Go Back   Airstream Forums > Airstream Community Forums > Our Community > Off Topic Forum
Old 11-13-2008, 09:49 AM   #1
Brookfield , Wisconsin
Trailer Automaton - Market Research
As a very short introduction, I created a start up company nearly six years ago and have provided patent pending technologies to various industries, including some systems currently in some of your trailers. Although it may not be readily apparent yet, vehicles and trailers are becoming an integrated system, interconnected using various types of networks, optimized to operate under various electrical and environmental conditions. Forums do not allow advertising and I promise not to do so, but forums are one of the best places to get input from "real end users" and thus this thread.
Although some limited examples exist, it won’t be long and the devices within trailers will be interconnected with a control network, “hopefully” creating an integrated system. Personally having 30+ years experience in factory automation systems I can clearly state your trailer can have almost anything you want, for a price. The question is what features would you like the most?
To be successful, these systems will have to provide added value beyond traditional systems, at a reasonable cost. The primary question is; What “problems” or features would you like in your trailer?
Possible areas to consider are;
Power Management: Things like “power shedding” where various non critical loads are disabled after some criteria is met to maintain battery power longer. Other areas include improved battery charging systems from vehicles, greater awareness of battery charge conditions, and so on. More easily answered, is there anything you don’t like about your trailer power system today? Any diagnostics you wish you had, but don't have today?
Lighting control: With the newer LED lighting technologies this may not be an issue, but is there any functionality you would like to see in you in trailer, and/or in your down the road lighting systems of your trailer?
Water system: This includes drinking water, waste water and so forth. Although not directly applicable our technology is probably in your home water softener if it is less than 3 years old, so we understand these types of subsystems. Is there anything you would like to see in your water and waste systems?
Security & Fire: Integrated systems enable quite a range of functionality in this area if you assume every sensor and every actuator can share information within this system. We would appreciate any ideas you would like to see in these systems?
Leveling, actuators, etc: When these systems exist, it is relatively simple task to “auto level” if this is desirable feature, but not sure this is of any value. Various forms of “extension” techniques for various accessories appear to exists for trailers, but they all appear to be “proprietary” solutions that won’t integrate well. Anything you like, or don’t like, relative to these subsystems?
Diagnostics: Whenever any system contains electronic devices you do not want the experiences you may have had when taking your vehicle into a dealership for “hopeful repair” where multiple devices may be replaced and you aren’t sure they were all required. Additionally you don’t want the failure of one device to fault other systems in your trailer. This should not be a problem with our approaches and thus assume the system tells you the problem, assuming a fault can be automatically detected. This is one area where some level of product expense is incurred to add numerous diagnostic features, and thus wise selections in this area are important. We are extremely literate in these areas having provided “extremely leading edge” technologies into our customers products and are confident we can give you what you are “willing to pay for” within a device. If we get a reasonable level of responses to our posting we will provide multiple surveys in this area to provide some “end user insight” into the product cost associated with various features to try to determine what is “required”, “highly desired” or “desired by not required”. We can provide various "white papers" to describe various issues since product supplier decisions WILL impact the end user experience and thus we prefer "informed decision making". What have you seen in the area of diagnostics that you like, and what you have experienced and don’t like?
Product packaging: This is perhaps one of the more difficult areas, since different control devices may be required to meet different criteria. For example, a braking system is exposed to the elements and thus must be environmentally sealed and must still be able to dissipate the heat its electronics, motors, valves and so forth produce. Devices in the vehicle cab may have to tolerate a coffee spill, but don’t have snow, salt and gravel pounding against them. Our research indicates most “in trailer” control devices, worst case, seem to fall into the vehicle cab scenario where most are actually housed within sealed boxes, and thus almost no special conditions are required. Any electronic packaging likes and dislikes? Is there a certain "package size" that would be required to fit in various existing locations? Is there a preferred mounting technique?
Wiring: Do you prefer screw terminals, push on spade terminals, plug in connectors containing screw terminals for wiring, special crimped wiring harnesses, pre wired harnesses with wire splicing?
If you would like to participate in “what could be done” and “what will be done” either post your comments here or you may send me direct emails if you prefer a less public view of your comments. All direct communications will be held in confidence.
