015 with lots of time spent in the garage. Crazy me would enjoy all those challenges getting your Globetrotter back on the road again.
It's so cool Aerowood is following your thread. He is an expert aluminum craftsman.
David
Old 12-31-2014, 10:18 AM   #135
GlamperGirl
Seattle , 98133
Thank you thank you! Joy is short lived. I had nightmares last night I made a mistake in the template and couldn't reconstruct the floor and the shell would not go back on.
Kind of real due to the fact so much c channel is broken and needs replacement.
So you know what I am doing today......Reading every thread on the best method for template and worrying about the c channel.
Old 12-31-2014, 11:33 AM   #136
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
C-channel
After thinking how to replace the two curved c-channels and how "frail"
they looked compared to the load (they hold the shell to the plywood floor
which in turn is elevator bolted to the chassis). I thought "screw it" and I bought some quality lumber from Lowes (it was the exact dimension).
For the curved end pcs. I ran some of the lumber through the band saw
to 1/4 width strips and then laminated them together and to the ply-wood floor using the curved C-channel as a template.
I intend to through bolt every 3rd-4th fastener and wood screw the rest.
They will be bedded from here to next year to prevent rot and soaked in
West System epoxy.
I double coated all the edges of the plywood with epoxy as well and the rest
will be sealed with teak oil sealant (under) and flooring under foot...also glued
down.
You can find elevator bolts at Fastenall or similar place. I'll need to buy some longer ones now as the wood is way thicker than the C-Channel to bolt to the Out riggers
Del Gurney is offline   Reply With Quote
Old 12-31-2014, 05:31 PM   #137
GlamperGirl
Seattle , 98133
Del, If you make it down south towards Everett sometime, perhaps arrange a stop at the shop to see my airstream. It's near Mill Creek, WA
Old 12-31-2014, 06:15 PM   #138
dbj216's Avatar
1986 34' Limited
1966 24' Tradewind
Conifer , Colorado
Franks Trailer Works blog has some good pointers for making luan templates for new subfloors. I believe I recall they were made before the shell was lifted.
It looks like from your photographs you have enough subfloor left to make a template for the four corners. Maybe that will work.
It's just another challenge. You've conquered several already.
David
PS Hope your hired man smells better! You are probably working him too hard!
Old 12-31-2014, 06:55 PM   #139
GlamperGirl
Seattle , 98133
Thanks all, I missed understanding the step of making the template before shell off. dang i am scouring the Frank blog stressed. It had appeared to me I had enough existing floor on and understood radius on how to complete in case the rear end bathroom was going to dissolve on me. Pics of my floor post lift off here.
https://plus.google.com/photos/11042...30001717153809
Old 01-01-2015, 08:35 AM   #140
dbj216's Avatar
1986 34' Limited
1966 24' Tradewind
Conifer , Colorado
Well, we know the shell fit the subfloor and C channel before you lifted the shell off. So grab some luan and go trace the outline of the subfloor corners. Cut on the marked lines and that should get you close.
I envision the shell as a "paper bag" and trying to get it to position perfectly on the new subfloor will take some messing around. I used my belt sander on the edges of my new subfloor until I had a good fit. The photo shows my template!
There are lots of vintage Airstreamers that have created ways to make the new subfloor and C channel fit the old shell. I'm sure you will get some good advice here in your thread. Stay tuned.
And don't dissolve like a big Alka Seltzer! You're just building a new old Airstream. It can be done, and you will do it.
David
Name:	1312 Floor Bath Out.jpg
1963 Globe Trotter Winter Project Chrjbenn 1960 - 1964 Globetrotter 15 05-28-2013 05:23 AM
1968 Airstream Sovereign - Needs restoration - Great winter project! eBay Watch Airstreams on eBay 0 10-02-2011 04:30 PM
Winter project time toastie Electrical - Systems, Generators, Batteries & Solar 3 11-03-2006 04:34 AM
