Old 04-13-2006, 03:33 AM   #29
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Georgia,
I agree with Ultradog, a Bobcat is fairly easy to operate. The basics are easy to get a handle on. They are a very stable little machine. Besides we all have to learn something sometimes
Aaron
WBCCI #XXXX AIR #2495
Old 04-13-2006, 03:38 AM   #30
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Originally Posted by enduroryda
Have to add to this post that you can rent a Bobcat and get a ton of yard work done in a weekend for a fraction of it's cost...that's what we did
Yes, I have thought about this but would then need to buy and maintain additional machines to mow the lawn, rototill gardens, pickup leaves/acorns, and move the snow. I pulled together a quick rental cost analysis using sample Bobcat rental costs I found on the internet (see attachment for details). Note, the rental fees used in the spreadsheet are daily fees.
The bottom-line is if I rent, it will cost me approximately $6800 the first year for rental fees and additional machine purchases. I do plan on removing more trees/stumps over time and doing more lot leveling after I remove the trees so would need to rent the bobcat again for 4 - 8 days per year. So, that would add in approximately an additional $1000/year for rental fees.
On the other hand, let's say I purchase the tractor for $10K. My calculations show that I would see a cost savings from buying vs. renting after three years of ownership.
Name:	Tractor rental analysis.jpg
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 04-13-2006, 05:47 AM   #31
enduroryda's Avatar
1994 21' Sovereign
Down on the corner... , CT
Wow Yuki...you do have your work cut out for you. I do think a tractor is more up your alley as breaking up ledge and digging up and regrading your driveway is more than a couple of days job. Everbody has given great info here...the best part is that if you do decide to purchase...tractors hold their re-sale value pretty well. I would check in the Want Advertiser...you can find some pretty good deals in there. Good luck with your purchase...
enduroryda is offline   Reply With Quote
Old 04-13-2006, 06:24 AM   #32
yukionna's Avatar
Massachusetts
Images: 18
Thanks! One other thing I think bears mentioning -- I know when I estimate yard work projects that I haven't tackled before, I typically underestimate the task and the task ends up taking more time due to my inexperience and to unforseen circumstances (i.e., a big rock hidden 6" under the ground where you want to rototill that garden, etc.). I dread the thought of renting machinary because that means I will have to work at full tilt the whole weekend so that I can get my "money's worth" on the rental. By the time Monday rolls around, I'm stiff and sore for the next week. It is no fun at all. On the other hand, I'm smiling right now just with the thought of my own shiny (or not) tractor sitting in my barn ready to take on yard tasks at the flip of a switch! I'm actually looking forward to the yard work!!!
WBCCI Region One
Old 04-13-2006, 06:47 AM   #33
1972 25' Tradewind
Wentworth , South Dakota
From the amount of work you are talking about I think you need a tractor in the 40 hp range. for the loader and eath work you are talking about. We have a tree nursery so have many tractors and loaders around. The New Holland 40D would be a good choice it can be puchased with super steer so it is quite manuverable. Take it easy on any of these smaller tractors when using a loader. Dirt work with a loader will take its toll. I don't advise the older tractors. I have several including an 8n Ford and B JD. they were great in there day but modern tecnology is hard to beat.
Danetree is offline   Reply With Quote
Old 04-13-2006, 09:24 AM   #34
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
. . .Once I used one to clean up after I'd torn the porch off a house. . .
I had to laugh when I read this. Driving into the family room or tearing the porch off the house is the kind of thing I'm afraid I'll do WITH the Bobcat! The tutorial in the rental yard sounds like a pretty good idea for this non-mechanical gal. Thanks for the info Good luck, Yukionna. ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 04-13-2006, 09:57 AM   #35
1983 30' Airstream 300
Plantersville , Texas
need attachments
We have farmed for years and have all sizes of tractors. JD 4020 deisel. JD 530 gas (restored for tractor pulls and parades) 1510 Ford deisel, JD 50 gas, 1520 Ford deisel. Kabota trackhoe. and Gravely 52" riding mower.
We have too many , but we just can't seem to part with any of them yet.
You seem to know your needs pretty well so I will only tell you that for the most part the 1520 is our favorite. It is 2 wheel drive with hydralics set up for a front end loader. we change out the attachments from a hay fork, to a bucket, to a fork lift some of these have been fabricated here on the farm(hay fork). rear has a pto and a 3 point hitch. we have a 4 ft mower. a rototiller, a blade. post hole digger, and a scoop for the rear. we modified some old equip to plow and make rows in the garden.
