Go Back   Airstream Forums > Airstream Community Forums > Our Community > Off Topic Forum
Old 09-14-2003, 06:25 PM   #1
yukionna
yukionna's Avatar
Profile:  Massachusetts
Images: 18
Thoughts on flat screen tv
I'm in the market for a flat screen tv for use in my Airstream because they are lightweight and don't take up as much space as a conventional tv. I plan on using the tv in the conventional manner as a tv but also want the ability to hook it up to my laptop to show DVD movies using a widescreen format. I found a 17" Samsung which not only can double as a tv and a pc monitor but it will also display a split screen for the tv and pc. Does anyone have thoughts on this model or on other flat screen models?
http://hardwarecentral.dealtime.com/...RD-85309165188
yukionna is offline   Reply With Quote
Old 09-14-2003, 06:39 PM   #2
54FlyingCloud
54FlyingCloud's Avatar
Profile:
We went window shopping for a flat panel tv at our local Good Guys, Best Buy, CompUSA and Circuit City. Of all the brands we saw the best picture quality was Sony but the Samsung was a strong 2nd.
Still haven't bought one yet. The old 15" is still working well.
54FlyingCloud is offline   Reply With Quote
Old 09-14-2003, 06:48 PM   #3
Fun-Lovin
Profile:
You could always go with one of the Mobile Video systems, they make them up to 15" I believe. These can be mounted to the ceiling and they fold up out of the way. Designed to be used in vans and suv's powered by dc.
Greg
1976 Soveriegn 31'
F250 Turbo 7.3L Diesel
WBCCI # 3516
Fun-Lovin is offline   Reply With Quote
Old 09-14-2003, 06:54 PM   #4
Tinsel Loaf
Tinsel Loaf's Avatar
Profile:
Our 15 inch flat panel Sansung is fine, but be sure to get one with a HDTV tuner. I cut off the ac adapter and run it to the 12 volt plug in our AS for power. You dont' need the 115 volt adapter because the Sansung flat panel runs on 14.5 volts DC. Ours works great with no problems and we use less battery power without the ac converter. Even when the battery power drops below 12 volts the set works just great. Just a tip.
Tinsel Loaf is offline   Reply With Quote
Old 09-14-2003, 07:00 PM   #5
74Argosy24MH
Profile:  LOST , Hawaii
I have a predecessor to that model and really like it. It has a 120 adapter but is 12v so I run it off the house battery. It also has cable and RCA inputs. The picture is good, the sound is marginal but I run it through external speakers.
John
74Argosy24MH is offline   Reply With Quote
Old 09-15-2003, 03:39 AM   #6
yukionna
yukionna's Avatar
Images: 18
Thanks for the tip! I'm actually interested in the 17" model so how do I find out how much voltage it pulls?
Old 09-15-2003, 04:37 AM   #7
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Some of the sites like Best Buy, Circuit City or J&R Music will have detailed photos of the back of the unit. The input is normally stated, 10/12/16 volt AC/DC etc.
You may have to search around but it can be found without a trip to the store
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 09-15-2003, 05:11 AM   #8
74Argosy24MH
Also check the Samsung site. Most manufacturers have pretty good spec sheets for their products.
