Hey!
this is hard work and LOOOOOOOOOOOOONG!
so far:
Chassis is cleaned and painted.
New floor is in
new bearings
new brakes, including the back plate
new wiring for brakes
walls are sealed from inside
arond the windows is sealed
the cover for the front window is fixed
the seams in the shell are sealed
the door frame is welded and fixed
the insuletion is getting installed. Im putting R12 so is a bit thicker than original, a bit more dificult to install but is working ok
the rims are painted in black low gloss and the baby moon hupcaps are cleaned and reinstalled
my plan is:
- finishing installing walls and insulation (leave ceiling for later becaus de AC unit has to come up first.
- install A/C
- install ceiling. (at this point all the walls inside are finished)
- paint inside with some texturized paint because flat paint may look bad (I guess)
and ...
I don't know yet what I'm gonna do with the interiors after avrething is painted, any sugestions?
also any ideas if I should put the floor before the furniture or just put floor in the areas that can be seen??
also any ideas about what kind of floor is light and look good?
I'm kind of hesitant in linolium.
here are some pictures:
http://pg.photos.yahoo.com/ph/carlos...vedo/my_photos
to put sealant in between the aluminum from outside I put 2 strips of painters maskin tape and put the sealant in the middle. this will keep the sealant just in the crack and not outside. is recommended that once you put the sealant, remove the tape asap otherwise with the sun and the heat it will leave glue when is removed andthe sealant wont look perfect because is stronger than the tape. so remove the tape while the sealant is fresh.
cheers!!!
Carlos