I clearly understand that most “market research” is done where all possible competitors can see the feedback provided,. My automation experience has found that issues exist in all industries where almost everyone knows the problems but many think they are “the only one that really knows the problem”. Having twenty combined years at Rockwell and Eaton I clearly understand that knowing the problems is only the first step, where providing acceptable quality solutions will determine the success of these coming trailer systems. I clearly understand that “perception is reality” and that there is no such thing as a "bad comment" or a "bad opinion", so please do not hesitate to provide your input.
In return for your input I would be more then willing to provide some insight into actual product development, what can be done easily, what can be done cheaply, what can be expensive so you had better "really want it" and so on. Since we support almost every vehicle network accessible at the OBDII connector from all popular vehicle manufacturers and various industrial networked devices and are very familiar with certain subsystems on trailers today, as long as I don't run into a "non disclosre agreement" problem I will provide answers to most questions in "generic terms". As I prefer to fault on the side of being "more then ethical" I may not provide answers in a "gray area" or may require an OK from one of my customers before providing an answer. If a customer allows me to reveal their product to answer a questions, I could provide more concise answers. Again, this is your chance to impact the future to "trailer automation" and all input will be taken seriously.
C5Don is offline   Reply With Quote
Old 11-13-2008, 10:32 AM   #2
1960 22' Safari
in the wilderness , The great Mojave Desert
I would love a system monitoring panel that was accurate.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 11-13-2008, 10:56 AM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
We've all been exposed to the benefits of automation in our newer tow vehicles and autos. On the downside there is no doubt that I have in many cases lost my ability to service and maintain my vehicles. We now have so many electrical and monitoring hooks in our vehicles, that you now require advanced tools and training to do repairs. My ABS light came on in my Honda. Possible problems may be the ABS computer, wheel sensor, or wiring issues. Is ABS good, yeah but it adds a level of complexity to repair and maintenance to my vehicle.
My trailer is a fairly simple vehicle. Yes some of the components have grown in their sophistication level, but all in all it's not beyond the scope of our ability to service. Adding any level of system control and automation you now add in a new layer of wiring infrastructure, sensors, and the need to provide diagnostic tools for the automation itself.
Quite honestly I use my trailer for weekend camping and vacation time. Does it need to grow into this electronic being that for all intents takes servicing totally out of my hands? Maybe this is a good idea for the Motor home folks who might be able to use some of this in their vehicles. Or you might consider the full timer who has some need for a higher level of control of their units. To me this idea seems to be a little too much overhead for a vehicle whose only job is to provide me temporary shelter for short periods of time.
It all comes at a price and in today's economy we don't need to be inflating the cost of our toy's with things that really don't have a good return on the investment based on our usage expectations.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 11-13-2008, 11:07 AM   #4
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Jack, I have to agree with you. We went from a tent to our Airstream five years ago and the simpler the better. The beauty of our Airstream is that it is well built, a design classic, simple systems for great camping. I don't want to add more $ to the bottom line, I don't want my TV talking with my AS. I don't want to be paged by my AS when my grey tank is half full. I don't think I need to interface my laptop with battery to tell me the black tank is full not do I need communications between the galley area and the bed. I also really do not want yet another do-dad that I can't get to work and start yet another thread on the forum about. Sorry, but feel the AS does not need to head into the 26th Century.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 11-13-2008, 11:20 AM   #5
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Other than monitoring of power available and ensuring that my appliances actually function adequately I prefer the simpler is better mode as noted by the others who have posted. The ability for RV dealers to actually repair anything highly technical is, in my opinion, a big hit and miss situation right now and their costs to ramp up with tools and education would put the already high costs of owning an Airstream over the top for many. Being able to diagnose and repair a system in a campground several hundred miles from a capable RV repair center is a huge consideration and I would only purchase a unit that I was capable of keeping going. You break down in your tow vehicle on the road it is relatively easy to rent another TV while yours is fixed. That is not the case with your Airstream.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 11-13-2008, 11:28 AM   #6
I agree with all comments thus far, which is the "historical problem" with automation. Some is good, some is bad. For example, few of us would give up our TV remote as it did "add value". Perhaps consider this; would you like to be altered in the vehicle if you are driving down the road and "smoke" is detected inside your trailer? Perhaps there is added value there, where turning on the lights adds no value. Even better, if the source of a short could be identified and disconnected, that might be a good thing. So doing automation for the sake of automation is for hobby people. I am an old automotive gear head (drag racer) and loved carburetors and such, but I do like my fuel injection as it does provide milage and performance. Simple is better is absolutely correct, which my fear is trailers following the "automtive approach" referenced above and thus being more aggravation then it is worth. Some products currently coming down the road, when introduced, will show some of the added value and I will be able to "say something" at that time. Again I am looked for "good stuff". Relative to the "monitoring panel that is accurate", please excuse my ignorance, but could you be a bit more specific? Others on this forum probably know exactly what you mean, but I am new to many areas of RVs and trailers and what values are being monitored and what values are in error? Again, I really appreciate your inputs. By the way, relative to reading automotive PIDs and such if we don't do better then that we should be shot. In reality, my current "trailer device customers" are more then concerned about diagnostics like identifying a bad sensor easily and I believe when they introduce product you will agree they understand your concerns.