John
Old 09-15-2003, 07:19 AM   #9
dtbw
dtbw's Avatar
Profile:  1999 34' Limited
2002 19' Bambi
Allen , Texas
We have a 17", 12V LCD unit installed
Nancy,
As a EE, I did considerable research before going my own way on the matter of a 12V TV for the Bambi. The unit I chose is actually an import from Australia (via a US distributer). The manufacturer is Cornea Systems. The unit is NATIVE 12V, has inputs for composite, DVI, S-Video and VGA, and cable/antenna. The resolution is 1280X1024, 16million colors. It has a NTSC tuner builtin. It comes with software drivers for your notebook. The unit does come with a 120V to 12V power brick, but unfortunately does not come with a 12V power cord. This was an easy fix. I just went to Radio Shack and purchased a 12V cigarette lighter cord that accepts a variety of device power input tips. By matching the tip dimensions and tip polarity with the included power brick, the appropriate tip was determined completing the 12V power cord. For mounting the unit, I wanted it NOT to sit on ANY of the limited counterspace of the Bambi, so I ordered an articulating VESA mount with a quick release. I mounted the arm at the extreme rear right area of the refrig cabinet. I did have to disconnect the propane from the refrig, remove the refrig mounting screws and slide the refrig slightly out so as to have access to the inside of the cabinet during the installation of the articulating arm (not all that difficult a job...really). The articulating VESA mount and quick release allows us to dismount the TV during travel, which we store in the original packing box placed in the shower area. When mounted, the TV is totally above the refrig counter and can be swung for viewing on the sofa or the bed as well as allowing the viewing angle to be adjusted for the best picture. The TV also includes a folding support that allows it to free stand. This is nice if you want to use it elsewhere. Other than installing the articulating arm mount, the only other modification that I think should be done is to drill a large whole from the bedside wall into the rack area above the refrig. This will allow the cords from the TV/power jack to pass thru rather than drape between the TV and the connector.
The other thing that we added to complete the "media" center was a native 12V DVD player. The unit, Blaupunkt DVD-ME1, is a really small, well designed unit. As both the DVD player and the TV handle PAL (European std) as well as NTSC (US analog std), we found that that the slightly higher resolution of using PAL was visably better, so that is how we run both units. (BTW, setting the composite input to PAL on the TV has NO affect on its reception of NTSC TV signals nor it use as a SVGA monitor) If this is of interest, I will email you how we did installation. I am picking up our Bambi mid week and I will take some detailed pics of the mount, TV and DVD player and add them to my posted pics. I forgot to mention that both the TV and the DVD come with full IR remote controls
We have been extremely pleased with the picture quality from both DVDs and OTA (over the air). Of course, OTA reception can be spotty if parked more than 50 miles or so from TV stations.
The TV can be found at
www.ecost.com/ecost/shop/detail.asp?dpno=967676.
The cost is $479.
The articulating arm can be found at http://www.lcdmonitorarm.com/lcd_arm_10.htm.
You will need one each, 835.BK ($259) and one each 899.BK ($10).
The DVD player is available at
http://www.sounddomain.com/sku/BLADVDME1
for $179.95.
david & bret
'02 Bambi LS
'99 34' Limited
President Heart of Texas Camping Unit
WBCCI # 7548
dtbw is offline   Reply With Quote
Old 09-15-2003, 02:44 PM   #10
yargseth
yargseth's Avatar
Profile:
Images: 12
Just posted to members photo installation of my sharp 20 and combo dvd vcr combo. Works great
Yargseth
yargseth is offline   Reply With Quote
Old 09-15-2003, 02:53 PM   #11
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Thoughts on a flat-screen TV....
too damn expensive!
(how's that?)
Old 09-15-2003, 03:37 PM   #12
yukionna
yukionna's Avatar
Images: 18
Thanks for your "thought", Chuck!
The good news is the prices are coming down more and more every day!
Old 09-15-2003, 03:50 PM   #13
drboyd
drboyd's Avatar
Profile:
I think flat screen TVs are wonderful....
...and I think someone should buy me one.
Or maybe two - one for the AS and one for the house.
Old 09-15-2003, 04:37 PM   #14
yukionna
yukionna's Avatar
Images: 18
Wow! What a sweet set-up you have! Check-out Yargseth's setup: http://www.airstreamphotos.com/photo...r=2915&thumb=1
Flat Panel TVs MikeF Audio, Video & TV 93 06-08-2008 05:31 PM
Installing TV, DVD, and VHS in your trailer Shelby Copeland Audio, Video & TV 73 04-08-2007 07:44 PM
Interior sliding screen panels Bill McNamara Airstream Motorhome Forums 1 05-12-2004 03:22 PM
TV Cabinet between front chairs. MacInDaBox Airstream Motorhome Forums 9 01-16-2003 11:06 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
