Go Back   Airstream Forums > Airstream Community Forums > Our Community > Off Topic Forum
Old 07-22-2008, 05:57 PM   #1
bullydogsmom
bullydogsmom's Avatar
Profile:  1972 25' Tradewind
old mystic , Connecticut
Thank You VHORD!
Vernon,
The keys that you made for our airstream came today, we were able to open every thing but the outside water door, must take a different key. We found out why the battery charger ran constantly when we plugged into 110. We have NO battery in the box! Gotta put that on the "to git" list.
Thank you again for the keys. Someday maybe I can "pay it forward" to someone else.
Annette
bullydogsmom is offline   Reply With Quote
Old 07-22-2008, 06:23 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 58
Most Airstreams (except ours, of course) use the same key for all the access hatches. The water fill door takes not only a different key cut, but a completely different key. Instead of a single-sided key, it is a double-sided key. Maybe next rally, you can go door-to-door until you find one that works your lock, then run to the locksmith and get a duplicate.
Change is inevitable, except from a vending machine
AIR#2611
Old 07-23-2008, 05:32 AM   #3
bullydogsmom
Overlander63,
Our son says he drives by an AS everyday on his way to work and now it has a for sale sign on it. We have 2 grandbabies today so we are going to take a ride to look at it, and I'm going to ask if we could possible borrow the water key and take it into town and get a copy. I'll offer to leave a deposit for it. Worth a shot.
Annette
Old 07-23-2008, 05:38 AM   #4
overlander63
Images: 58
Originally Posted by bullydogsmom View Post
Overlander63,
Annette
The water filler key is different, as it has several different cuts it could be. That's why I suggested an Airstream rally, you could go to the neighbors, try the keys until one fits, and then go get it copied.
AIR#2611
Old 07-23-2008, 05:15 PM   #5
bullydogsmom
Now, I'm real new to all this AS stuff, but don't we have to get it open to fill it with water?
Annette
Old 07-23-2008, 05:20 PM   #6
overlander63
Images: 58
Annette
Yes. You could do some temporary engineering, and remove the fill hose inside the trailer, and fill it from there until you get a key. Just put the hose back on the filler so it doesn't splash all over. Ignore the dueling banjos in the background when you do this...
AIR#2611
Old 07-23-2008, 05:27 PM   #7
Gunnyusmc
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 56
Water Door
You can reach the lock from the inside. Take the nut off the back and then off too the locksmith!
Gunny
Gunnyusmc is offline   Reply With Quote
Old 07-23-2008, 06:27 PM   #8
bullydogsmom
Gunnyusmc, Fantastic! tomorrow we should have the lower wall skins off up to that point. Will report back any success.
Thanks Annette
Old 07-24-2008, 07:04 AM   #9
vhord
vhord's Avatar
Profile:  1970 27' Overlander
Crosby , Texas
Images: 95
Vernon,
Annette
You are very welcome. I am glad that they worked.
Vernon
1970 27' Overlander Restoration ("The Silver Belly", aka The SB)
Photo gallery
AIR #26858
vhord is online now   Reply With Quote
Old 07-24-2008, 10:03 AM   #10
richinny
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
look to see if there are numbers stamped into the face of the lock (very faint). if you see numbers, post them. someone should have a match to it.
Ricky & (Ingrid)
Ingrid, 99.5 y.o. and counting & Ricky, a long way from there!
give life. have you signed your donor card?
kidney & pancreas transplant 9/9/06
welcome to the collective
richinny is online now   Reply With Quote
Old 07-24-2008, 12:07 PM   #11
tphan
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
Hi- I was able to get the water-fill door key from Oasis Rv, in Tucson, Arizona. I too have a '72, and they sent the exact right key for it, first time, and it is indeed kind of a double-sided key. Give them a call, or pm me if you would like to have a key made from mine. -tim
tphan is offline   Reply With Quote
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
