Go Back   Airstream Forums > Airstream Community Forums > Our Community > Off Topic Forum
Old 06-17-2006, 06:08 PM   #21
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Originally Posted by overlander63
I think (not 100% sure) the "auto" setting uses 120 volts, then reverts to LP when no shore power is available. The fridge fan is to help cool your fridge coils, and keep the overall temp a bit lower inside it, but I would say it only makes a few degree difference.
Also, a hint if you are a light sleeper like me: turn the fan off at night, as that little bitty fan can sound like a jet engine at 3 AM...
That's how mine works. So far, it's never failed. Last fall, while on the trip to Florida, I was attending a conference during the day when the AC power cut out. When I returned late that night, the reefer had switched over to gas, and the Fantastic Fan was moving air, just like they were supposed to do. Typically, during warm weather the reefer stays approx. 3 degrees cooler when the fan is running.
Regarding the fan being loud... that's the absolute truth. I have heard of people replacing them with quieter 12 volt computer fans.
SilverRanger is offline   Reply With Quote
Old 06-17-2006, 06:57 PM   #22
Tinsel Loaf's Avatar
Diesel boyHey it could be worse! If you don’t believe me check some posts from a couple of years ago. But that is what the big price tag is for. You get more for your hard earned cash than a just pleasant experience pulling right out of the lot and on your way. You get to know your dealer and you get to know your Airstream, your tolerance level and eventually you will learn how to fix your Airsteram yourself because you most likely will not find another dealer that wants to help you because you did not purchase it from them, oh one may help. Good luck. As you have read “we all feel your pain” because most of us came from where you are now. Enjoy…..Welcome to the forum.
Tinsel Loaf is offline   Reply With Quote
Old 06-17-2006, 07:52 PM   #23
Jenturnr's Avatar
2020 33' Classic
Hobe Sound , Florida
Cool
We have a new 06 Classic Limited 34' - with slide. Purchased from a very well known dealer in Florida. We had many issues with our unit - but took delivery and chose another dealer for repairs. The repairs were made at little or no cost to us. We actually drive 5 hours to our "chosen" repair dealer.
There is no excuse for non-working appliances - or any other non-working item. Keep taking it back - you have purchased the finest travel trailer made - even with the problems it may have. You could have bought something else - with bigger problems.
I believe some dealers sell Airstreams just to "sell Airstreams". We are on our 3rd Airstream and still WOULD NOT HAVE ANYTHING ELSE.
Good luck, and hope to see you on the road............
Jenni
Jenturnr is offline   Reply With Quote
Old 06-19-2006, 08:24 AM   #24
sparky5's Avatar
2004 19' International CCD
Ridgefield , Connecticut
My 2 cents are as follows:
We purchased the same trailer as yours almost 2 years ago so it is a 2004 19' Bambi CCD, but it has many of the same features, minus the solar panel.
My problems encountered were few, and I discovered many of the percieved problems were my own lack of knowledge on the how-to's of operating. For instance, it took me the longest time to figure out how to switch the fridge from AC to LP, and if anything, mine gets too cold and freezes the lettuce! The trim around the sink did peel away, but I zapped it with Krazy Glue and it's fine. The first time I used it the electric jack jammed and I had to get a local guy from an SOB dealer near my campground to replace it. I kept the broken one and returned it to my dealer in NJ on my way home, and I received a full refund from Airstream (eventually) I once accidentally overcharged my battery by leaving the unit plugged in in my driveway for too long without using it- the local guy said it over charged the battery so I did have to replace it. My aunt pulled too hard on the privacy curtain and broke the little plastic hanging gizmo, but since it was under warranty, they replaced everything, including the curtain (except they put in the wrong color curtain...I have to talk to them about that) My biggest issue is the MOEN kitchen sink faucet which leaks, and the dealer said I have to contact MOEN directly about that for the replacement (which I don't agree with) but I have yet to do that. It's on the list.
I would like to comment on dealers who do repairs even if you haven't purchased from them........I was traveling down the East coast in Feb. and discovered that my hot water heater didn't fire up. I happened to spot a dealer located right off I-95 in South Carolina http://donmar.airstream.com/ so I exited immediately and stopped in. They couldn't have been nicer and more accomodating- they took a look right away even though I didn't have an appointment. Turned out spider webs and debris were in the heating channel, so they cleaned it all out and got it going again. He also checked my tire pressure, tweeked a lighting issue, and checked a few other safety questions I had. They only charged about $20 which I thought was pretty reasonable for their time without an appointment, so I would gladly stop there again. For a woman traveling alone this is invaluable.
