Old 02-13-2010, 08:13 AM   #1
HowieE's Avatar
Princeton , New Jersey
Images: 12
Where is Wally
For the last 2 days I have only been able to get to Save Wally about 10% of the time. I get an error message.
Is this just overload of people reading Leo's legal notice from WBCCI or a problem on my end?
2004 Excursion 4x4
Old 02-13-2010, 08:23 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I haven't had any problems at all, checking several times a day.
In 41 degree Orlando
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 02-13-2010, 08:44 AM   #3
HowieE's Avatar
Images: 12
I am getting a 404 Error message on Fire Fox and you do not have permission to access this site on Internet Exp.
2004 Excursion 4x4
Old 02-13-2010, 09:05 AM   #4
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Work for me!!
All those links work perfect for me.. Thanks for all Save Wally does!!
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 02-13-2010, 09:06 AM   #5
HowieE's Avatar
Images: 12
The guide link works the other two still give an error message. If links do not work it is not my bookmarks.
2004 Excursion 4x4
Old 02-13-2010, 09:07 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
You are entering savewally.org?
5 meter Langford Nahanni
Old 02-13-2010, 09:21 AM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Howiee, I sometimes get messages like those (404) when my connection is slower than normal. I have a broadband card and sometimes the speed is so slow that sites time out while trying to connect.
If the slowness persists, then I will go through the "activation" process.
Pat
pmclemore is offline   Reply With Quote
Old 02-13-2010, 10:14 AM   #8
HowieE's Avatar
Images: 12
Pat
Message is almost instant so I don't think it is a speed issue.
Like I say I got through about 10% of tries yesterday but zero today.
What is the activation process?
2004 Excursion 4x4
Old 02-13-2010, 10:23 AM   #9
Ready-to-Travel
pmclemore's Avatar
If you have the broadband card, I think it is one of the menu choices under Options (I'm on my Mac now, and the menu for the VZAcess Manager is different from the PC).
In essence, it tells the card to search for the closest cell tower. Since I live in a fringe area it sometimes gets confused.
But if you don't use the broadband card, then my idea is not very helpful.
Pat
Old 02-13-2010, 12:09 PM   #10
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Howie,
Verizon DNS servers have been hiccupping here for the past few days, though they won't ever admit to to it....
To help make sure the issue isn't in your PC, try this -
  • Open a command prompt, by clicking Start, point to All programs, point to Accessories, and then click Command prompt.
  • At the prompt, type ipconfig /flushdns and hit Enter.
  • You should get a return message that says Windows IP Configuration, Successfully flushed the DNS Resolver Cache.
  • To close your command prompt window type exit and hit Enter.
Try those addresses again....
Let us know how you did?
Best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 02-13-2010, 12:21 PM   #11
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I had a similar problem with our local newspaper's website. I was getting 404 errors and unable to bring it up. I cleared cache and cookies and all that, still wouldn't work. Ultimately I removed FireFox and reinstalled (saved my bookmarks so I could load them back up), and it has worked fine ever since. Very weird problem.
Stephanie
Old 02-13-2010, 01:24 PM   #12
HowieE's Avatar
Images: 12
Thanks JM2
I remember when Verizon had employees that knew what their products did. That was a long time ago.
Thanks again
2004 Excursion 4x4
Old 02-13-2010, 03:21 PM   #13
StingrayL82's Avatar
San Angelo , Texas
Images: 37
When I typed the Save Wally Forums web address, the site gave me the 404 error. It did, however, work when I clicked on the link you provided Leo.
There is definitely a problem somewhere.
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 02-13-2010, 03:50 PM   #14
HowieE's Avatar
Images: 12
Try JM2 solution it worked for me a couple of hours ago and still works after I followed his instructions.
2004 Excursion 4x4
What is Wally Byam doing? PeeWee Airstream History 87 03-29-2010 07:30 PM
The Wally Bee 85MH325 Airstream History 13 02-15-2009 09:44 PM
Wally Caravan Melody Ranch Airstream Trailer Forums 2 01-11-2009 05:20 PM
Beam me up Wally mandolindave Off Topic Forum 0 10-02-2007 06:02 AM
Wally B # dmadam WBCCI Forum 1 04-14-2004 06:00 PM
