Old 02-12-2006, 12:22 PM   #1
Question Unwanted guests in the trailor!
Dear Forum Members, I have a question involving airstreams and unwanted guests. Are airstream trailers any less susceptable to infestaion of mice and other critters due to their sealed undersides with aluminum sheeting? I have a friend who is interested in purchasing an airstream and parking it out on his land in Kansas where mice and other critters seem to get into everything. I personally have not found any evidence of rodents in my 1976 22' Argosy after having parked it for months in a nearby campground by a lake in Kansas. I also spent a lot of time under my coach after I bought it and redid a lot of the rivets so the underside was really closed up. Any thoughts or experiances from forum members would be appreciated. Sincerely Ray
ray matthews is offline   Reply With Quote
Old 02-12-2006, 12:31 PM   #2
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Send a message via AIM to Andrew Selking
If you do a search on this subject you will find lots of threads to help you.
My personal two cent's says that mice will come into any trailer whether it be a Airstream or a SOB. If you put out things that will deter them you should not have a problem. The threads will give you an idea what works and what doesn't.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 02-12-2006, 12:34 PM   #3
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Any hole or seam open even as much as a dime will allow those critters to get inside. If you are hooked up to electricity, I would consider those electronic pest things that are supposed to effect rodents, spiders, etc. but do not effect animals other than from the rodent family. You can plug holes with copper wool.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-12-2006, 12:37 PM   #4
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
I believe that Craig may be understating the issue a little. I believe they also come in by osmosis as well. They are VERY resourceful!
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 02-12-2006, 01:34 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Tell your friend to build a metal building. Its more like what he needs. Leave the Airstreams to the adventurous. I found Copperhead snakes in the belly of mine. (that should make him sleep well.)
Old 02-12-2006, 01:57 PM   #6
Jim Jarzabek's Avatar
1950 25' Cruiser
Lebanon , Ohio
Images: 16
Mice use transporters like on "Star Trek"
Both mice and cockroaches are so technologically advanced that they use transporter beams to move about ....
It got to be so tedious chewing....
Jim Jarzabek is offline   Reply With Quote
Old 02-12-2006, 02:44 PM   #7
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Back on the original topic
Craig provided the best summary so far. Steel wool worked for me at an old apartment.
Tom
Old 02-12-2006, 03:04 PM   #8
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
We use a combination of steel wool and expanding foam to seal conduit here in the power company.
Tom
Old 02-12-2006, 04:35 PM   #9
Craftsman
Guest
Posts: n/a
Mice love Airstreams. They like my 76 Sovereign better than the 94 classic. I'm not sure why, they may just prefer vintage units.
Old 02-12-2006, 06:48 PM   #10
JimGolden's Avatar
1977 31' Excella 500
When I bought my '77 and went to clean it up, I discovered the skeletal remains of a rat (not a mouse) and the left behind snake skin of the fellow that'd had him for lunch. Belly pan looked like a new one too.
I found a mouse living in the headlight assembly of my Polaris ATV. He got through a crack that was not much over an 1/8" thick. I don't know how they do it!!
- Jim
JimGolden is offline   Reply With Quote
Old 02-13-2006, 10:26 AM   #11
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
A couple of these guys/gals can do wonders for mice/rat problems. If they can't get to them, they will tell you where they are at, so you can open doors, remove panels, etc. Plus, they love their job!
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 02-13-2006, 10:41 AM   #12
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Snakes go to where the mice are. Where you find one - the other will be. A friend found a snake in his holding tank. Kept hearing a strange noise and did a dump a a rest stop. No idea how it got inside. He had been camping in his camper for the 10 previous days.
Mike
Old 02-13-2006, 12:11 PM   #13
1971 29' Ambassador
Leonardtown , Maryland
Un wanted guest.
My wifes' answer to these sort of problems id "Moth Balls".
Use fine mesh onion bags place some moth balls in the bags and place them around the inside of trailer in the obvious openings where rodants will enter. Do not forget the electric cord other exterior panels. Then place some moth balls around the tires, and any other parts that touch the ground.
To clear the air, about a week before using remove all the bags and open some windows.
We use this method every winter. So far so good.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 02-13-2006, 12:21 PM   #14
1950 25' Cruiser
Lebanon , Ohio
Images: 16
Wink Snake dance at the boat dock...
A while back, while waiting to launch my boat at the ramp, I was watching a guy with an Airstream motorhome. He had backed his boat down with the cover still on it.
It appeared he had not run his boat in awhile....
He took off the cover and started rummaging around; moments later a large rattlesnake came over port while he went vertical over starboard....
The rattler made its' way across the ramp unmolested.
The guy was pretty rattled!
Need help from england for trailor registration remcolent Off Topic Forum 2 08-07-2006 08:01 AM
See the Trailor Jump..... Jim Jarzabek Off Topic Forum 9 01-29-2006 02:59 PM
Lotsa guests today TomW Our Community 2 05-18-2005 10:16 AM
Do you dress to match the age of your trailor remcolent Off Topic Forum 26 02-04-2004 12:14 PM
Trailor brakes on 2003 2500 chev joel Tow Vehicles 9 10-10-2003 05:30 PM