Old 11-13-2008, 01:13 PM   #7
jcanavera's Avatar
Fenton , Missouri
Images: 143
Holding tank sensors and their reporting systems have been notoriously one of the most prone to failure components of RV's. Sensing methods have been floats, sensors on the sides of tanks to the newer pressure type sensors which have some ability to determine the volume in a tank. In each case you are dealing with having to detect levels of liquid which are clean (fresh water), somewhat clean (sink and shower water), to dirty (toilet holding tank). Due to the debris that may or may not be left in the toilet tank (we call it black water), this tank is most prone to have a sensor malfunction. In the newer Airstreams they use a device which senses pressure which somehow translates into level setting. Apparently it's less prone to fouling by debris. Unfortunately it's not been the total answer since we have seen instances of monitor panel failure, sensor failure or inability of the system to keep its calibration that is used to determine the volume of liquid in the tank and how it relates to the fullness condition. This calibration is critical since Airstream uses different size holding tanks per length of model of the trailer. The calibration at one time was loaded to the monitor panel via a Palm device. Bottom line is that no one really has gotten a good solution on a method that will operate for years without failure.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 11-13-2008, 03:52 PM   #8
jcanavera
Gee, do you know me? Bottom line is I actually have a prototype device for tank guaging, as it is one area of expertise in a prior life. In effect you can calibrate it for your specific tank, dents and all. The device would allow any form of voltage or current sensor input. In effect you can think of a tank guage as a glorified "look up table" where the sensor voltage is measured, then a volume is "looked up" in a kind of spreadsheet. For every voltage there is an associated volume. Now the whole theory is that "everything is level" as calibrated and that the output voltage of the sensor does not drift with temperature and such. So trailers and vehicles are a little more tricky, where "tilt" has to be taken into account and where the "look up tables" can get a little more complex. You also implied the issue of "fluid density", where say water expands and contracts with temperature, and mix in some solids and the averge density of the system changes. My guess is probably being calibrated on water would be good enough, but based on your comment that may not be the case. The issue is "plugging a cheap pressue sensor" if it is not a "flush mount" sensor. In process control (prior life) one uses flush mount pressure sensors which are NOT cheap, but they would clearly work. Another way that is used on the huge silos you see by dairies and such is called a "bubble tube" were a very low air pressure constantly pushes air out the tube, where the liquid pressre where the bubbles exit is measured at the sensor, located remotely in nice temperture and environmental conditions. I don't know if trailers have a "air source" that could be used for this purpose, or perpahs just a blast of pressurized water from time to time to just "clear the tube would be fine. Bottom line is this problem can CLEARLY be solved and made quite accurate. It is not uncommon to provide "temperature compensation" to adjust for drifts due to temperature at the sensor or at the fluid, so this is really no big deal. This was an EXCELLENT comment and is exactly they type of feedback I am looking for. I am EXTREMELY pleased at how active this site is and exceeds all my expectations, but confirms what I have been told many times by existing trailer industry customers and even RVIA adds relative to how friendly everyone is in this industry. Providing an improved tank guage is quite straight forward and although I did not hghlight all the issues for guaging systems, I believe we can solve that problem. Do you care about the "display technology"? For example, a low end small LCD of 16 to 20 total characters could do the trick, but LCD's don't like the cold. Another alternative is color, like the size of a traditional cell phone. It costs a bit more but is really impressive when alrams go red, different colors for differnt conditions and so forth. In these types of "sytems" I personally believe the most cost effective approach is to have a display device, like the little color one, that is then shared by everything in the trailer. IF you want to upgrade to a larger one, or use a very low end one like the LCD I referenced, you could unplug one and plug in the new one, and in a "good system" would be good to go. I would VERY much appreciate comments on the desired display technology as well as packaging. For example, would something like a "thermostat control, wall mounted" be desired, or plug in hand module one the end of something like a flexible phone cord, or ?
