10-10-2015, 11:28 AM
Coolman
Roseburg
, Oregon
Why should I buy an Airstream?
My wife and I presently have a Newmar class A pusher that we are going to sell for personal reasons. Unfortunately we have been spoiled by the quality and dependability of our coach. We have been looking for a travel trailer and have been consistently disappointed in the quality. I have known for years the superior handling of an Airstream but after reading the Forum for nearly a year I'm concerned about quality issues with Airstream as well. I'm in the heat & ac business so thermal performance is important to me, also condensation reports and the damage I know it causes. I also know proper ventilation solves the moisture problem. Other comments like " not good when it's hot & not good when it's cold, concern me. I'm less concerned with appliances etc. they can be fixed. When our camper is parked it will be in a climate controlled environment so storage is not a question and I'm fairly good with basic repairs and maintenance.
I do like the family feel of Airstream owners but the nearly twice the price concerns me, everything has a proper value. Please help me to understand why the price is soo much higher, is the value truly there.
Thank you in advance for taking the time to respond. Tom
10-10-2015, 11:48 AM
Biloxi
, Mississippi
Tom, you either feel it or you don't. Airstream ownership is as much from the heart as the pocket book.
MICHAEL
10-10-2015, 12:38 PM
2012 25' Flying Cloud
Battle Lake
The quality of construction is inconsistent in the details, and the electrical, plumbing, HVAC is mediocre, thermal performance of the shell construction is only good in moderate temperatures. The towing is easy and stable, as good as it gets.
Many who want a high quality Airstream buy it, then go through fixing the details and putting on better tires/wheels, electrical power supply and fixtures, stronger solar, sometimes better plumbing fixtures, better mattress and sometimes seating, ventilation fans and covers and skylight, curtains and whatever suits their fancy. It's easy to add $10,000 to the cost and some solar/electrical systems can cost that on their own.
So figure the initial cost of a high quality Airstream will only begin with the purchase price. But those who have done the quality are usually very pleased with their Airstream, and it helps if you plan on it being your last RV. It's still a very basic travel trailer with limited storage and living space. Airstreams are all tiny compared to other choices.
They will need ongoing and regular preventive maintenance for corrosion prevention or repair, and leak inspections and resealing. With care it will last a lifetime and look like a new one all the way.
Buy it for iconic style and towability; modify and maintain it for satisfaction and longitivity. We bought ours new, initial quality was near perfect, we spent considerable money modifying it to suit us and our travel, and do regular inspections and maintenance. After four years our Airstream is nice as new and has been throughout the country several times, we couldn't be happier.
Doug and Cheryl
10-10-2015, 12:54 PM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
What dkottum said times two.
In my case, I bought a gently used, almost new unit for quite the discount due to the prior owner's (PO) circumstances. Spending the dollars and time customizing it to our liking over the years is as much fun for me as using it. Other family members have owned SOBs and none of them lasted long without intensive work and, even then, they are all long gone... traded for Aluminum :eyes:
You will soon learn a trailer is substantially less expensive to maintain and operate than a Class A if you choose to join the aluminum community. FYI, the presence of complains and discussion about quality issues may not represent the true distribution of Airstream issues as those without problems/concerns have nothing but good times to write about.
10-10-2015, 02:09 PM
2008 25' Classic
Full Time
Sounds like you should keep the Newmar. Airstreams are POS.
Seriously, like all RVs Airstreams have their pros and cons.
If thermal efficiency is your main concern then look for something else. We've camped in 104F Texas heat in full sun but the inside was comfortable for us. We don't require the AC to keep the interior cold enough to store meat and ours doesn't have ducted air. The coldest was 18F and a small ceramic heater and the propane furnace kept us comfortable that night. The quality on our Classic is much better than any SOB trailer we've seen. I do worry about hail. I have to admit Airstream doesn't have some of the convenience items that SOBs have. We didn't want slides so it restricted our search which led us to looking for a preowned Airstream. Our 25fb is not too big and not too small. If you want a condo on wheels then Airstream may not fit your needs.
Good luck in your search.
Kelvin
10-10-2015, 02:50 PM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Honestly, those happiest with Airstream travel trailers tend to be those who failed to talk themselves out of one (e.g. they fell in love with it, or some aspect of it which could not be found anywhere else.).
