Go Back   Airstream Forums > Airstream Community Forums > Our Community > Off Topic Forum
Old 11-07-2006, 04:27 PM   #1
rama777
Profile:  1974 31' Sovereign
jemison , Alabama
stupid question
Check these out http://cgi.ebay.com/AUTO-JACK-STAND-...QQcmdZViewItem Are these actual jacks or are they just stands for jacks?
rama777 is offline   Reply With Quote
Old 11-07-2006, 04:32 PM   #2
C Johnson
C Johnson's Avatar
Profile:  1965 17' Caravel
Portland , Oregon
Images: 326
Hi, They are jackstands. I have some just like them to put under the car when I need to work on it underneath. I personally wouldn't trust my life with .99 jackstands.
Chris AIR # 7276 WBCCI # 7276
WBCCI Forum Save Wally Forum
Photos of Project 2k5 My Blog Chris' World
My Pictures
C Johnson is offline   Reply With Quote
Old 11-07-2006, 06:45 PM   #3
dmaiden
Mom scared by aluminum
dmaiden's Avatar
Profile:  1963 22' Flying Cloud
Tempe , Arizona
Rama,
You first have to jack the vehicle up, then those adjust up or down to the height you have jacked it up to. Hope that's not clear as mud. You can't actually jack anything up with those.
Not sure I would trust those either though. Spend 6.99 at Harbor Freight.
Dave and Joanne
1963 Flying Cloud
2005 Silverado 4x4 3/4 Ton
dmaiden is offline   Reply With Quote
Old 11-07-2006, 08:30 PM   #4
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
These are adjustable jack stands. I use similar unit to work on my antique cars. You must first jack the vehicle up with a floor jack, the place the jack stands to hold the vrhicle up while you do the work on it.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 11-08-2006, 10:48 AM   #5
Goin camping
Profile:  2007 25' Safari FB SE
valencia , California
By now you know they are just jackstands.
There are items in life you should never go cheap on. Pacemakers... or ANY safty device. Do you really want the vehicles you are under to come down and squish you?
When it comes to safty please spend the money required for quality. The life and limb you save may be your own.
I've had a cheap jackstand fail. fortunately I was not under the car.
NULLUS ANXIETAS
WBCCI 6731 FCU
AIR# 13896
Goin camping is offline   Reply With Quote
Old 11-08-2006, 10:58 AM   #6
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Just wanted to add this: The cheep aluminum stands used to help stabilize your trailer in uneven campgrounds should never be used for safety devices such as under a car. They will fail very fast under the full weight of an automobile or trailer for that matter.
Don't ask me how I know. Hey, all I did was pull a set of tires off a 66 Mustang to help a friend out who needed a set for a few hours. "These look like they will work" was a stupid thing to say. 4 hours latter and with nobody around (or under) the car, it was on the rear axle on the ground. Both "stabilizers" shattered under the weight.
Buy Quality - you won't regret it.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 11-08-2006, 11:43 AM   #7
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
Post
Jack stands are for a controlled environment - indoor level concrete floors, no wind, no serious work effort exerted on lifted chassis, no other vehicle or pedestrian traffic in the area, etc. etc. I know two people who have suffocated when their vehicles shifted while they were under them. Please do not trust a jackstand for anything that will put a person under the suspended weight - ALWAYS use solid blocking to chock up good and solid before putting yourself or others at risk. Google cribbing pylons for houses or search while adding Corp of Engineers as key words to see real-deal pylons.
Go buy yourself some 6x6 or better yet some 8x8 landscaping timbers. The idea is to make at least two pylons of cribbing that are pyramid in shape. If you choose two pylons place them inbetween twin axles or just aft of single axle. The base of the pyramid should be at least as wide as it is tall so plan ahead when you cut the wood. Top cribbing pylon off with hardwood shims to take the full weight and achieve level as needed.
If the trailer is going to be raised indefinately you need to crib under the 'A' frame. Simply blocking up the tounge jack post is asking for trouble - wind or other forces can use the trailers length as leverage to twist it off its supports. I had the tongue flop off its block the first place I stored this trailer from the ground settling under the cribbing I used - Think big to spread the weight out. A 36-40" by 16-18" crib footprint I'd consider minimum under your 31' trailer toungue.
This picture shows my partner deciding where to make the dead axle graveyard - the cribbing is not as exact as I would like but what is not shown is that the second layer of 6x6 blocks are almost as long as the height of the lifted trailer frame; I was more concerned about side-to-side shifting than front-rear. I've re-railed rail cars and moved 40 tons up over and back over track to be reassemled for towing but the picture shows enough for you to get the idea. Just think it through, don't take any shortcuts when actually lifting the trailer please!
(and yes; I've named the low spot in driveway under trailer Lake Winnebago)
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Stupid human tricks, part 2 74Argosy24MH Off Topic Forum 9 12-22-2002 02:14 PM
Stupid Human Tricks airstreamcaravel General Repair Forum 12 11-20-2002 03:08 PM
My Stupid Question of the Day.-sink covers 68 Suburban Cabinets, Counter Tops & Furnishings 5 10-11-2002 09:46 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 02:51 PM
Tire sizing question caadoptees Tires 5 07-02-2002 11:19 PM
