Old 09-16-2007, 06:40 AM   #1
Jonz's Avatar
1969 21' Globetrotter
Sutton , Surrey
1969 #134 globe trotter
full restoration in progress, but modern interior going in. Belmont's photos - powered by SmugMug for all the photos to date
Jonz is offline   Reply With Quote
Old 09-16-2007, 06:57 AM   #2
Based on your photo's, the axle has seen better days, years ago.
When the axle is good, you will see 2 inches or so, of the tire, above the wheel.
In your case, it looks like about 2 inches of the top of the wheel cannot be seen.
Further, check the position of the torsion arm. When the trailer is loaded for travel, a horizontal position, as the arm goes rearward, is maximum.
It appears from your photo's that the torsion arm, as it goes rearward, is considerably rising.
That means when the trailer is in motion, it will bottom out. When the trailer bottoms out, many damages will occur, starting usually with tearing up furniture, shearing rivets, severe frame damage, fatigue cracks in the shell, ruining the entrance door hinge, etc.
A good axle's torsion arm, as it goes rearward, with the trailer loaded, will have a downward angle of about 10 to 15 degrees.
The only fix, is replacement. A replacement axle, can have it's starting angle increased, that will give the trailer even greater ground clearance than when new.
The following article, will explain in more detail.
http://www.inlandrv.com/articles/dur...xle-92001.html
Old 09-16-2007, 07:00 AM   #3
Maybricks's Avatar
1962 19' Globetrotter
1960 22' Safari
Stamford , Rutland UK
Send a message via Yahoo to Maybricks
Hi Welcome to the Airstream forums good to see another Brit on here! Looks like your doing some serious restoration
www.vintage-americana.co.uk
+44 (0)7984 662 532
Maybricks is offline   Reply With Quote
19?? Globe Trotter OldGlobe 1965 - 1969 Globetrotter 16 07-30-2012 05:50 PM
Globe Trotter not in 1969 Manual - Why? gypsymoth 1965 - 1969 Globetrotter 8 08-15-2007 07:32 PM
64 Globe Trotter Power mbx2SoCal Electrical - Systems, Generators, Batteries & Solar 1 04-22-2007 06:29 PM
64 globe trotter mbx2SoCal Sinks, Showers & Toilets 3 04-21-2007 10:59 PM