We are one of those people.
We looked at lots of other options but found ourselves coming back to Airstream over and over again. Then we sat in one for an hour or two talking over our options. That experience convinced us it was the RV for us.
As you and others have noted - Airstreams, like most RV's, aren't perfect. But in this case, it was perfect for us.
You may find the best value in picking up a gently used Airstream that feels like the right size with the right options. If it turns out not to be right for you, it should be easy unload the trailer for relatively close to what you paid for it so you can move on to something else.
Best of luck in your search!
10-10-2015, 03:00 PM
1972 31' Sovereign
felton
good question Tom! i'm very new to airsteaming , in fact have yet to even take mine on the road yet. I bought mine simply because i find the big white plastic fiberglass trailers just plain ugly. They may cost way less and have more storage but for me it's more about "style" and really enjoying traveling in an iconic travel trailer. Some prefer staying in big box type chain hotels, I'd rather find an independent "quirky" motel with character in the rooms etc. some people love eating at chain restaurants, I like finding independent places with owner / chef cooking. It's just my personal distaste for anything too dull and generic. I could go on & on ... I suspect there's something in the psyche of airstream owners. It's like buying a Toyota v a BMW, both get you from A to B, one more reliably with lower costs , the other will take you on one hell of a ride and make life far more pleasurable!
10-10-2015, 03:52 PM
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
You might be happier spending $5k on a 70's Airstream at the end of it's life and paying one of the Professional Rebuilder / Customizers the cost of a new one and it'll probably be twice the quality and exactly what you want.
Having said that, if, for you, "bottom line" is the bottom line then there may not be an Airstream, or any towable trailer that you'll be happy with.
Good Luck.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
10-10-2015, 04:53 PM
2016 25' Flying Cloud
Venice
Having owned a 40ft pusher (2006) & going to a travel trailer after is a major change of direction. We traveled the US in the MH, sold it but still wanted to stay in the game, so to speak. Our AS is small, extremely comfortable, easy to tow & most of all it's a quality built RV, perfect no, but very good. We made the trailer MISTAKE before buying our AS by purchasing a cheaper low quality glitzy brand & quickly sold it. My 2 cents.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
10-10-2015, 05:30 PM
2012 28' International
Prince Edward County
, Ontario
I agree with dkottum's comment. We've towed around North America for the past two years and have been very pleased. There have been several relatively minor issues but when under warranty, they were dealt with right away by several dealers. Now out of warranty, we've only had one problem (loosening door hinge) that was a relatively inexpensive fix. What drove us to the brand was a combination of modern design and light/brightness inside. All other RV's we've looked at were dark caves inside in comparison.
10-10-2015, 05:42 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
If you can find a trailer you like better for half price buy it. No need to waste money on a Airstream.
10-10-2015, 07:22 PM
2007 25' Safari FB SE
2000 30' Excella
1999 30' Excella 1000
Low Country
, South Carolina
Airsteam is an American Icon.. even a "cult" like Corvette or Harley owners.
If it is for you, you don't have to ask, it is for those that appreciate it, no matter what breaks, leaks or needs maintenance or repairs ... we love Airstreams.
To this day we get asked questions about where ever we go..No white box ever did. My cousin has a newer white box looks old compared to ours, people think it is new.
We have had 4, loved them all. Made many changes to all our Airstreams. We would have no other brand as no other brand is comparable.
Buy what you will be happy with.
StreamNTyme
10-10-2015, 07:56 PM
1969 25' Tradewind
Shasta Lake
The beauty of the Airstream is it's rounded ceiling and corners .
They seem larger inside then a same size box trailer because the eye doesn't see a defined intersection at the ceiling/wall/corner.
They have less storage space. This means you will only pack what you really need and save the weight of hauling stuff you thought you mite need but haven't touched in 3 years.
They are aerodynamic . Way less effect from the wind.
The biggest fear is hail. Find cover under a bridge or service station.
As for storage you've got that covered .
Where and when and what seasons do you plan to travel ? If you plan to snowbird your golden.
If you stay in the NW spring summer and fall no problem.
If you head to the desert in summer expect to be warm .
If you head north in winter ... brrrrr .
If you head to the other side of the rockies in spring and summer ... Look out for the weather.
