Go Back   Airstream Forums > Airstream Community Forums > Our Community > Off Topic Forum
Old 12-04-2004, 10:52 PM   #1
BFZ
BFZ's Avatar
Profile:
test
test test test
BFZ is offline   Reply With Quote
Old 12-04-2004, 10:54 PM   #2
RichardT
RichardT's Avatar
Profile:
Originally Posted by BFZ
test test test
Welcome to the Forums! Your test has proven successfull!
RichardT is offline   Reply With Quote
Old 12-04-2004, 10:59 PM   #3
BFZ
BFZ's Avatar
Profile:
Question How do you determine what year trailer was built?
Thanks for the quick reply.....I have recently purchased a 31' International Soveriegn, no title and I am not sure what year it is, is there anyway of telling?
thanks, BFZ
Old 12-04-2004, 10:59 PM   #4
markdoane
Profile:  , Minnesota
Images: 59
Who? What test??
Non-contributing deadbeat.
Old 12-04-2004, 11:11 PM   #5
RichardT
RichardT's Avatar
Profile:
Tell me the Vin number and I will tell you the year, it is on the title and on the tag next to the door
Old 12-04-2004, 11:21 PM   #6
BFZ
BFZ's Avatar
Profile:
hard to read , but part of it i looks like 100276
Old 12-04-2004, 11:31 PM   #7
RichardT
RichardT's Avatar
Profile:
Make sure you are giving the number that is on the tag next to the door, you will find two sets of numbers one on the top and one on the bottom in the center, give the number on the bottom, it may read something like 0315J451 or something like that
Try this to decode yourself and post what you find or if you need help post the number
Serial numbers
Old 12-04-2004, 11:42 PM   #8
BFZ
BFZ's Avatar
Profile:
Thumbs up
This will help me tremendously, hard to see the number at 12:30 in the AM....
Another question, where are the batteries located on this model? i am usec to seeing them on the outside at the front on the tongue on most models, so far i have been unable to locate them anywhere?
BFZ
Old 12-04-2004, 11:45 PM   #9
RichardT
RichardT's Avatar
Profile:
Withought knowing the year I will guess in an exterior door on the side.
It probably has only one battery.
If it is a newer model then it will have one or two doors up front behind the tounge, a little older and it will be in the back compartment door.
If it is a 31' it is 1969 or newer for sure.
Old 12-04-2004, 11:49 PM   #10
BFZ
BFZ's Avatar
Profile:
Thumbs up
Withought knowing the year I will guess in an exterior door on the side. If it is a newer moder then it will have one ore two doors up front behind the tounge, a little older and it will be in the back compartment door.
No door s in front, one door on side at rear right, one door on left side appears to be for access to frig (which has been replaced) one large door at very rear no batteries there....when it is plugged up to power source, meter at front shows batteries in good condition.
BTW: I will try posting pictures in the next couple of days
Old 12-05-2004, 05:48 AM   #11
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
BFZ,
Sounds like a rear bath unit like mine, in which case the battery is in the drop down door at the extreme right rear of the unit. If it is a center bath; IIRC the battery door is further forward on the right side. The left side door is fridge access.
Aaron
WBCCI #2449 AIR #2495
Old 12-05-2004, 06:31 AM   #12
BFZ
BFZ's Avatar
Profile:
Thumbs up
Originally Posted by wahoonc
BFZ,
Aaron
yes it is a rear bath unit.......I will check for battery cables today...Thanks
Old 12-05-2004, 01:05 PM   #13
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
test test test
We have tested your test, and your test tested successfully. If you need to test again, or feel tested, feel free to test again.
Old 12-05-2004, 06:16 PM   #14
BFZ
BFZ's Avatar
Profile:
the serial number is I31T0J276
How To Test Holding Tanks hex Waste Systems, Tanks & Totes 1 11-19-2002 03:38 AM
Test hex Our Community 8 10-17-2002 05:20 PM
Which tow vehicle for a 19' Bambi? Jay_Iski Tow Vehicles 48 07-15-2002 02:43 PM
test
