Old 10-19-2002, 07:47 PM   #1
buckmaster's Avatar
1965 20' Globetrotter
1970 31' Sovereign
1972 25' Tradewind
Newport , Oregon
1965 Main Door
Well the first project I under took was to fix a broken door frame. this was the internal door frame of the main door. It was broken where the door handle goes and above and below the hinge. I used some square aluminum tubing to reenforce the break then epoxied and screwed it all together, Now the door will close but the Main hinge is worn I'm not sure how I will deal with this replace it? or work up some shims? any suggestions would be helpful.
buckmaster is offline   Reply With Quote
Exterior/Main Door Doesn't fit frame Angary Windows, Doors, Locks & Vents 1 11-13-2011 06:12 PM
Screen door stuck in closed position ESCAPE POD Doors & Locks 4 10-31-2011 03:30 PM
Door handle for outside of screen door RTurnConn Exterior Storage Compartments & Access Doors 1 08-27-2011 09:16 PM
Door sprung AND frame broken Stella Doors & Locks 12 07-06-2011 05:04 PM
RM 2410 and 2510 Freezer Door Widths pbearsailor Refrigerators 4 01-07-2011 07:16 PM