Old 11-13-2008, 04:10 PM   #9
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
Sounds complicated—and expensive.
Others have said and will say it better than I, but here’s my 2 cents.
This particular forum has hundreds of members who are restoring older Airstreams. 1950’s models are still quite common with a few from the 1940’s still rollin’. I have a 35 year old camper that I am restoring from the ground up. I am amazed at the items that still work after all of these years. A couple of everyday examples. The 35 year old rectifier that came with the Airstream new, still works, not well, but it does work (a rectifier converts 110v ac to 12v dc to run many of the systems in RV’s). It will need to be replaced. I doubt very seriously that 35 years from now any rectifier produced today will still be around. Refrigerators are another example. The fridge that came in mine still worked when we bought it a few years ago. It now needs to be replaced. For some reason, many modern models have circuit boards in them that self destruct after a couple of years. None of this is inexpensive to repair.
So, why would I want to complicate things with extra sensors and controllers that will inevitably break (sooner rather than later). Today’s consumer electronics have a tendency to be very, very poorly made. Break it, throw it away, buy a new one. No thanks.
If you could devise a way to do all of these things inexpensively and give warrantees that run years and not months, there may be a market. Would I buy these things? No. I really don’t need them, nor do I want the headache. The electronic “upgrades” on my camper include a new car stereo and a small HD TV. That’s about it.
Maybe there’s a market for the truly high-end RV market, but most of us here are not part of that market.
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 11-13-2008, 04:49 PM   #10
Barry,
Your service concerns, with todays technologies, can be handled much better then most of what you see today. The kind of system architecture trailers could utilize would simply require that you plug a USB cable into one of the devices in the system into your laptop. If you can connect it to the internet, then remote access is possible. Although I won't disclose too much here, I personally prefer the ability to download a series of diagnostic applications to the end user. These would provide a step by step sequence following directions on the laptop to "drill down into the system" and the "devices in the system" to identify the root cause of a fault. In this way, the applications can stay with the customer in case he needs it again, or he can even give it to his friends. Besides, you don't always have intenet access and thus an architecture that provides the ability to "look at anything inside any device, only when needed", and when the existing diagnostics are not sufficient, "download additonal diagnostics" after "removing the prior diagnositcs" and thus keep the memory costs down is, in my opinion, the preferred approach. We do this today, so that is not the issue. And I don't know about you, but I really don't like it when Norton or someone else with "marginal software" is cruising inside my machines. For those whom want someone else to "look into your system through the internet" that certainly can be done and is not precluded as long as that capability is part of the system design. Personally I think diagnosing a problem, and then having a part waiting for you at your closest dealership would be my opinion of "quality service". So in conclusion, if a device and the system are not designed from the start to support whatever level of diagnostics that are needed to indenfity a problem, then everyone will always be asking for better diagnostics. The reason you have problems in diagnosing vehicles is because "all those devices are different" and "none of those devices supports diagnostic capabilities" described here. I could continue to ramble on and on, but lets just say that if the communicating trailer devices follow the same road as industrial controls took in the early 80's, or the PID approach used by current "automotive manufacturers", a marketing manager I worked with said it like this; "If you continue to do what you did, you will continue to get what you've got"! As end users of this stuff be happy that perhaps this transition is occuring at the right time where technology now enables this industry to follow a different path. I will ask numerous questions relative to "preferred diagnostic interfaces", and with all your help, hope to "keep it as simple" as I can.
Regards,
Don
Old 11-13-2008, 04:56 PM   #11
Trailerite
TwinkytheKid's Avatar
1971 23' Safari
Riverton , Missouri
I am not interested in a computer controlled travel trailer. When I go camping it is to get away from it all, simply. I don't want to lug my laptop with me on the chance my waste water monitor will stop working. As long as I have something that tells me how much fresh water I have, how much crap is in the tanks, and if my battery has a charge, I'm happy.
Now, if I had a million dollar motorbus, I would expect it to do everything, down to dropping a replacement roll of toilet paper in place when a roll empties.
Michael.