Have good insurance on the trailer that covers hail.
This may be a plus or a minus depending on you ... You will be in an ICON and the center of attention wherever you go. Be prepared for questions and stories.
If you go Airstream . Have lots of FUN with it and the people you will meet along the way.
10-10-2015, 08:01 PM
1969 29' Ambassador
brooksville
As mentioned above. You can find a older AS, find the year style you like, and then take it to a professional restorer. Colin Hyde is up in NY he can give you ideas on what a shell off for restore will cost. Then you can have it built to your specs, you will know what your getting, and it will last another 60 years. I've seen posts where people built their replacement frames out of Stainless steel.
Either way an AS new or restored will last 3x as long as most white boxes.
The reason AS last so much longer than any white box is the design. Aluminum outer walls, Aluminum framing, aluminum inner walls.
Up side to a travel trailer is you get to your camping spot, DC the TV and can head out.
Up side motor home passengers can get up and move around.
On a side note check out Livin Light they build all aluminum white box style trailers.
10-10-2015, 08:32 PM
1969 25' Tradewind
Shasta Lake
BTW Just over the hill in Bend is a custom trailer restorer. If you went with an older unit and had it remodeled to you liking this may be an alternative but it takes time, lots of time and money.
On the other hand if your handy this could be a great project for 3 to 5 years for a complete rebuild. Providing the starting unit has no major floor problems, but expect some floor damage.
I just spent the last 2 years rebuilding our 25' 1969 Airstream Tradewind from the axles up to the a/c. I replaced all the systems and replaced the last 4' of the floor and installed underlayment and Marmolium flooring added a Casita wet bathroom, refinished most of the original cabinets and used the partitions as templets for new partitions . Added a second 30 amp inlet and circuit for the washer and dryer, added a/c, remote powered vents, digital antenna and all new appliances.
In any case enjoy the journey.
10-10-2015, 08:46 PM
2016 30' International
2015 25' FB Flying Cloud
Paso Robles
You're hooked the minute you walk in
I think you either LOVE the Airstream or you don't. The first time I stepped foot in one I got a big smile on my face. It just felt so right 😀.
After checking out other brand options I knew I'd be an Airstream owner forever. The other trailers seem cheap and gaudy compared with the Airstreams clean and modern feel.
Any issues we've encountered have not changed our thinking. Airstreams are for us 😀.
10-10-2015, 08:57 PM
2005 30' Classic
Burlington
, Ontario
I think I'd rather have the Newmar - if I could halfway justify the expense! I keep thinking about a class A motorhome to finish up our RV career, but as we only travel maybe 7 - 8 weeks a year it just does not seem to make sense even though we could certainly buy one without breaking the bank.
Meanwhile we do like our Airstream. Never found a problem with heating / cooling, but then we tend not to use it in extremes - we bought it mainly to head south in winter.
Expensive for what they are? yes. I don't think there is a linear relationship between
dollars and quality!
The nature of the beast is appealing though, and we could not find another trailer that appealed to us as much.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
10-10-2015, 09:09 PM
Venice
X2! Icon it is & like that Corvette mentioned ownership in itself is worth the price!
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
10-10-2015, 10:29 PM
Durango
The perceived value of an AS is over rated. I've owned a number of RV's and boats over the past 50 years and when it comes to the perceived value of an AS on a a scale of 1 to 10 I would put it at 6 or 7. If you have the time and money, have an AS restored/built to your specs.
If you don't go first class, your heirs will!
10-10-2015, 10:52 PM
Vacaville
After owning our 10 yr old Airstream for two years and spending 3 months in it, I'd say it's better than most, but not nearly as good as the legend might lead you to believe (much like Maytag or Jeep).
We just bought a 30 yr old Avion. It's better built and my initial impression is that it is much more robust and will outlast an AS of any era. It feels better. The layout and function is better. The components are as good or better. The cabinets are better than those in most houses. The overall build quality is better. They aren't perfect, but what is? Unfortunately, Fleetwood killed the brand.
Buy an AS if it will do for you what you want it to do. They do tow nice. We are keeping our AS, it's got its purpose.
If you have the time, do as others have suggested, buy an old one that's in decent shape and have it restored to what you like. That'll be a future project for us.