Our friend has one like ours that is 4 wheel drive and a little stronger. he has a backhoe for his. ours has power steering.(NIce as we AGE)
We bought the 1510 new and the 1520 used and have gathered attachments as we needed. there are other brands that will do the same thing just try to get something that you can add too . The most important thing for us has been the pto, 3 pt hitch and the hydralics.
My husband still drives the 1520 every day even tho he is on oxygen 24/7. we just transfer his oxygen from his scooter to the tractor in a clip holder and off he goes to load scrap , mow or just inspect the farm.
our trackhoe was a big investment but, we have really used it a lot . digging up tree roots, digging holes to plant new trees at our local cemetery( everyboby was facinated by it), digging new septic lines, and many more large digging projects.
We also have a JD dozer that is under major repair now. Have had the dozer since the 60's.
Great grandson claims the trackhoe and the dozer as his so I guess there is no way to sell them. He is 14 and can operate the trackhoe really well.
I hope that you find the right tractor for your needs, Not too big or too small. One unit with lots of goodies will really do you a great job
Kay
carnegie1935 is offline   Reply With Quote
Old 05-25-2006, 06:10 AM   #36
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Well, of necessity, I have a little more useful tractor comparison shopping experience now… Yuki… have you bought anything yet? My beloved little Honda has had fuel problems and has been down and/or in the shop now awaiting parts for over two weeks. It’s the first major repairs it’s had in twenty-one years though… so I guess I can’t complain too much. It will live again, but… it’s got me looking at new tractors.
I’ve done some fairly exhaustive research into subcompact tractors in the past two weeks and thought I’d share what I’ve found. My tractor tasks are not nearly as daunting as what Yuki has planned. I mow about two acres total in two locations (trailer the tractor between), and use a snow blower for our 60’x20’ driveway and a 1/3 acre parking lot at our apartment building. I also have a dozer blade for leveling gravel and other odds and ends. I want a 3 point hitch (currently don’t have one) for convenience in using my sprayer and other attachments. I don’t use ground-engaging equipment like tillers or plows. My Honda has a heavy steel welded chassis, four wheel drive, all wheel steering, locking rear differential, live PTOs front and rear, and hydraulics front and rear. It has all of those features on a chassis not much larger than an MTD lawn tractor. I like those features and want them on my next tractor. The Honda chassis is the perfect size for the tasks I ask of it.
In looking, I settled on the 18-25hp sub-compact class tractors. You can get some of the features I want on standard lawn/garden tractors, but not all of them and what you can get are expensive options. So, the step up to the subcompact tractor class was necessary. I looked at Case IH, Club Cadet, New Holland, John Deere, and Kubota. A Case IH DX18E equipped with an 18hp 3 cyl Shibauru diesel, two-stage front mount snowblower, 54” mower deck, and 54” manual-angle blade was quoted at $14,950. The DX25E was $750 more, and they hydraulic angle blade was an additional $500 totaling $16,200. I like this tractor. It’s competent and a joy to drive.
The Cub Cadet 5254E with a diesel engine with the same attachments priced out at $16,555. What little I've been able to find on the larger Cub Cadet series by MTD hasn't been very positive; particularly in the area of getting replacement parts in a timely fashion.
I haven’t priced the New Holland series, but they are identically spec’d as the Case IH tractors, except they’re blue. I expect they’d be priced similarly. The nearest New Holland dealer is about 12 miles away and I just haven’t made it over there.
I looked at a John Deere 2305 24 hp diesel. It has a 3 cyl Yanmar diesel. It was priced out with all of the same options including the hydraulic 54” angling blade at $14,450. This tractor is clearly the best buy. I sat on the 2305, but haven’t actually driven it. It’s a high-quality tractor as well and I’m impressed with the Yanmar diesel. I don’t care as much for the way the 2305 seat feels though. The one I sat on leans back too far and has a “low-rider” feel. I may have to find another one to see if it’s just that tractor or the way they’re designed. The controls aren't as logically laid out for me as the Case IH or Kubota, but they may be JD standard. I've never been around JD much... those who farm in our family have always bought red.
Both the Case IH DXxxE series and John Deere 2305 are physically much larger tractors than my Honda and are almost too big for the areas I use them in. I went to Kubota yesterday. Although the nearest dealer is 40 miles away, and I really wanted to buy my tractor locally, I may end up with a Kubota.
The BX series is amazing. Kubota builds at least two full-featured sub-compact tractors with chassis sizes smaller than either the JD2305 or the DX series Case tractors; the BX2350 and the smaller yet BX1850. Both have 3cyl Kubota diesels, 4WD, power steering, mid and rear-mount PTOs, three point hitches standard, and hydraulics. My Honda has a 46” mower deck, and the BX1850 is available with a 48” deck which will still fit on my 54” wide trailer. The BX2350 prices out around $13,500 with the 50” snowblower, 54” mower deck, and 50” blade, but the BX1850 which has a chassis only slightly larger than my Honda was quoted at $11,900 with the 48” mower deck. The seating is comfortable, although not as nice as the Case, and the controls are logically laid out and easy to see and reach. They’re willing to bring the BX1850 out for me to try out next week, So I’ll report back.
