Old 07-16-2017, 07:55 PM   #1
2012 25' FB Flying Cloud
Lowell , Michigan
Using running lights instead of awning lights?
Anyone tried simply lighting running lights when parked and unhitched? Don't want to put out awning and hang tiki lanterns. Anyone tried wiring 7-way cord (running lights plug) to a battery switch?
blodger is offline   Reply With Quote
Old 07-16-2017, 08:00 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
There's a thread around here about wiring a TV side 7 pin connector to fire up the running lights. It's not that crazy.
Old 07-16-2017, 08:10 PM   #3
abqdor's Avatar
2016 25' Flying Cloud
Albuquerque , New Mexico
I found the thread and although I haven't tried it yet, here is the suggestion:
Easy, when camping, just put a 5 amp "blade" fuse across slots #3 and #4 on the umbilical cord you plug into the tow vehicle (looking at cord end with the nub up). That connects the running/taillights to the 12v supply of your coach.
'17 Ford F-150 Ecoboost, max tow package
'13 GMC Yukon Denali 6.2L V8
'04 GMC Yukon SLT 5.3L V8
abqdor is offline   Reply With Quote
Old 07-16-2017, 09:13 PM   #4
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Sure have, and forgot to turn them off when I went to bed. Woke up the next morning and discovered my mistake, turned them off and waited for the shorepower to recharge my batteries.........However due to a battery isolator, my shore powered converter can't recharge my engine start battery, so I still needed a boost.
We now take a couple strings of small LED Christamas lights that we string up around the coach and across the awning. It looks very festive.
Cheers
Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 07-16-2017, 09:15 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
I use a fuse and do it most every trip
CRH is offline   Reply With Quote
Old 07-17-2017, 05:03 AM   #6
Lowell , Michigan
Thanks everyone. I'm going to try out the fuse suggestion. Gonna be lookin good.
Old 07-17-2017, 05:25 AM   #7
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
A popular and previously discussed topic.
http://www.airforums.com/forums/f447...ing-59634.html
MICHAEL
Using ground for circuit negative instead of dedicated neg CA_Tallguy Electrical - Systems, Generators, Batteries & Solar 1 04-19-2017 08:03 PM
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Using 'Jack Nuts' instead of rivets? Eagle & Bear Ribs, Skins & Rivets 15 12-17-2012 10:31 AM
How do you create a link using a word instead of a url? Turtle Forum Admin, News and Member Account Info 13 01-15-2010 06:36 AM
using a futon mattress instead of cushions tinsltootsie Interior Restoration Forum 7 05-13-2004 08:01 PM
