Old 11-23-2011, 01:53 PM   #1
ole-red's Avatar
2007 19' International CCD
2002 19' Bambi
2005 30' Classic
Dover , Arkansas
Question Removing aluminum paint from old Airstream
I haven't even seen this Airstream yet, so I don't know a lot about it, except it has been painted by the owner, who I have known a long time....He used an aluminum paint.....Can this be removed easily ???
Ole-Red
ole-red is offline   Reply With Quote
Old 11-23-2011, 01:57 PM   #2
Ole-Red
A proper colored paint job on an Airstream mneans that the metal was sanded.
If.........that's the case, NO it never would look correct, should you remove the paint.
Old 11-23-2011, 02:26 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
The removal will take quite a bit of work and you will have to polish it or clear coat it after that. It is going to be a lot of money or time.
Old 11-23-2011, 03:19 PM   #4
1969 27' Overlander
Albuquerque , New Mexico
Yes, it can be removed. I encountered the same problem on mine. The PO had oversprayed the front tongue area (I just thought it was dirty).
I used aircraft stripper (since I was stripping the old clear-coat anyway), and lightly used steel wool to smooth out the rough spots. Some areas will never be pretty.
Then, a LOT of buffing with several stages of buffing compound. Cheap Turtle Wax (NO SILICONE!) rubbing compound worked the best for an abrasive. Then work up in stages to finer compounds.
Takes a LOT of work, and will never be mirror smooth.
But yes, you can get paint off aluminum.
Ed Glenn
edglenn is offline   Reply With Quote
Airstream of Mississippi Overlander & Sea Commercial Listings 46 03-03-2014 08:24 PM
Bowlus Road Chief Vintage Travel Trailer, 1935. Aluminum Classic, pre airstream eBay Watch Airstreams on eBay 0 09-29-2011 07:50 PM
Airstream Pacer 1960, shorty, aluminum, antique, camper eBay Watch Airstreams on eBay 0 08-14-2011 07:30 PM
47 Vagabond Polished Aluminum Trailer Airstream Camper eBay Watch Airstreams on eBay 0 06-26-2011 12:10 PM
Hot Rod Camping Airstream Aluminum Trailer Custom Built eBay Watch Airstreams on eBay 1 06-18-2011 03:36 PM