TwinkytheKid is offline   Reply With Quote
Old 11-13-2008, 05:11 PM   #12
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Simplicity is good (the old "less is more" theory)...which is proven over and over in our world. However, remember that what we think of as "simple" today is light years more "complicated" that what our grandparents grew up with...and their parents probably thought what they had was too complicated. It's a matter of perspective. Don't get me wrong...I love vintage Airstreams...and restored cars, etc, etc...in fact, I restored a VW bug convertible that I absolutely loved because of its "coolness" and it's relative simplicity. But even so, I much prefer driving my new truck as a regular means of transportation. "Complicated" is a matter of perspective. We have a newer Airstream that we really like...but I think it would be kinda cool to be able to plug it into my laptop and have it help diagnose the systems and let me know that all is well. That would leave me all the more time to enjoy camping in "relaxed" mode... By the way, welcome to the Airforums, Don!
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 11-13-2008, 05:21 PM   #13
moderator
Airslide's Avatar
2016 27' International
Wilton , California
Images: 50
I work in the service department of a Mercedes Benz dealer and see this stuff every day. Talk about complicated!
But.. since you asked.
What about a "reliable and accurate" tire pressure monitoring system that could be integrated into the vehicles display. This will be the norm as manufactures perfect this technology. I would love to know whats going on back there as we all have concerns about the tires under our heavy airstreams already. And since your at it we could integrate a weight sensing device that might look for overloading. This is a common problem familys have since we like to bring everything and afterall .. there are all those cabinents..
just these two safety related features would get me thinking the RV industry is catching up..
Vinnie
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 11-13-2008, 06:23 PM   #14
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
This is the kind of example that people will say 'of course that's a good idea', but would anyone pay extra for that in their trailer? Mine has been towed around for 40 years without having a fire inside it, let alone while being towed down the road. So I'd have to say we've been doing just fine without a product like that. Just to point out that people might say that's a great idea when asked, but actually shelling out money for it is another matter.
I'm with the folks who say they are happy keeping everything as simple as possible. Luckily mine is so old there's nothing to worry about automating. If we want to know how full the black tank is, we just open the toidy and peek down the hole
Stephanie
Old 11-13-2008, 09:03 PM   #15
Vinnie,
I agree with everyone here about complicated is not good. Why are vehicle systems complicated? The cultures that built them build cars, not electronics, and it shows. Heck, I worked for two of the largest automation suppliers in the US and had to go out on my own to "do it right". Any of you whom work for corporate america, especially in engineering, clearly understand what "could be done" versus "what is done" due to a multitude of issues, which is why we go camping. So its nice to see the disgust about electronics and systems, as that clearly indicates a "market oppurtunity".
Relative to your tire concerns, I think you will see some solutions coming soon in that area, assuming one of my customers "enables the feature". The system I reference will do more then tell you pressure, but will only be useful on a certain type of trailer. Once they introduce the products I can say more, but can't say a lot right now. I will say there are the capablilities of indicating uneven tire loads and such.
Relative to communicating the information up to the cab, that is already a done deal once a specific product line is introduced. It is "inherent" in a new subsystem, and is exactly one of the reasons I having these dialogs.
Relative to say the "tire conditions" and other detected faults, what is your preferred interface, as this is a constant debate. For example, telling you "error 21", like a vehicle, is not intuitive. But indicating "Left Front Low 15psi" might be a bit better. Under what conditions do you want to know something is wrong? Do you want to be able to configure your own pressure thresholds?
I assume people don't want to be bothered by "beeps" and "screen changes" and such unless something is "really wrong". My guess is this kind of stuff would be configurable, where you could enable/disable the audible alarm as this stuff can get very irritating.
Relative to product quality, here are some experiences I am painfully aware of relative to the trailer market.
1) Some think "ground is ground" meaning if they connect a wire to the frame the current will magicly flow back to the negative terminal of the battery, even as the connection corrodes.
2) Somebelieve 16 guage wire can carry 40 amps
3) Some believe a butt splice is a good connection
4) Some believe that wires do not "drop voltage" as the current increases
I can go on, but poor wiring practices are the biggest problem I have seen in trailer systems to date. Relative to reliable networking, it is more difficult to achieve in a trailer then in a vehicle, where wiring harnesses and connectors are acutally designed to meet the needs of a specific vehicle. A trailer is more like an industrial plant, where all kinds of devices could be connected. My experience thus far is this is a trailer systems has to be much more forgiving. Additionaly, I personally believe inital devices need to be "overdesigned", or minimally need to have internal diagnostics that make it very difficult to "smoke a device". For example, some existing devices actually monitor the health of the power electronics, and if they begin to overheat they alert the operator and limit the power so they don't fail. In fact, they could acutally act as an electronic fuse, and not smoke the device.