This is my experience so far. But I'll tell you, the small insignificant thing that annoys the heck out of me is the rust all over the light over the liscense plate. I give up on that- I'm just going to spray paint it.
I hope you get your problems resolved because it truly is a fantastic trailer!
Robin
sparky5 is offline   Reply With Quote
Old 06-19-2006, 09:09 AM   #25
2005 31' Classic
Gretna , Nebraska
Smile New trailer issues
On our 2005 31' Classic we had to go to the dealer to have the sensors calibrated for the tanks. Also had some outside trim coming loose & had to duct tape it to get home.
Our fridge will keep ice cream just fine.
Our dealer (Council Bluffs IA) never once mentioned an extended warranty, but does a nice job of helping us out.
I would say we had very few problems and a good delivery experience.
Dwight
16595 is offline   Reply With Quote
Old 06-19-2006, 10:05 AM   #26
Fort Belvoir , Virginia
Originally Posted by lewster
Hi Diesel and welcome, I feel your pain.....really! I had a bunch of issues with my 19CCD on delivery and I was so pissed at the dealaer that I took it like it was and did the repairs myself! And after calling the owner of the dealership, he said to send him a bill which he promptly paid! Being one's own RV service center does have it's advantages!
That said, you should get your dealer to address ALL of these as they are considered warranty issues. Start a file with a written and photo record of every defect and complaint. If they can not or will not resolve them, call the factory and inform them of what is happening and have them recommend another dealer. Search in these forums for comments and experiences with various dealers. You could always take it back to the factory, but that solution is often the most expensive for your time and gas and not always practical.
Good luck and keep us posted!
Lew: I noticed you live in Naples... I own a 1995 34" Limited and I am in a desperate need to find a reputable shop in Florida to due repairs caused by Hurricane Wilma. (I just returned from Iraq). They are not major... I need to replace a couple of hatches, fix or replace the A/C unit and repair or replace a corner piece in the outside... The rain caused extensive damage to the liner. I think I found the shop to get it done. I contacted couple of shops in Tampa and North of MIami but it appears not to be interested in taking the job... Appreciate your assistance.
Hugo Sanhueza
cel. 786-302-9013
hugo.sanhueza is offline   Reply With Quote
Old 06-19-2006, 10:10 AM   #27
flyfisher's Avatar
2004 30' Classic
Field and Stream , PA & MT
Dieselboy -
I feel your pain! At least it sounds like your dealer asked you to postpone your purchase until the PDI was completed.
Our dealer didn't complete the PDI at all, and didn't even tell us that until we arrived at the dealership on a Saturday morning expecting to take delivery of it (and he also told us then about a number of the other uncorrected problems with our trailer).
In our case, we had sold our used trailer to a couple from Indianapolis, who met us at the Airstream dealership in PA to take delivery of our used trailer, and my wife and I were planning to use our new Airstream shortly afterwards for the entire summer. If we didn't take delivery of the Airstream, we would have had to cancel our plans for the summer since we wouldn't have had anything to stay in.
What's with Airstream's PDI process anyway? Coming from the auto/ag/construction industry, it seems to me like they are eons behind the times in terms of enforcing their dealers to do proper PDI's on their trailers. They need to put more teeth into their PDI/dealer service processes - i.e. MONEY - Provide more financial incentives to dealers to do it right; penalize dealers (financially) who do not perform.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 06-19-2006, 03:24 PM   #28
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Your fridge will not cool when not plugged into shore power, unless you switch it over to LP, you can try this when you get the pilot igniter hooked back up, there are many threads on running the fridge while towing. Also, RV frdiges are not known for be spectacular at cooling , and there are many threads here about that, as well.
Our 2006 unit has the two way fridge and it automatically switches from ac to gas and back when there is an interuption in the ac and back when it is restored. As long as there is power in the batteries that is. It sounds like there may be an electrical issue somewhere in the coach. It could be that intermittant reading lamp or it could be in the fridge. If your dealer is convenient to your home, ask for a replacement lamp before you ask for a replacement Airstream, you are more likely to get it. If that is not the culpret have the fridge checked out. Then move to the solar charging system. One of these items could be the key to nearly half or your other problems. As for the hotwater heater fire. That one is scary but you should be grateful that the whole thing didn't go up in flames and that no one was hurt. Most of the other issues are frustrating but many are cosmetic. Not what you expect when you shell out $40K, but then again, when do you get your money's worth anymore?
