Originally Posted by richw46
How rigid? I've seen some decorative skirts that could be rolled up for transport, would that suffice or would it have to be something like corrugated sheet metal? I don't suppose there's some easy way of skirting trailers or I'd see more of them. Maybe just too much of a pain to tote something like that around?
Perhaps I shouldn't have made that post. Those numbers were calculated estimates for a single size and weight of trailer. But even if I crunched the numbers, they're still
just estimates, and
not something you should trust your life to! As the saying goes, "Your mileage may vary;" in this case your windspeed may vary.
The
only lesson you should learn from that post is that a curve-sided Airstream will resist a stronger wind that a slab-sided box, and keeping the wind out from under your trailer will let your Airstream resist a stronger wind than if you don't. Period.
If the wind is going to be strong enough to rock your trailer uncomfortably, get out and go somewhere safer
before the wind picks up, no matter what you've done to help your trailer. If you try to increase your trailer's resistance to high winds and then foolishly get yourself injured or killed by riding out a storm you should have bugged out for, I will never forgive you.