Thus far I "get it". If it is not high quality, don't do it. If a user can't identify a fault easily, it is a bad design. If a user plugs a new device into the system, it should minimally provide limping functionality to verify it is working, without any special training or tools. If help is needed, plugging into a laptop and getting assitance over the internet is highly desired.
Regards,
Don
Old 11-13-2008, 09:33 PM   #16
moderator
Airslide's Avatar
Wilton , California
Images: 50
Don,
If you ever come out to California i would love to meet you. I have been working with Can-bus networking systems since 98' and doing market research with customers for several years. I also "Get it" why most dont appreciate the upside of technology vs. the satisfaction of actually fixing something on our trailers better than what came from the factory. Here is an example of poor engineering. When the Volvo S80 was originally launched in 1999, the drivers instrument display would actually say "Stop safely and restart vehicle". Can you imagine what the driver would think when they saw this? Well, the ECM really just needed a reboot but the engineers thought that they would or should get it right away and inconvenience the customer to perform this alarming task. Now they just hide that function in the vehicles next restart. It sounds like your working with cutting edge technology. Why shouldnt the finest recreational vehicle have these features if they are truely ready for the market. These systems would have to withstand moisture, vibration, extreme temperatures, neglect, age and customer modifications! No easy task. The fact is that people do desire these features (maybe not all of us) but people that buy products, hopefully airstream products so this company can stay alive and competitive once things turn around.
Cheers,
Vinnie
Old 11-13-2008, 09:44 PM   #17
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
I like to abide by the KISS princple! Adios,John
Diesel1 is offline   Reply With Quote
Old 11-13-2008, 10:25 PM   #18
Mexray's Avatar
1978 28' Ambassador
Morada , California
I'd like to see some new, designed from the ground up, LED interior lighting fixtures that would provide adequate illumination and reduced amperage usage...the 'long life' value of LED's is over rated, IMHO...what we need is lots of light, with less amp draw on the battery bank.
I also agree that systems need to be kept simple for trailers designed for 'camping'...but on the other hand, there is a portion of the RV public that wants 'all the options', and as such, the KISS policy goes out the window!
In these days of HD, LED TV's, I'd really like to see some kind of quality entertainment system that could be easily 'customized' by the user...perhaps a design incorporating a high tech looking 'central' unit with components that would fit into compartments and use a network to interconnect...the old plug and play concept...one could pick and choose which 'components' he wants in his system; Sat radio, DVD player, Sat TV receiver, Stereo Amp, AM/FM radio, iPod like device player, etc...
The TV monitor would interconnect with the 'central' unit to play the audio through a real quality speaker system, not just some ten dollar speakers mounted in the wall or ceiling! Most audio systems in RV's are really built 'cheap', unless it's in a mega-buck Moho!...Trailer Mfg's need help in this arena!
Ray & Pat; Morada, CA
Old 11-14-2008, 08:45 AM   #19
Vinnie,
You called it right, this is very leading edge technology. Although this is not always the case, and varies with company and current boss (enough qualifiers), changing the status quo is difficult, and is one of the primary reasons "new and good" technologies take so long to adopt. To put this "software and networking" stuff in perspective you just need to ask a simple queston; "Mechanical engineers design products they may design a new bracket but they select from existing bolts, nuts, washers and so forth and REUSE existing technologies spending their time on the real problem. Electronic hardware engineers do the same, going to data books to select from available parts, then make the "unique schematic and circuit board" to interconnect these components to create a new product, and they are competitive. Most firmware (software inside products) engineers start a new product, and more like then not, "start over" reinventing their equivalent of bolts and such. Why you may ask? Because they can. Do the products they create have "software schematics" that replicate the implimentation exactly like a hardware engineer? Not very often. Do their "new software components" get applied in multiple situations like the previously referenced bolt or electronic component where constant reuse "uncovers and corrects" the defects or adds functionality for new applications of the object? Nope. Now creating all these software components is what software engineers call objects. However, in the world today although PC people, using windows and such may "reuse some microsoft objects", the interface to all these objects is "different". In other words although you may have a half inch bolt, you can't insert it in a sixteenth inch hole. What our software/firmware inventions do is provide the EXACT same software interface to all our objects, meaning every function in every object class has EXACTLY the same interface. Thus we have "plug and play" inside a product, and since all objects have the same interface, we can add or remove new objects and NOT negatively impact any existing object. Then we "interconect the objects to create product functionality using software schematics" which we call User Application Programs. Bottom line is ALL internals of ALL products form ALL manufacturers in ALL industries is EXACTLY the same. Since these same interfaces interconnect these products to the network everything on the network is the same, thus "plug and play". Thus one interface tool to service all products. Thus, if the product vendor allow it, you could "look inside and see" exactly how a product works and identify the problem.
