Old 08-03-2009, 07:31 AM   #1
1966 20' Globetrotter
1963 24' Tradewind
Wesley Chapel , Florida
what's it worth? 64 trade wind
Help found a 64 trade wind 24 ft single axel that has had a frame off restoration with new floor but the rest is gutted (nothing on the inside that's it worth)? body is straight would like to buy don't know how much to pay
shezatrotter is offline   Reply With Quote
Old 08-03-2009, 07:17 PM   #2
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
What about grey and black tanks? Where new ones installed? What is the new flooring material? Was the frame cleaned and painted? With what? How was the floor insulated? Sorry for the extra questions, but it is what I would want to know before I priced the '64.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 08-03-2009, 07:58 PM   #3
1964 24' Tradewind
Cape Ann , Massachusetts
There really is a large leeway here. Although the trailer may seem roadworthy ask yourself if you have the resources to follow through with all that is necessary for finishing the trailer. I know in my case with the same trailer that was in really pretty good condition, that I have just spent in supplies alone almost 2.5 k to do a frame on rear end replacement (new toilet, plumbing, water heater, water pump, new intellicharge with new rear end wiring, new floor replacement, replacing the collector waste valve, refiberglassing the black water tank, etc.). During the last 5 years I have put about another 5k on everything from new brakes (still need to do the axle), new refrigerator, refinishing and rebuilding cabinetry, new finish floor, mattresses, reuphostelry, etc. These are only supply costs since I have done all the labor myself.
So for the price, I would work backwards to see what it is worth to you, figure your budget for getting it on the road while doing it the right way, and then come up with your number that you can afford. If the seller bites and it is a fair number, you will be able to complete the project.
If you need any help with the project, I probably have seen it on the trailer. Feel free to reach out.
Eric
1964 Tradewind Double
graniteshore is offline   Reply With Quote
Old 08-03-2009, 08:22 PM   #4
VIKING's Avatar
Boulder Creek , California
$2,500.00
I just had to chime in here.
Being another '64 owner.
I would say between 2k and 3k is the range it would be worthwhile.
Consider that you will probably never recuperate your investment when you consider time and money. You will have to enjoy it instead!
I've gotta run... I just saw a 55 whale tail Flying Cloud on Craigslist in Turlock for $5,200.00
See ya, Rich
VIKING is offline   Reply With Quote
Old 08-04-2009, 06:32 AM   #5
1963 24' Tradewind
the 64 got the frame sandblaster rebuilt to orginal spec and painted insulated new plywood pt 3/4" floor the tanks are there but not installed the wiring was redone and the bottom skin was riveted back
Old 08-04-2009, 02:14 PM   #6
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Originally Posted by VIKING View Post
$2,500.00
See ya, Rich
I'd go with Rich on this one. I could be swayed with more information and pictures to add $1k to that, but $2,500 is safe.
TAC MN-6
WBCCI/VAC 11736
AIR 25979
floor, worth, restoration
Any Other '59 Tradewind Owners? flyfshr 1959-69 Tradewind 75 08-17-2014 12:45 PM
'59 Trade Wind flyfshr 1959-69 Tradewind 196 03-10-2013 10:42 PM
Trade Wind A/C Help mikesplace Furnaces, Heaters, Fireplaces & Air Conditioning 20 07-17-2009 09:48 AM
Need help on trade wind mercury7 1959-69 Tradewind 57 10-27-2006 07:38 PM
'61 Trade Wind DiMi Member Introductions 7 08-01-2006 04:00 PM
