Old 03-28-2009, 06:25 PM   #29
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
A copper penny next to a battery terminal will help keep corrosion off the terminals--the corrosion will get on the pennies first.
For corrosion on battery terminals, pour some diet soda on the terminals, the soda water will dissolve the corrosion.
Another way to treat corrosion is to put a dab of vaseline on the terminals.
Old 03-29-2009, 07:57 AM   #30
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
The guy I take care of is type two diabetic and can't have flour products like bread. I kept wondering if the leg cramps were tied to diabetes...cause he sure does yelp a lot about his legs hurting after standing...but I have heard that the extremities are damaged on the body if diabetic...
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 03-29-2009, 08:21 AM   #31
1970 27' Overlander
Here's another odd thing...your height is the same as you are measured (arms extended outward left and right) from fingertip to finger tip.
Old 03-29-2009, 08:50 AM   #32
Well Preserved
1993 21' Sovereign
Originally Posted by 76sovereign View Post
A word of caution: DON'T PUT IT AROUND YOUR NOSE HOLE OPENINGS UNLESS YOU WANT TO REMOVE NOSE HAIR!.....OUCH!
TMI...
Old 03-29-2009, 09:56 PM   #33
1970 27' Overlander
I was curious about the 'dry time'.....
Old 03-29-2009, 11:11 PM   #34
SaabLover's Avatar
Almost Always Sunny Sarasota , Florida
Images: 12
Removing red wine from carpet
One of the best ways to deal with red wine spillage is with a white wine chaser. Thats right. If you spilled your red wine, pour a glass of white over the stain. The white wine actually neutralizes the red wine and the stain disappears magically before your eyes.
1999 Chevy Suburban 7.4LT "Tugger" Last of the big boys! Still going strong. 1992 Saab 900s Convertible 60K miles Not my TV
Almost always sunny here unless there is a hurricane bearing down on you. And then it's time to hook up the burb and roll. So far I've been very lucky.
SaabLover is offline   Reply With Quote
Old 03-30-2009, 07:09 AM   #35
2010 25' FB Flying Cloud
Davenport , Iowa
Peppermint is good for upset stomach and sinus drainage. I use the candy while driving, but once off the road, a double over ice and sip it. Just let a small amount run slowly down the back of you throat. Keep one at dedside for during the night. I learned this from an "old" pharmacist. He bought gallon jugs by the case.
Airtandem is offline   Reply With Quote
Old 03-30-2009, 08:23 AM   #36
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Stripped out wood screw...
Dip the tapered end of some wooden toothpics in carpenters glue, fill the hole tightly, let dry, cut off excess and screw away.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 03-30-2009, 11:53 AM   #37
1972 Travelux Princess 25
Cobourg , Ontario
There was a piece in the paper this morning. It said diabetics can reduce their need for insulin with just 30 seconds of exercise, 5 or 6 times per day. It would probably help the cramps too.
Leg cramps can also be connected to low calcium and other causes. I would definitely consult a naturopath or nutritionist about overall health care, diet, and supplements.
Diabetes in most cases can be controlled with diet and lifestyle improvements. Before insulin was discovered many diabetics lived long healthy lives purely by watching their diets. A Dr. Kneip in Germany was the expert in the 19th century and many of his discoveries still apply.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 03-30-2009, 01:08 PM   #38
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Warm, not hot, olive oil put in the ear with an eye dropper will relieve an earache long enough for the doctor's office to open in the morning. Use a dab of cotton to keep the oil from running back out. Worked when my mom used to use it on me.
Old 03-30-2009, 01:14 PM   #39
HankandLois's Avatar
2007 27' International CCD FB
Everett , Washington
Originally Posted by Silverhobby View Post
Vick's Salve rubbed on the bottoms of your feet, covered by socks overnight will stop a cough.
I hear it's also helps stave away athlete's foot.
My favorite? Baking soda water as an anatacid/stomach soother (as long as you can tolerate the higher sodium)
For hiccups, eat a spoonful/packet of sugar. The sugar relaxes your muscles instantly. Yes, it's kinda gross, but it works!
Air # 20467
WBCCI #4018
Just call us Jean & Bill :-)
HankandLois is offline   Reply With Quote
Old 03-30-2009, 01:28 PM   #40
1970 27' Overlander
Yes, for those who have the fungus under their toenail ...I had a girlfrind that applied Vicks VAPO Rub to all around that area of the toenail and covered it with a balloon like thing (probably not that!) and it cured it withen two weeks.
Old 03-30-2009, 11:32 PM   #41
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Same thing, but different.
Hi, depending on the size of the wood screw, drill out a little bit larger, add wood glue to a Golf "T", tap Golf "T" in place with hammer, after the glue dries, cut flush with wood surface, and pre-drill before reinstalling screw.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-30-2009, 11:52 PM   #42
Thumbs up
You Duffer you, I'll remember that
"Honey what took you so long?, You were only going to play nine holes this morning."
"Well Fred collapsed on the second hole and from then on it was hit the ball drag Fred, hit the ball drag Fred.
PFC
"Tahawus"
RLC
John Prine
What's your favorite, famous (or not) saying? Fyrzowt Fun & Games 1813 Today 09:52 AM
favorite wax lisa.bivens Cleaning, Stripping & Polishing 11 04-18-2008 04:56 AM
Favorite AS Decoration rickandsandi Off Topic Forum 10 02-09-2007 05:21 AM
What's your favorite campground? streamer23 Off Topic Forum 8 07-30-2006 02:10 PM
A Few Favorite Things j54mark General Repair Forum 0 04-13-2004 02:21 PM