I have been doing this for nearly six years now, and trust me, every new customer has their engineers whom tell me it can't be done, it won't work for their type of products, and so on. Bottom line is it has never failed to meet requirements. So can you have ease of maintenance? Sure. Can you have plug and play? Sure. Can you have a system where you can replace a the year old product with a new product as long has in minimally has the right type of inputs and outputs by merely downloading the "old User Application Program"? Sure. As they say, you can lead a horse to water but you can't make him drink. We will see if the trailer industry thinks this is a good idea, since they have not yet gone down the road of totally proprietary systems. So does the USA have the innovation and leading edge technical capabilities to recover our economy? Sure does, but it takes open minded companies that realize they "sell trailers" and not electronics to get this to happen. The high quality of Airstream obviously has a high quality minded customer and thus the types of feedback I am getting. Ya, our technology is pending in some trailer market suppliers products, but until the announce I have to keep my mouth shut. The issue is we may be forced to provide some of these other products to crush existing vendors in your market to get them to think this is a good idea, as we do not want to sell product, just technology. However, our non disclosure agreements do not allow us to reveal our customers, as they don't really want their competitors to use our stuff. Being an engineer, it was a marketing "slip up" and thus we minimally have to provide at least one of our own products so that we can "reveal our capabiltiy". Sorry for the long discussion, but that is what we like to call "leading edge".
Mexray,
I hear you about all the entertainment stuff, but that is not what we do and that is an industry of "perceived open" where each company creates a different version of their standard and then trays to get everyone to conforrm. Like VHS versus BETA some eventually wins (not necessarity the better solution) and you get a "market standard". We can't afford to play there and you will clearly have to rely on others. We do "licensed open control" where we eliminate the technology risks for our customers and they determine what features the product will do, how robust the electronics are within the device, how environmentally sound the product is and so on to differentiate themselves in their market. As that old commercial said; "We don't want to change the world, we just want to change your oil!"
Regards,
Don
Old 11-14-2008, 10:12 AM   #20
Vinnie,
Relative to "CAN" based networks: Like many engineers I have been involved in industrial control networking since the early 80's. When I did processing plants we actually may have installed one of the first fiber optic networks in a food processing plant as an "experiment" for a customer, and loved it. If there are any oldtimer egineers on this site, I even did the old intel BitBus stuff using Multibus 1 board level computers; one of two pre-PC bus standards. Since then I went to Rockwell, were I was involved in "every network known to man". some good, some bad. In effect they turned me into an extremely network literate engineer, which is where I was one of the primary architects of what the call the CIP architecture, which inculded a CAN based network called DeviceNet (tm), as well as ControlNet and EtherNetIP. That was where I took my first object based real time control arrows, where the architecture eventually became the industry standard. Although I was kind of ticked that what the archtiecture was "intended to become" got kind of messed up by those whom "didn't get it", many of my friends there say they were amazed how much of it "stuck" and that I should be proud of that. Then I did time at Eaton, doing the same old stuff, just more of it. I was chairman of the ODVA (Open DeviceNet Vendors Association) System SIG and member of the Technical Review Board for all my time at Eaton. The guys on that SIG were some of the "best of the best" in industry, but in effect, they are all "on to other things". That architecture was pretty good, but due to some of the "democratic" decisions, where everyone has a right to one vote even it they don't know anything, some of the specification details resulted in needless software overhead where none was needed. Combine that with "market protection" strategies and although, in my opinion, the best perceived open network for industrial controls, it just did not "scale well" to smaller systems.
