Old 01-31-2014, 04:23 PM   #15
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by doorgunner View Post
Bob;
Is that a 60 something Crown Vic in the background??
Hi, doorgunner; This is the first year of the Galaxie, 1959. The most prominent change is the Thunderbird roof line. There were several other small changes making the Fairlane 500 into the Fairlane 500 Galaxie.
ID:	204707   Click image for larger version
ID:	204709   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-31-2014, 05:45 PM   #16
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Nice car Bob.
My question is: How do you put air in the centre wheel/tire of that dolly? They might have been better to equip that unit with "noflat" wheel assemblies?
One is supposed to do a pretrip on all that equipment before use right?
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 01-31-2014, 09:47 PM   #17
Salem , Oregon
Images: 18
Originally Posted by masseyfarm View Post
Nice car Bob.
Dave
Hi, Dave; The outside wheels have their own valve stems. The second tire in on each side has a valve stem extension going through the wheel of the outside tires. And the third wheel in has a really long valve stem extension that goes through two wheels. [left side has two valve stems and the right has three]
2005 Safari 25-B
Old 02-05-2014, 11:19 PM   #18
Salem , Oregon
Images: 18
He did what? Already.
Hi, OK, OK, I had to make some changes already. [modifications] I studied hard and decided that this was the best unit for me and my trailer. But there were a few things bothering me. First off, there were three wire looms to connect while using this machine. A 100 foot A-C cord for the electric motor. Then an umbilical cord for the trailer brakes. And finally a cord with two alligator clamps for connecting to the trailer's battery/ies. [that I can't get to] To me, this could cause problems while watching where I'm going and watching to see that these wires don't get caught on something while moving my trailer. Not to mention the brake controller switch felt weak and mushy. I bought a heavy duty toggle switch. I bought a new trailer connector. The one that came with It was OK but only had two screws for wire connections. I bought a real seven wire RV loom to replace the five wire loom with tiny wires and one incorrect wire color. I wired it up so my brake lights will come on whenever the brakes are applied. I wired it up so the battery power comes through the trailer connector instead of separately. And I used the third toggle switch to turn on the trailer's running lights. [Why? I don't know; Just because I could, I guess]
(1.) Stuff that I removed, but repurposed the toggle switch.
(2.) New heavy duty toggle switch installed.
(3.) New connector and new seven wire loom.
(4.) All wired up and ready to be tested, some day. [need my trailer to test] The third toggle switch is connected and in the box, but no hole was drilled for it yet.
ID:	205020   Click image for larger version
ID:	205022   Click image for larger version
2005 Safari 25-B
Old 02-06-2014, 10:53 AM   #19
masseyfarm's Avatar
Images: 56
"Engineering Evolution"
Dave
Old 02-06-2014, 10:20 PM   #20
Salem , Oregon
Images: 18
Dave
Hi, today I finished my modifications. I drilled a hole on the side of the control box and mounted the third switch. Wrapped some wires together and stuffed them back into the box. From the driver's seat, [no seat] the switch to my right, is the forward / neutral / reverse switch. The switch on the left is for the trailer brakes and brake lights. The switch on the left side is for the running lights. Since the actual operating switches are on top, I put the un-important running light switch on the side.
ID:	205066   Click image for larger version
2005 Safari 25-B
Old 02-07-2014, 12:08 AM   #21
masseyfarm's Avatar
Images: 56
Looking good and sounds simple enough for even me to operate.
I am waiting on your field tests.
Dave
Old 02-07-2014, 12:23 AM   #22
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Looks good Bob but is that strain relief on the yellow cord UL approved?
Cheers, Dan
~ Margaret Thatcher ~
Old 02-07-2014, 06:42 AM   #23
2013 20' Flying Cloud
Cream Ridge , New Jersey
So you're saying that all five tires are connected on the same shaft? It seems like that would create a lot of friction from one side to the other on a turn as they are all tied together.
Joe Palmieri is offline   Reply With Quote
Old 02-07-2014, 05:45 PM   #24
Salem , Oregon
Images: 18
Hi, Joe; Yes, all five tires/wheels are connected. This could make it harder to turn. [I will find out] But with five tires wide, it should be harder to tip over than lets say two tires. Also the handle is much larger and longer than most, if not all, other trailer dollies. [more leverage for handling]
2005 Safari 25-B
Old 02-09-2014, 03:53 PM   #25
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Greeneville , Tennessee
Robert, I am glad you posted this thread, it got me looking at this closer as my current residence that I rent is a real pain to back the trailers (35 ft AS & 30 ft enclosed cargo) into from a narrow road. I also loose the use of 40 ft of my drive because I have to back into the drive and place the trailer on the left side so the door opens onto the drive, if I put it over on the right side of the drive the door opens into grass that is on an incline.
I had been trying to figure out how to get the trailers in so the tongue is to the house leaving the doors to open on the pavement and still leaving 1/2 of my drive for use. Although I believe the power mover you purchased would be too hard on my back to pull it around for turning, thus I am looking at the other one parkit 360 transformer as it has a remote and turns without assistance. This could also be loaded in the back of my truck with my mini crane and used in other places such as some of the campgrounds I have been in that have a tight fit. Although I am not real big on the pricetag which is twice what you paid, but to save my back and have something that the wife could use if necessary is a good offset. Will be waiting to see what you post on yours before I go any further.
Sarge
Sarge USAF
WBCCI- none
Good Sam Life Mem
NRA, DAV, PGR, DRA
SARGE/AF is offline   Reply With Quote
Old 02-09-2014, 04:38 PM   #26
Firedog1
Firedog1's Avatar
2018 30' Classic
Woodbridge Connecticut & , Venice Florida
Sarge, I have a Park it 360, If you are going to alumnaflamingo I can bring it with me so you can try it out. Let me know. Would be happy to do that.
Firedog
Firedog1 is offline   Reply With Quote
Old 02-10-2014, 05:31 AM   #27
SARGE/AF's Avatar
1996 34' Limited
1976 31' Sovereign
1983 31' Excella
Firedog
Unfortunately we wont this year as other trips are already planned. Thanks for the offer. Is yours the transformer? if not how hard is it to turn?
Sarge USAF
WBCCI- none
Good Sam Life Mem
NRA, DAV, PGR, DRA
Old 02-10-2014, 07:05 AM   #28
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
LilNomad here..saw this in my trailer life magazine last nite. was wondering is the dolly for home use only? does anyone travel with one and can it be used to back in the trailer at campgrounds vs a front hitch? I know thats cheating hehe but just wondering. Im working on my backing skills. Its not really my skill level its all the stupid trees, rocks and other stuff thats not supposed to be there!
LiLNomad is offline   Reply With Quote
