Old 10-02-2010, 07:07 PM   #1
x
XXXX , XXXX
This is what happens when mice chew your wiring
One of my campers came pounding on my door Thursday night at about 11:45PM. He told me to call the fire department because a trailer was on fire. I called 911 and evacuated everyone from the area and cut the power to the park. The fire trucks within 10 mins. Excellent timing for a volunteer force considering we are 5 mins away from the hall. The trailer was fully engulfed as soon as I saw it. They had it out within 15 mins but it was a total loss. The fire chief determined it was a short in the power converter most likely caused by rodents chewing through the wiring. The pictures speak for themselves. Luckily no one was in the trailer at the time and no other trailers were damaged just a neighbouring shed and some trees. I'm posting this as a warning to all to be vigilant and regularily inspect your trailer for signs of damage or infestation.
Name:	Fire Damaged Trailer 001.jpg
ID:	112186   Click image for larger version
Name:	Fire Damaged Trailer 003.jpg
Name:	Fire Damaged Trailer 004.jpg
ID:	112188   Click image for larger version
Name:	Fire Damaged Trailer 005.jpg
Name:	Fire Damaged Trailer 006.jpg
ID:	112190   Click image for larger version
Name:	Fire Damaged Trailer 007.jpg
Name:	Fire Damaged Trailer 008.jpg
ID:	112192   Click image for larger version
Name:	Fire Damaged Trailer 009.jpg
Name:	Fire Damaged Trailer 010.jpg
ID:	112194   Click image for larger version
Name:	Fire Damaged Trailer 011.jpg
wasagachris is offline   Reply With Quote
Old 10-02-2010, 07:20 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I'm gonna have to think about this a bit.
I really feel sorry for those folks.
Old 10-02-2010, 07:36 PM   #3
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Yeah.. me too. Good thing they were not home at the time.. On the other hand maybe he could have put it out. Hard to say. We all worry about this type of thing.
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 10-02-2010, 07:48 PM   #4
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Make one want to test the smoke alarms before starting trip.
Did they show the rodent chewed wires? or just sermise it?
Wish they would not use soy based oil in wire covers, rodents chewed up the sparkplug wires and vacuum lines, but you never know what else as they can do the damage in an unseen area.
Old 10-02-2010, 07:59 PM   #5
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I know for a fact that those critters can do 750 dollars worth of damage to a Ford Powerstroke electrical system overnight....plus the tow .
Old 10-02-2010, 08:07 PM   #6
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
mmm.. bio-diesel
smells like french fries
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 10-02-2010, 08:15 PM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
We have a Honda CRV which sat in the drive for a couple of weeks last year last winter without being driven. Imagine our surprise when upon opening up the glove box for a napkin, we find that most of the paper in the box had been shredded by an obvious rodent resident. How it got into the glove box (and out of the car) is still a mystery to me. Obviously I consider a car a lot tighter than my trailer.
The pictures of this fire and being caused by a rodent aren't surprising.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 10-02-2010, 08:49 PM   #8
x
XXXX , XXXX
There was evidence of a nest on top of the converter which was located just below the fridge. Both appliances created a warm spot for the mice to habitat in. There was definate evidence of the wiring being shorted out. BTW this damage was to the 12VDC wires. The smoke alarm was installed and working at the time. However this model of trailer had no emergency exit window in the bedroom. The fridge was located right across from the entry door. Sures makes you think about an alternate exit from the sleeping area once you look at the bed platform in the bedroom. The mattress frame was pulled out by the fire department. I didn't post a picture of the matress frame but it was covered in molten globs of aluminum from the roof which totally melted from the heat. The trailer owner had patio lights located about 20' away from the trailer and they all melted from the radiant heat. This is very scary that 12VDC could do all this.
Old 10-02-2010, 09:22 PM   #9
HankO's Avatar
1997 28' Excella
Eden , Utah
Just trying to get this straight my head. Mice chewed wires, trailer started on fire. Ok what happened here. I've had mice chew wires in my boat and truck and I've yet to have a fire, explain. Also were any mice killed in the destruction.
Hank
HankO is offline   Reply With Quote
Old 10-02-2010, 09:27 PM   #10
Hephzibah , Georgia
It sounds like the owner didn't have a fuse immediately after the connection from the battery. I don't know what the usual wiring diagram looks like for a 12 volt system but I imagine this trailers power converter was connected directly to the battery with no fuse in between.
If it were the AC voltage circuits that were damaged I would like to think a breaker would have tripped and kept that from happening.
I have seen a main engine harness on a garage kept 2004 F-150 stripped of almost all its insulation by a rat. Which resulted in the main 100 amp fuse blowing and causing a no start. Owner thought the battery was dead.
nti06 is offline   Reply With Quote
Old 10-02-2010, 09:42 PM   #11
x
XXXX , XXXX
Hanko was your boat or car plugged into 110VAC when the mice chewed the wires? Were the circuits live when they chewed the wires? Did the mice build a nest right on top of the spot where they chewd the wires? More than likely the nest caught fire which then spread to the cabinet and lit the fridge on fire which then ruptured the propane and then really fuelled the fire. There may have been mice killed in the destruction but in all that mess afterward no skeletal evidence could be found. Lets hope the little bast**ds were killed.
nt106 yes the ac breaker at the pole did trip and the trailer's powercord and the receptacle were undamaged by the fire.
Old 10-03-2010, 07:04 AM   #12
richinny's Avatar
2011 34' Classic
any chance the fridge started the fire? was it one of the recalled units?
Ricky
Why we don't have mice... aircooled4 Off Topic Forum 14 08-13-2010 09:47 AM
New owner of excella 500.. bit off more than I can chew? truebebeblue Repairing/Replacing Floor &/or Frame 9 02-03-2006 09:14 PM
Mice! Betsey General Repair Forum 18 08-22-2005 09:42 AM
More than we can chew???? Ambassador Ryan 1959 - 1965 Ambassador 8 09-29-2003 05:55 PM
mice wallybyam Off Topic Forum 2 01-29-2003 11:29 AM
