Old 01-23-2006, 05:30 PM   #1
blucloud's Avatar
2007 27' International CCD FB
1987 25' Sovereign
1977 23' Safari
North Olmsted , Ohio
Images: 20
Question Upgrading our Tow Vehicle/ 8100 Vortec
I am in the process of uprading our tow vehicle. the vehicle we are considering is the GMC 2500HD, 4x4, crew cab. I am interested in the 8100 Vortec w/ the Allison 6 speed and 410 gears as a drive train. Are there any forum members who tow with the 8100 Vortec that could give their opinions of this motor.
Decisions..decisions...Dave
DUH! We will be towing a 25ft sovereign.
You never know what you can do
until you try to undo what you did.
blucloud is offline   Reply With Quote
Old 01-23-2006, 05:55 PM   #2
Craftsman
Guest
Posts: n/a
I tow with the 8.1L in my 2001 Suburban. I love it. It has tons of power. Towing a 31' Sovereign you forget it's back there.
Old 01-23-2006, 06:42 PM   #3
Airstream25's Avatar
1995 25' Excella
1982 34' Limited
Albuquerque , New Mexico
Images: 21
Send a message via Skype™ to Airstream25
Towing with the 8100 Vortec
Dave,
I have the 8100 Vortec in a Yukon XL. This engine is a nice improvement in towing power compared to the previous 5.3 L.
I have gotten 9.3 mpg highway towing about 55-60 mph.
On another trip at 75 mph and a head wind, the mileage dropped to 7.5 mpg.
I have a 25' Excella. I do not have the Allison transmission.
Airstream25
KE5CKG on 2 meters
AIR #10274
Airstream25 is offline   Reply With Quote
Old 01-23-2006, 07:15 PM   #4
I'd give some consideration to a lower rear end ratio than the 4:10 unless you are really going to be loaded down. The 8.1 has a pretty strong torque curve.
On a related topic, I just had my '04 K2500 crew cab in for an oil change at 37,000 miles (the dealer does oil and filter changes for $14 for life!) and have yet to have a single item fail in any way on mine.
Mark
'85 Sovereign, 25'
Old 01-23-2006, 08:27 PM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I have a little over 50,000 miles on my '01 2500hd extended cab 4X4 with 8.1 and 5 speed Allison auto transmission. It has the 3.37 rear end. I've only had an AC vent replaced under warranty because one of the vanes kept falling out when I went to adjust it up or down. I did have the battery case start leaking at the positive post but that is not unusual for side post batteries. It was replaced and no problems since. The transmission actually would not shift into reverse for a few seconds due to the corrosion inside the battery cable cap.
I use to tow a '77 Excella 500 31' but now tow an '86 Sovereign 25' model. Both are a breeze to tow with my truck. While performance is just great, if I had to do it all over again, I would choose the 4.10 rear end and go with slightly taller tires than the LT245-75-16. Even an LT265-75-16 E rated tire would make the truck look better and bring the overall ratio comparable to something like a 3.90. Of course, you would need a programmer or device to recalibrate the speedometer but the combination would look and perform fine. If you don't think you will ever go to a taller tire, the 3.73 rear end works fine. I get 10-11 mpg towing and I have broken 15 mpg on the highway a number of times without AC and driving 68 mph.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 01-23-2006, 08:32 PM   #6
wrepete's Avatar
1996 28' Excella
Geneseo , New York
Dave, I'm towing with the 8.1 in a 2004 Chevy Avalanche 2500 into high mountains in Wyoming and Montana the past two summers, and there is no lack of power or towing comfort. I've had three 3/4 ton Suburbans over many years, and I liked them a lot, but I really like the Avalanche with the rear covered bed. You will like the big V8!
Bud
1996 28ft Classic
2008 Silverado Duramax 2500HD
Hensley/BrakeSmart/EnKay
wrepete is offline   Reply With Quote
Old 01-23-2006, 08:33 PM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I tow with at 6.0L w/4.10s and I do great with our 25'. You'll be in great shape with that TV. Just watch the oil levels. I've heard many an 8.1L owner say it is not uncommon to eat up to 1 quart in between every oil change.
Old 01-24-2006, 08:33 AM   #8
AgZep's Avatar
2005 28' International CCD
Las Cruces , New Mexico
We have a Silverado 2500HD with the 8.1 and the Allison. I forget the gear ratio, but I think it's the 3.37.
Since gas prices hit the roof in August, we've been driving at 55. Often, we reach 12mpg towing, and we even broke 14 a few times. Unladen, on a long trip between southern New Mexico and northern Colorado, we were over 17 mpg. I would never have believed that possible...
The 8.1 is certainly a great motor for towing, but I have to say it's the Allison transmission that is really exceptional. I've never seen the tranny temp gauge get high, even towing uphill on the hottest summer days. When descending steep grades, you just brake to your desired speed, take your feet off the pedals, and let the Allison hold you right at that speed. It's wonderful.
I always tow with the cruise control and the tow mode engaged. No problems.
AgZep is offline   Reply With Quote
Old 01-24-2006, 09:06 AM   #9
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
We have the 8.1 in a 2001 quad cab dually with 4.1 rear end. Before I bought the truck they had replaced the engine with a crate engine because the original engine burned oil badly. I have 35000 on the truck now and put $1000 in it two months ago to replace the fuel pump and the spark timer sensor. Truck, of course, has lots of power and will pass anything on the road except a gas station. Pull a 31 footer. Have the allison transmission which runs great but the Chevy tech bulleton says I should have reprogramed to change the downshift set points. Something about possibly over reving the engine under some conditions.
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 09:14 PM
F250 tow vehicle or flatbed? Cheryl Tow Vehicles 19 08-23-2007 01:58 PM
Tow Vehicle Options wlanford Tow Vehicles 10 05-23-2005 12:18 PM
1975 Cadillac Eldorado as Tow Vehicle overlander64 Tow Vehicles 9 11-04-2002 07:04 AM
4x4 tow vehicle... or not? Cheryl Tow Vehicles 11 08-22-2002 11:00 PM