All three have excellent financing right now…
JD is 0% for three years with 10% down; CaseIH is 0% for two years, 2.99 for three with 10% down; and Kubota is 0% for a year, 0.9% for two, and 2.99% for three years with no down. Cub Cadet had 3.99 % for 36 mos with 10% down. The CaseIH warranty is two years overall and three years power train. The JD warranty is 3 years on everything. The Cub Cadet is 2 year or 1500 hours. The Kubota warranty on the BX series is two years overall (or 1500 hours) and three years powertrain.
As much as I wanted to buy a "domestic" and buy it locally, there just isn't anything built in the chassis size I'm looking for but the Kubota... and they're signficantly less money to boot!
Roger
Old 05-25-2006, 06:55 AM   #37
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The John Deere I mentioned in my earlier post cost $22,525, delivered from Marion Tractor, brand-new. It had:
Tractor
Front end loader
Bush hog
Flail
Rear dozer blade
Small utility trailer
It is diesel, hydro drive, full hydraulics, PTO, 4x4, power steering, and sun roof.
I used it to clean up around the farm where we stored our Argosy (25 acres), and it has never failed. Zero defects, either, the only problems were self-inflicted.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 05-25-2006, 08:40 AM   #38
yukionna's Avatar
Massachusetts
Images: 18
Originally Posted by 85MH325
Well, of necessity, I have a little more useful tractor comparison shopping experience now… Yuki… have you bought anything yet? ....
Roger
No, we needed to put our tractor evaluation on hold while we deal with our New England flooding situation. Thanks for the additional evaluation information, tho. It is very helpful and on track with some of our thinking too (with regards to choosing Kubota).
WBCCI Region One
Old 05-26-2006, 01:44 PM   #39
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
this is what you need!
Yukionna- I love my ford 1520 I think its about 20 hp--3 cyl. diesel--jim
jamesardis is offline   Reply With Quote
Old 05-26-2006, 01:47 PM   #40
Looking for time
jamesardis's Avatar
1971 23' Safari
midland , Michigan
pic
forgot the pic--
Name:	new sun+air+orc 006.jpg
Old 06-26-2006, 06:00 AM   #41
85MH325's Avatar
Tipton , Iowa
Images: 37
Well, I did it. I have a Kubota BX1850 in the garage, and the Honda RT5000 sold on eBay to a very nice guy from Chicago this weekend. The Kubota ended up at $12,700 including taxes, cruise control, and another hydraulic part that was forgotten in the original quote of $11,900. That stacks up to $15k for both the Case DX25E and John Deere 2305 each with the snowblower, mower deck, dozer blade and 3pt hitch. The Case DX18E was about $750 less than the DX25E.
These tractors are really garden tractors as opposed to farm tractors, but they're really impressive for their size.
So far I've only got about four hours on the Kubota, but it's pretty amazing!
Roger
Old 06-26-2006, 07:11 AM   #42
JBK
JBK's Avatar
1986 34.5' Airstream 345
Grand Rapids , Up in the Nort' Woods of Minn.
Yuk:
A small tractor like tho ones mentioned will all do everything on your list with the exception of the stumps. Stumps take some serious power to remove and the best way is with a backhoe attachment. You would be best to have them ground out or rent a hoe to get the job done right without stressing equipment that is too small. That said, you probably can dig out a stump with a loader, but man, what a job!
Also, look into the ASV Posi-Track RC50. Now that is a unit I would give a very personal body part to have. It is made in my home town and Cat has a finger in it. The new suspensions for the cat track loaders are made ASV. A neat unit, also a good stock investment. Check them out. ASVI.com.
JB
JBK is offline   Reply With Quote
Advice needed, and perhaps a tip or two. Curtis-79MH Airstream Motorhome Forums 12 06-26-2007 01:43 PM
HELP PART NEEDED! Aluminum Termination Cap... InsideOut Waste Systems, Tanks & Totes 46 03-20-2006 06:08 AM
Fan-Tastic fan??? definition needed hex Our Community 26 10-10-2002 02:17 PM
30 Footer Advice Needed JaceBeck Our Community 13 10-04-2002 11:51 AM
Propane Tanks - New OPD Needed? montanaandy LP Gas, Piping, Tanks & Regulators 18 06-17-2002 12:11 PM