I really am sorry for your problems and hope they get resolved soon and to your satisfaction. But remember, even with lemon laws, a dealer has to have tried multiple times to repair each item with no luck and it has to be documented and your state has to have a lemon law that applies to RV's and TT's. Otherwise you will have very little to stand on legally.
Old 06-19-2006, 04:33 PM   #29
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
John
I know the PDI guy from my local dealer flew up to JC to do a seminar to Airstream regarding the common issues he finds when prepping the units. I think my dealer initiated the visit.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 06-19-2006, 08:16 PM   #30
KIMILI's Avatar
2004 25' International CCD
Salem , Massachusetts
lemons can be fixed
Hi Diesel,
sorry to hear about your problems.
Unfortunately you are not alone. We come from your same background, tent campers who upgraded to an AS with no previous experience.
We bought our 25'ccd 3 years ago and suffered many..too many griefs, with our new unit. It had to be repaired 3 times within the first few weeks and still needed much fixing. Every time we drove it something else went wrong. All of this after having paid $450.00!! to the dealer for an inspection and setup!! (By the way they never refunded us that amount).
After much debate and discussion with both our dealer and Airstream, we came to the conclusion that they talked much but did not deliver. So we rolled up our sleeves and got to work!
These incredible forums were, and still are, the most valuable source of information and advise.
We are very proud to say that our Airstream is not only beautiful but it also travels smoothly and has proved to be a magnificent trailer even under bad weather conditions and rocky roads, mile after mile.
In our experience the only way to get the trailer working as it should is to look after it yourself.
So if your dreams are silver, plan a few hard working weekends into your schedule. They are worth the effort.
All the best
PS
- we had the same problems with our sensor and it still does not work right. Once you learn how the tanks work you don't really need it.
- we looked into the lemon law in our state, NJ. Consumer affairs told us that since it does not have an engine, the law does not apply.
Cheers!
KIMILI
KIMILI is offline   Reply With Quote
Old 06-19-2006, 08:19 PM   #31
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
If the dealer does not resolve your problems take it up with the factory.
They will.
Michelle TAC MT-0
Sarah, Snowball
Old 06-19-2006, 08:26 PM   #32
flyfisher's Avatar
2004 30' Classic
Originally Posted by Safari-Rick
Sorry that you've started out with such a bad experience of the Airstream.
Quick question, does Colorado have a "limon law" as does California? If so, you just have to report it to the state consumer affairs, and the dealer has to make it right with a refund or a new vehicle/trailer.
I know that i've kinda over simplified it but hopefully my point was made.
R/
Safari-rick
I found the following by doing an internet search: (some of these state laws are evolving so I don't know whether this is the present law)
Colorado's Lemon Law, C.R.S. 42-12-101, covers only new, self-propelled vehicles, including pickups and vans, but excluding motor homes and motorcycles. This law may require a manufacturer to replace or repurchase that vehicle if a defect or condition, which substantially impairs the use or market value of the vehicle, can not be corrected. If you buy a new vehicle that has a defect within one year following the purchase, and the same defect is not repaired after four or more attempts to repair, a court may order the manufacturer to replace the vehicle or refund the purchase price minus a reasonable allowance for your use of the vehicle. This also applies when the vehicle is out of service for repairs for a cumulative total of 30 or more business days during the warranty term or one year after original delivery, whichever comes first.
Flyfisher
Old 06-19-2006, 09:02 PM   #33
So sorry about your problems, like the rest. We had a convertor/invertor problem and then fire this year. Been replaced by A/S and our new dealership here in Chicago and all is well. Some of your other problems are common--superglue was our solution for the countertop problems.
So many people have already written with more information than I have.
But I have dealt with Windish (in person, three times, when shopping for a trailer) and my impression was that they were jerks.
I'd call Airstream directly... bypass Windish and see what A/S wants you to do. I think you SHOULD suggest a new trailer. But to them, not to Windish. Windish will probably never volunteer that as it makes them look like idiots to Airstream.
Tom, and Frank
Tom and Frank
Evanston, Illinois
2004 Safari 28 ft Slideout "Lucy" 4 HI CAMP
2004 Ford Excursion 6.0 PSD PWRSTRK,
and Brittany, the Nova Scotia Duck Tolling Retriever
PWRSTRK is offline   Reply With Quote
Old 06-20-2006, 03:10 PM   #34
2004 16' International CCD
Portland , Oregon
Welcome to the New Airstream Quality
Diesel Boy,
I hate to say it, but it is happening and if my experience is a guide will get much worse. The best advice I can give you is take the trailer to the deal and get out of the deal or commit yourself to rebuilding it or not using it.
