Old 08-13-2015, 09:57 AM   #1
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Slide out for a teardrop?
This is cool:
Gidget is the world's smallest caravan that is fully-equipped at just eight-feet long | Daily Mail Online
Then I thought, what would happen if you took say a 26 foot trailer, and created a tube within a tube - like a lipstick. Instead of a side slideout, what if you had a slide out where the length extended. You couldn't use the end caps, but you may be able to make a 26 footer go to 40 feet! Maybe you could set up 4 extra bunks to sleep another 8 people or so! table tennis in the middle... small roller rink... Maybe have both ends slide out so it's balanced on the axles with a drop down support.
The engineering is starting to give me a headache though.
robwok is offline   Reply With Quote
Old 08-13-2015, 10:19 AM   #2
1971 31' Sovereign
Christine , North Dakota
All of your appliances would have to remain in the fixed portion.
Sliding frames aren't new.
48-80 EXTENDABLE FLATBED TRAILER
The sliding portion you could add some wall mounted fold down beds similar to.
New folding "workbench" - Pirate4x4.Com : 4x4 and Off-Road Forum
Recess in some LED puck lights above the beds (or if bunks, put some into the bottom of the top one).
Or if you don't want to fuss with the hinge portion, you could use permanant hooks on the wall and then create some storage for the flat boards and removable support legs.
I'm full of ideas, a few of them may even be useful.
And none of this means you can or should create a stretch AS..
phlegm is offline   Reply With Quote
Custom handmade teardrop teardrop trailer: Airstream lovers behold! eBay Watch Airstreams on eBay 0 12-21-2013 05:30 AM
Slide-Out Won't Go In or Out AGEMMEN Limited slide out models 1 09-02-2013 06:40 PM
Slide-out no slide boondockdad General Repair Forum 0 10-05-2008 05:38 PM
Airstream's Little 2nd Cousin Teardrop Hit'nMiss Off Topic Forum 21 05-23-2005 09:34 AM
Airstream/Teardrop Morph? fornesto Our Community 12 06-04-2004 01:25 PM
