Old 12-29-2010, 08:41 AM   #1
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Vintage Airstream in good company: Prevost
So this morning a Prevost dropped in to dump and take on water. Dad assigned the kids to duty, so I supervised. And to my surprise, I discovered that the Prevost uses ... Thetford dump fittings!
Lynn
WBCCI 21043
Old 12-29-2010, 09:24 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Thetford
Lynn
What point are you making?? Airstream MH also use the Thetford. Are you saying they are not a common fitting?
Dave
Old 12-29-2010, 10:10 AM   #3
DougZ's Avatar
1972 27' Overlander
Venice , Florida
I think her title made her point. I understand completely.
DougZ is offline   Reply With Quote
Old 12-29-2010, 10:37 AM   #4
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Nope, Thetford fittings are pretty uncommon nowadays. Try to locate such at a WalllyWorld, for example. I keep an extra sewer connector onboard for just this reason. It would really be the pits to be off in the backworld someplace with nothing but Valterra available. (My spare is out on loan right now.)
Lynn
WBCCI 21043
Old 12-29-2010, 12:16 PM   #5
DougZ's Avatar
1972 27' Overlander
Venice , Florida
Opps, sorry Lynn. I didn't realize you were a he! My bad.
Old 12-29-2010, 12:17 PM   #6
Images: 59
It' widely known in the RV community that Prevost and Airstream owners believe their s&!t doesn't stink.
The genesis of this misconception can be directly traced to the quality and utility of the Thetford system. Never leaks and vapor tight.
And please call them by the correct name. They are 'waste product offloading valves', not dump fittings.
Old 12-29-2010, 01:16 PM   #7
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Doesn't bug me. I've seen a whole lot worse, including being invited to a sorority rush event (I attended, of course, and was subsequently invited to join as an "honorary" member) and receiving a box of tampons as a graduation present from the city (I used them to soak up spilled oil).
Lynn
WBCCI 21043
Old 12-30-2010, 12:07 AM   #8
masseyfarm's Avatar
Images: 56
Thetford
Well - - - - you learn something every day. Today 2 things. The theory is great and I'll make sure I aquire a spare "offloading valve" fitting.
Dave
Old 12-30-2010, 07:46 AM   #9
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
It's no theory. My wife says that it doesn't stink, so that's that.
Lynn
WBCCI 21043
Old 12-30-2010, 07:50 AM   #10
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
When I redid my "offloading valves" I used the Thetfords again because I think they're made better than the Valterra. I hated the fact too that I always had to have a separate fitting to make slinky's or my Flush King work. So, when I put it back together, I put a Valterra end on the tube & I don't have to have the extra fitting anymore!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 12-30-2010, 09:09 AM   #11
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
"Effluent" is the word, I think. Effluent valves.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 12-30-2010, 10:13 AM   #12
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
So, then, I guess, Thetford makes "waste product offload valves" and Valterra makes "Dump valves"?
That's good to know, I think.
I'll have to remember that. Maybe
In any event, it's a good idea to carry an extra if you have Thetford. I have had two brake at the attaching hooks. Both in cold weather.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 12-30-2010, 12:40 PM   #13
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I assumed Prevost MHs had a little robot who came out and hooked it all up for you so you would never have to touch a dump valve yourself
Stephanie
Old 12-30-2010, 03:00 PM   #14
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Not the one I did. However, it did have electrically operated valves. Pretty goofy. The switches to run the valves were about 15 inches from the valves themselves, so all the wiring and stuff to go wrong was all there so that the person didn't have to lean over 15 inches and manually operate them.
Lynn
WBCCI 21043
