Old 03-13-2009, 12:24 AM   #1
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Trailer Trash?
Hi, as I was digging around in my trailer I pulled the cover off of the kitchen cabinet under my oven. I got my flashlight and was just looking around at things when I thought I saw a styrofoam coffee cup stuffed between the furnace ducts and sink drain pipe. Yes it was. And it was obviously left there by someone at the factory while my trailer was being built. As I looked deeper, I saw a piece of black plastic pipe, that seemed to be open on one end instead of connected to something. I reached in and pulled it out. This was a left over piece of black plastic pipe that was laying onto the furnace housing. Next I saw what looked like a white wire with a ground loop on the end of the wire, but was not connected to ground anywhere. I could not reach it from this side so I removed the three kitchen utinsel drawers and pulled it out; It was not connected at the other end either. While in there I saw a washer looking thing laying on the floor. It was a drill out hole of aluminum from some unknown place. These things wouldn't hurt anything and I really don't care about them; They could have been in this trailer for decades if I wasn't the kind of person who likes to dig. I do think it is a shame, for Airstream, that some of their employees think it's cool to leave trash in someone's trailer knowing they will most likely never hear or have to deal with it once it leaves the assembly line. On the other hand, I wouldn't feel sorry for this person if they lost their job because of our economy. No pride, No job. Anyone else have similar stories of trash left in their brand new Airstream?
I haven't been to the factory, but I would like to ask, or know, if Airstream has trash cans or recycle bins on their assembly line.
Name:	IMG_0405 (Large).JPG
ID:	76838   Click image for larger version
Name:	IMG_0406 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-13-2009, 12:32 AM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
You should ebay them as rare collectibles
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 03-13-2009, 05:55 AM   #3
Rollerboy's Avatar
1963 30' Sovereign
Gaylord , Michigan
Send a message via Yahoo to Rollerboy
I took off the wall that is in my kitchen,there written in black ink,was a Signature by the Lead Assembler in black ink,and in pencil ,His Helper ! Fire these two while your at it! Damn Hoodlums !
Rollerboy is offline   Reply With Quote
Old 03-13-2009, 06:32 AM   #4
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
When removing the "beautiful" shag carpeting from the 1978 Argosy Minuet, I found many rivet shafts under the padding. Obviously there is no time available to sweep these up.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 03-13-2009, 06:59 AM   #5
shermantic's Avatar
1972 Argosy 26
1973 Argosy 26
Fairmont , West Virginia
I think its cool if they if have a signature on you trailer! Might be worth more some day!
shermantic is offline   Reply With Quote
Old 03-13-2009, 07:01 AM   #6
modarch's Avatar
1967 17' Caravel
Thompsons Station , Tennessee
I found a ton of the metal "donut holes" in the bottom of my c-channel between the walls during my restoration. I didn't think anything of it... Now the pipe and cup are odd. But I wouldn't loose sleep about it.
modarch is offline   Reply With Quote
Old 03-13-2009, 07:07 AM   #7
funkill's Avatar
reno , NV
Images: 27
I was thinking your story would lead somewhere else ... i.e. you would soon mention that you had a little visitor (mouse) collecting stuff and building nests. Thankfully it was not that!
funkill is offline   Reply With Quote
Old 03-13-2009, 07:11 AM   #8
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
My city, Lorain, was home to a very large Ford assembly plant. Over the years they produced Econolines, thunderbirds, courgars, and others.
It is amazing to hear the stories of things that went into making Fords the best! Perhaps thats why they are no longer there....
Lets just hope that Jackson Center has more bathrooms than Lorain, Ohio
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 03-13-2009, 08:06 AM   #9
flitzwhopper's Avatar
1976 Argosy 24
Tempe , Arizona
When I pulled the furnace out to replace the motor, I found the knock outs and filings where they drilled the holes for vents. What's worse is that it the furnace had been removed once before to replace the fresh air cross over hose. No pride of profesionalism there. They also bent the furnace box up because they didn't know how to remove the furnace properly. It may have been done at an Airstream dealer because it was a factory recall. As a rank amature doing the furnace service for the first time it was well within the ability of a common man to do it properly.
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
flitzwhopper is offline   Reply With Quote
Old 03-13-2009, 08:27 AM   #10
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
Same thing on my 67 during my restoration, I found all kinds of goodies lying around.
In the trash can they go.
I hope the commercial aircraft manufactures are not this lax in the cleanup.
They must in a hurry, slow the line down a little.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 03-13-2009, 09:03 AM   #11
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Well, in digging around my 2004, I pulled several lbs of crap out. Routed out pieces of alum, rolled up wire, etc. It was literally several lbs.
The thing that really and truly ticked me off was when I installed my own subwoofer. Under my front couch, there is a white box type structure. I opened it up in the investigation stage to see about placement of said subwoofer because it was a bazooka and it was long, not the box looking one they shove in the arm storage of the couch.
To my absolute amazement, in the routed out hole that lead from the umbilical to the wiring inside, some clown had balled up and shoved a McDonald's breakfast sandwich wrapper into the hole.
After all the oddities and such I've exp with having owned two new Airstreams, it was this kind of mentality that really started to put the pieces together for me as to the mindset of the people building these units vs the issues I was seeing. I just couldn't believe someone would do something like that. When you post what you found, it really didn't shock me given what I have exp.
I know some folks get upset to find wood and alum shavings, to me that is small compared to 6x6 pieces of routed out alum, wiring and of course food wrappers.
Given the state of the economy, I am fairly certain the folks responsible for these lazy and rude acts have had time to think about their jobs as they have most likely been mothballed for periods of time due to production cutbacks at the factory.
Old 03-13-2009, 09:13 AM   #12
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
In one of the couch arm cover/lid we found all the clips n rollers (don't know real name) but are the runner attachments for the curtains that were originally in here...the former owners had taken out the curtains we are all familiar with and put in pull down shades which we are still useing today...we know there is one of you that specialize in making curtains and will probably get with you later. But this one was pretty darn clean when we purchased.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 03-13-2009, 10:00 AM   #13
1967 26' Overlander
Images: 107
No excuse for food wrappers and coffee cups.
PERIOD
Greg
Winston Salem, NC
WBCCI 5218,
Old 03-13-2009, 10:16 AM   #14
1972 Travelux Princess 25
Cobourg , Ontario
This is not the first time this subject has come up. Apparently it is a long standing tradition, going back the 60s at least, to send out brand new Airstream trailers looking like the inside of a vacuum cleaner bag.
They are still the same today if not worse. In fact, if a bag of trash is the worst thing you have to deal with you are lucky.
It's a mystery to me why so called reputable manufacturers, and for that matter unions, let a few ignorant goons ruin the livelihood of a thousand honest workmen.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
First Annual Trailer Trash Queen Results are in!! ScrapIrony-2 Fun & Games 3 10-20-2008 07:40 AM
Msmoto becomes trailer trash Msmoto Member Introductions 18 09-01-2008 02:09 PM
Talkin' Trash Bob Thompson General Interior Topics 25 07-21-2007 10:59 AM
Trailers Trash brunoffrance On The Road... 11 01-22-2006 04:11 AM
Beware, trash till Off Topic Forum 0 11-29-2004 08:32 PM
