Old 10-17-2012, 08:14 PM   #57
2006 22' International CCD
2007 Base Camp
Elk Valley , British Columbia
Originally Posted by Protagonist View Post
The difference between illumination and visibility is also one reasn why LEDs are being used for some taillights, but not for headlights. LEDs provide excellent visibility for a long range, but only illuminate for a very short range.
They are being used for headlights. Around $600 for a pair. They are very low wattage and provide fantastic light. If you drive in the snow though, they don't make enough heat to clear the lens.
Friday is offline   Reply With Quote
Old 10-17-2012, 08:16 PM   #58
2007 Base Camp
Originally Posted by CrawfordGene View Post
Has anyone had the problem with Tundras made from 2007 on? If so, does it fog from the inside too? Is it possible to get the plastic lens off easily to clean the inside?
Gene
Nope. They are glued together. You can put them in the oven at low temp for an hour or two, then pry them apart, clean them, and put them back together.
Most people wreck at least one of them trying to do that... but, it can be done. Usually it is because people want to paint them...
eBay is a good source for cheap lenses... they might not last long, but they are cheap.
ST trailer tire speed ratings A W Warn Tires 46 05-02-2011 08:39 AM
Some insight on how things end up the way they are Boondocker WBCCI Forum 24 04-26-2011 08:06 PM
Apps/Pandora under investigation Denis4x4 Computers, Internet & Satellite 0 04-05-2011 06:41 AM