I had many of the things you did, plus many more happen with my 2004 16 CCD. I would have had to live at the dealer (150miles away) in order to fix them all and since the defective parts were the problem what good is replacing one crummy part with another?
Here's some things to look forward to: The cabinet doors won't stay closed while you tow. Our cabinet fell off the wall because they are held up by 3/8" screws in lightweight wood. After a year virtually ALL the screws had pulled out. There is a seam on top of the bumper box under the molding piece. This is probably unchaulked on our trailer, the bumper box collected water and the chipboard sucked in through that unchaulked seam (you probably can't see it without taking the molding off -- chaulking between the bottom of the molding and bumper box would be the next best thing). All this saturated the insulation under the floor, caused the cheap vinyl floor to mold, until I've had to strip it down to bare bones to remediate the mold. Airstream will do nothing for me, not even send me a piece of aluminum to replace the one that corroded out because of all this water.
Also, the big area under above your spare tire is supposed to be insulated. It is 3 " spun fiberglass insulation compressed by the floor into a space of 1/4". The insulative value? Close to zero. But it did a grand job of keeping the moisture (that came with the chipboard floor) locked in so that it too molds. Also check under your step. No insulation there at all. Just aluminum covering chipboard.
Also check your wheelwells very carefully. Mine had a 1" hold communicating with the closet! The other side had about a 2x3" gap communicating with the insulated underside. This of course is a mold fest waiting to happen. It will also allow all kinds of dust, debris into the rig. There are also about 5 large holes communicating between the underspace and the living space. Then your furnace will blow all this into the living space. All very well "sealed" indeed. One whole wall of the blackwater cover had no insulation at all.
The bathdoor is probably too narrow for the hardware. The 1/32" of wood on either side will fail and the door will need replacing. Our strips around the counter and table never did stay on. There are not designed to be counters but shelf material.
Again, the bottom line, in my opinion: Save yourself while you still can. Get out of that contract and buy an older Airstream. I had seven pages of things I've fixed since June 04. Airstream will do nada. The time I did take to the dealer they didn't fix half (Eugene, OR), fixed the other half poorly and incompletely, added a dent to the underside, and took a week and $100 in gas to do so! RUN while there's still time! RUN!
Bearbolle is offline   Reply With Quote
Old 06-20-2006, 03:31 PM   #35
rebel beck's Avatar
1975 31' Sovereign
Oxford , Mississippi
Images: 35
My 2 cents
Man you folks that can go out and buy a new Airstream have more problems then some of us folks that have the hand me downs. Wish I could afford a new one but after reading this I'm proud of my 31 year old one.
I know some states have what they call a lemon law you may want to check into that. But if it was me and I know if it was my husband I would have taken it back the first time something happened and for sure would ask to speak to Larry, Curly or Mo and tell them to fix it right now no if ands or butts. And if I had to stay over they would be paying for my motel, gas and what ever else.
As far as the extended warranty I would be getting a lawyer on that.
This is a expensive item we are talking about and new things like this are not suppose to happen.
Becky
75 Sovereign (Peppy)
03 Chevy HD (lil Peppy)
Air# 9552
rebel beck is offline   Reply With Quote
Old 06-20-2006, 03:57 PM   #36
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
I'm not so sure it's "New Airstream Quality"...
Although a lot has to do with the way Airstream sends it out the door, I'd pin the majority of it on the dealer and here's why I say that. Last week we took delivery of a new 05 25' CCD. Last night was our 6th night in the new trailer and we've yet to find anything wrong and after restoring two vintage trailers, and currently in the process of doing a shell off renovation on a 54 Cruiser, I've gone over it with a fine tooth comb. But were it not for the hard work of the dealer we bought it from, there would have been gripes.
We bought from Roger Williams Airstream in Weatherford, Texas, one of only five "Airstream only" dealers in the country. They essentially have two people, David Tidmore the manager (and sometimes mechanic) and Denver the full time mechanic. They take a full week to make a trailer ready. During that week the trailer was polished, thoroughly cleaned, and every system checked and operated. They even tested the rain sensors and recalibrated the holding tank monitors. During the make ready they found that the fridge didn't light on propane, the water heater wouldn't light properly, some light bulbs were out, something was wrong that required removal of the grey water tank. When I picked the trailer up it was spotless, inside and out. They spent an hour setting up and adjusting the Hensley hitch to my truck. Then David personally took the hooked up rig on a 45 minute rigorous test drive to seat and adjust the brakes and to check for proper adjustment of the Hensley hitch. Typically he'll spend close to a day showing the customer everything there is to know about the trailer, but as I was now a fourth time Airstreamer, I asked to just go over anything specific that would be unique to that trailer. When I got home, Annie and I loaded all of the boxed stuff from the Caravel (still in the boxes) into the new trailer and headed out for several days in Jacksboro,TX at Fort Richardson State Park, then headed south to San Antonio for a few days. Thanks to the attention to detail by the dealer, it was 100% trouble free.