Thus, to this date, all of my customers using CAN utilize our protocols, as they scale very well and correct the "democratic decisions" made on DeviceNet. Additonally, to get an architecture right, you must have a "dictatorship", where the dictator had better be true to the common interface theme. Bottom line is CAN is perhaps the BEST network for the buck. Then come the automotive guys, whom effectively created it as the next generation J1850 solution. To their credit, they kept the protocols the same when they used CAN in what is commonly referred to as J1939. However, keeping things consistent with the "old PID interface approach" caused them to mess up what CAN is good at, as well as some other things. For example, if you want CAN to "work" with long cable lengths and such you need to sample a bit "late" where J1939 does it at 50%, DeviceNet does it properly at 80%+. Since vehicle wiring is relatively short, not a problem. However, some of your trailers are not that short, so personally, I see a potential problem. By the way, it gets worse with lower cost cabling. DeviceNet requires "high buck" cable just to get their lengths, and the push the edge of the spec. Another item is CAN uses a "number" sent on the wire to determine who "gets to send a message" so that the network does not fail due to collisions. The lower the number, the higher the priority, and thus the lower number always wins. So if you looked at the details of the automotive numbers you would see they kind of "messed up" this priority capabiltiy. So then what they do is use various traditional techniques to get the system to work properly. On a vehicle, that is OK (I guess), but when you start mixing all kinds of control devices on a network, you want to be able to "tune" the system where high priority stuff ALWAYS goes first, and low priority stuff waits. I could go on and on, but let's just say, as best I can tell, the trailer maket appears to think they are building a vehicle and not a control system. Personally I am hoping I am early enough to try to impact the major trailer manufacturers direction but it may be hard, because they build trailers and not networks or control systems and they really aren't skilled in the art. In the technical area I don't loose many battles as I am honest, open minded and admit when a better approach exists, in addition to having years of experience in what works and why, and what doesn't work and why.
Lastly, everyone always thinks the "network is the problem" which is entirely NOT the case. In reality, the network is where external devices "see that the internals all devices are different" and thus they blame the network. The network interface then becomes the place where they try to enforce the "interface rules" and thus everyone standardizes on the network. In reality, they should standardize on the internal device architecture, where common protocols are then used at the interface to enable navigating, configuring and programming the device. So the trialer industry could be in for the "network wars" that occurred, and still is going on in the industrial market. Personally I am going to try to make this the "VHS/BETA" for "J1939/Other" war and we will see what happens. The good news is our stuff merely changes a User Application Program (software schematic) and we can coexist with most any protocol while embedding our own to "actually plug and play". We will then have to "find the loopholes" in the J1939 CAN Identifier Usage to make stuff work OK. SInce this industry will never test the bit sample point, we will run at 80% and not 50% and thus won't "fault like others". Hopefully this little bit of info will filter into the technical debates and this issue will be corrected in trailers. There are many other similar issues, but hey, there are reasons why some products are considered to be quality products, and others are not.
Sorry for the long CAN response, but buttom line is CAN is excellent, but there are a number of "wiring practices" that MUST be followed. What trailer specification do I reference to find what cable to use, length of network drops and so forth? Do all devices require a network status LED, and if so, what does it mean if it is RED or flashing RED or flashing GREEN or Off? What "connector" is used for all devices to connect to CAN? How does a tool do a nework Who to identify the connected nodes? This list goes on. :>)
If this stuff is not specified before the first network products are introduced, buckle up. These specificatons "may" be underway and I am just some outside idiot that is not aware of the real status, and thus hope someone with this knowledge will either post a message correcting me and point me to these specifications. Until then, I will use my own.
So when everyone wants the industry to follow the KISS principle, time will tell if we are trying to "herd horses" or "herd cats". For their own sake, I hope trailer manufacturers are not cats.
Regards,
Don
Research by WBCCI Number? ankornuta WBCCI Forum 1319 04-15-2024 07:53 AM
How Do I Research My Trailer History? SUEHOWIE 1954 - 1959 Overlander 8 10-21-2008 08:49 PM
Crazy Storage Idea (Market Research) LittleRadio Winterizing, Storage, Carports & Covers 42 11-18-2007 03:59 PM
I'm a freak about research... macninja Member Introductions 4 09-15-2007 01:16 PM
Archive research~ 53flyingcloud Off Topic Forum 0 06-12-2004 04:44 PM
