Old 02-05-2007, 05:49 PM   #1
starflyte1's Avatar
2007 25' Safari FB SE
Lady Lake , Florida
Windows?
Are all windows the same quality in all models? We have an Excella Classic now and love the windows. Wondered if the Safari has the same windows?
Pat
starflyte1 is offline   Reply With Quote
Old 02-05-2007, 05:55 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Pat
The newer Safari windows don't open like the Classics. Only a small portion opens at the bottome of the window assembly.
Old 02-05-2007, 06:00 PM   #3
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
The safari windows are less than decent....
I have a 05 Safari, and the windows are less than decent. They are drafty, have no ventilation, not user friendly to open (little knob that turns 50times) and do not look to the overall quality of an Airstream. Stand next to one (classic, international, safari SE) and compare to intro level Safari.
Worth the Bank $$ to upgrade.
SafariSS is offline   Reply With Quote
Old 02-05-2007, 06:09 PM   #4
lynn's Avatar
You can get Classic style windows in a Safari by ordering the SE Package.
lynn is offline   Reply With Quote
Old 02-05-2007, 06:53 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
The International CCD line has the same windows too. I had those on my '74 Argosy and jumped at the chance to get them on my Safari Special Edition. The air circulation is most welcome!
5 meter Langford Nahanni
Old 02-05-2007, 06:57 PM   #6
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
Curious... is the opening the same - such that you could change out the 1/3 opening safari for the full opening classic?
For those that are not happy perhaps they could change out just a couple of the window to get more air?
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 02-05-2007, 07:11 PM   #7
SafariSS's Avatar
2005 30' Safari
Yeah..
The openings are close to the same, the radius's are different. It has been done. Check Rich Luhrs website to see what David Tidmore did to the Safari 30.
Expensive retrofit.
Old 02-05-2007, 07:21 PM   #8
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I agree. It's a pricey retrofit. I am floored that the factory can't make it at least an option. The standard Safari windows blow....literally in wind conditions. All that has been said is true. One of the biggest shortcomings of the Safari line (non SE) is the windows...they are cheap, don't seal well, are not as user friendly as the CCD/Classic windows and provide very little airflow in the coach, unless you have one, or better yet, two fantastic vents. Most (read not all) the window dimentions are the same, and since they are already making the CCD and SE versions, I just don't see how the factory can't make the windows optional.....it's not a major production line change than what is already being offered in the bulk of the Bambi/Safari floorplans as SE and CCD models.
The only problem IMHO going with the SE edition (or CCD) is that you get the interior aluminum skins. I personally think they look neat, but I like the traditional interiors. Besides, to pay $5k for the windows and the inside exposed skins, when all most want is the window, seems a bit steep.
Old 02-05-2007, 07:56 PM   #9
Buckhorn , Ontario
Images: 59
Expensive retrofit.
Hey that is pretty cool - so just a bit of extra aluminum in the corners where you would not see it behind the frame flange and presto you can change them out.
We have changed out the two corner windows on the 69 - time consuming but really doable for the DIY'er with patience.
I asked this because I do like the Safaris and If I ever found one I might buy it - but the windows are just such a drag. But we have the 99 Excella donor trailer here that we can snafu the windows out of if need be.
Hubby just woke up and said what don't you want the vintage ones anymore???
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
Windows Inland RV Center, In Windows & Screens 1 04-20-2004 06:14 AM
Caravel windows susan martin 1966-68 Caravel 1 08-21-2002 08:43 AM
Motorhome Windows thenewkid64 Airstream Motorhome Forums 10 03-19-2002 12:09 PM