The best part - We bought the trailer for only a couple of thousand more than a used 04 model that we looked at and there was no charge for the dealer prep.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 06-20-2006, 04:40 PM   #37
flyfisher's Avatar
2004 30' Classic
Lucky you to have a dealer who can afford to do that!
I must respectfully disagree with you putting the blame on the dealer, however, and would put 99.9% of the blame for poor quality right on the guys' laps at Jackson Center.
Most dealers couldn't, and shouldn't have to, afford to spend as much time as your dealer did in prepping a trailer prior to its sale and delivery. Further, no one (your dealer included) can build good quality into a poorly built trailer. A lot of these trailers should never leave the factory. Your dealer might catch and correct a lot of the obvious problems, but he'll probably never detect what lies beneath the surface, waiting to come up under your bed or bath 2 or more years down the road.
I recently took the 5th factory tour at Jackson Center that I've taken during the past several years. Although there have been some obvious improvements in manufacturing there during that time, I was appalled at some of the things I saw along the assembly line. It's a miracle that you, or anyone, could ever end up with a good quality trailer built there.
John
Flyfisher
Old 06-20-2006, 06:09 PM   #38
1954 25' Cruiser
Paradise , Texas
I agree, the dealer shouldn't have to clean up after Jackson Center. I wasn't clear on the point I was trying to make. There is no excuse for the quality problems that come out of the factory. However, the dealers are in business to make money by selling Airstreams. The dealers are full aware of the quality problems. The dealers are getting paid to make the trailers ready, sometimes paid extra if they charge the prep fee. They also get paid by Airstream to correct any warranty claims, which would be anything they find wrong during make ready. Therefore, if the dealer is going to make money off the product, they need to stand behind the product and make it right as if they were Jackson Center itself because the dealer is who I, the customer, is going to come to if there are problems. If that means going the extra mile to see that things are right then that is just a cost of doing business. Meanwhile, they, the dealers, need to be putting pressure on Jackson Center to clean up their act. Truthfully, I suspect the quality issue will never change. I've owned other brands and they were just as bad if not worse and I've been through my vintage units. The things I saw behind the interior skins and under the floor showed that quality wasn't a priority in the 50s or the 60s.
Paul Mayeux
AirForums #1565
WBCCI #7162
Old 06-21-2006, 08:45 AM   #39
gowyn's Avatar
2007 27' Safari FB SE
London , ontario
Originally Posted by letsgo
If you think thats bad try the dealer in Ontario Canada.
drive safe
which dealer is that?
gowyn is offline   Reply With Quote
Old 06-21-2006, 09:16 AM   #40
Killo1's Avatar
2005 22' Safari
Santa Ana , California
Here is how I see it. Airstream and the dealer are making a "good" amount of money off me buying their trailer. As far as I'm concerned, they are both 100% responsible to make sure that trailer is PERFECT. Of course, Airstream designs and manufactures the shell and cabinetry, but for the most part that is tried and proving formula.
It is quite obvious being in manufacturing for my business that there are quality control issues along the line.
Heck, my refrigerator on my brand new trailer didn't work in 110ac. After exploring with some guidance here I found that the heating element was never installed correctly and would of never worked correctly.
Now how come AS or my dealer didn't catch that? Bad quality control.
The good news is that it wouldn't take much to correct this on the backend. Just a few time employees at AS commited to a thourough in process and final inspection.
Alan
2005 22ft Safari
2003 Chevrolet Suburban Z71 5.3l
"Life is like a box of chocolates..." Forrest Gump
Killo1 is offline   Reply With Quote
2006 International - I'm going, are you? InsideOut WBCCI Rallies & Events 88 06-15-2006 10:25 PM
Funny Church Experiences bimi Off Topic Forum 4 04-09-2006 05:43 AM
Hello hello SeanClaes Member Introductions 9 01-30-2006 06:58 PM
Airstream Homecoming Attendees Pahaska WBCCI Rallies & Events 61 09-08-2003 06:21 PM
