Old 04-19-2011, 03:36 PM   #1
1977 31' Excella 500
farmersburg , Indiana
refrigerator
Can they be charged
scottstream is offline   Reply With Quote
Old 04-19-2011, 03:45 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Greetings, scottstream, and welcome to the forums! I'm sure you'll find more information here than you'll sometimes even want!
The refrigerator in your Airstream is pretty much a standard unit in RVs: It works with ammonia. These refrigerators involve a sealed system and would only need to be recharged if somehow the ammonia leaked out, and even then you'd have to have the system repaired before the recharge. Generally speaking, since a leak often means that the system may have rusted out, your choice is to locate one of the replacement systems, or to purchase a new (and, unfortunately, expensive) refrigerator.
But are you sure that it's the ammonia system that's the problem? These refrigerators generally work either with gas (propane) or electricity (an element) to heat the ammonia at one end of the absorbtion cycle. Are you sure it's being heated (either with propane or with the element)? Before ours finally went belly up (rusted out pipes, leaking out all the ammonia), it would work only with propane, the electrical element having long since died.
Again, welcome to the forums!
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 04-19-2011, 04:35 PM   #3
Thanks for the greeting and the info I will research further on the problem. I smell ammonia. When I open the fridge door. Nothing seems rusted out but the person I bought. The airstream from said the refrigerator slowly stopped cooling . Still. Troubleshooting. A friend. Said you can turn them upside down? Anymore advice would be appreciated thanks again
Old 04-19-2011, 04:44 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Welcome to the Forums! Yes, you can turn them upside down (called "burping") to break an air lock in the cooling system (it doesn't always work, but it's worth a try as a trouble-shooting effort). However, if you smell ammonia, and the previous owner said it was slowly failing, it's no doubt leaking somewhere...and that is most likely your problem ... and "burping" will not resolve that.
Have you research the "Refrigerators" sub-forum? Here: Refrigerators - Airstream Forums
TB & Greg and Abbey Schnauzer
#3954
Old 04-19-2011, 04:48 PM   #5
Thanks I will check it out
Old 04-19-2011, 06:00 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Leak
If you smell ammonia; it has a leak. You can get new cooling units installed in your refer; cheaper than buying new. I've heard that there is a limit on how old your refer can be. Not absolutely sure though.
Old 04-19-2011, 06:17 PM   #7
lewster's Avatar
Naples, FL , Hood River, OR
Scott,
The 'refrigerant' mix in an gas/absorption (G/A) refrigerator is a mixture of ammonia, hydrogen gas, water and an anti-corrosive called sodium chromate, which is bright yellow.
If you are smelling ammonia, your cooling unit has definitely been compromised and the 'refrigerant' has leaked out of the tubing of the cooling unit. You will probably notice yellow staining around the boiler tube, which is inside the 'stack' where the electric element is located; just above the LP burner.
If the box is still in good shape and the seals on the doors are still soft, pliable and doing their job, you can usually purchase a new or reconditioned cooling unit for almost any G/A unit out there. There are also many places that will take your existing cooling unit and re-build it for you.
As a factory authorized service center for Norcold and Dometic, I am limited to replacing these failed units with new factory replacements, but you can google 'RV refrigerator or gas-absorption refrigerator cooling unit repair/replacement and a whole bunch of leads will come up.
OTOH, if your box is not in great shape, you might want to consider replacing the entire unit.
Old 04-19-2011, 06:19 PM   #8
1986 31' Sovereign
Miami , Florida
My wife and I replaced the cooling unit with a rebuilt unit in our Dometic RM 2820 in about two hours. Pretty straightforward work. That was three years ago and so far, so good.
Back then, the rebuilt cost us roughly $450.
mike
Old 04-19-2011, 07:13 PM   #9
Splitrock's Avatar
Sioux Falls , South Dakota
Can they be charged
Welcome! The refrigerator in my trailer had some rust on the bottom panel, some rust on the metal shelves, a couple broken knobs, and some stains on the inside plastic. It cooled the freezer and the refrigerator storage bay stayed at 60 degrees. My wife didn't like the old looking refrigerator. I could have liked it if it had cooled.
I removed the unit from the trailer and that was a bit of a workout. It must have weighed 200 pounds. To me a old refrigerator is a replace item like the refrigerator in the house. I quickly realized that it's the same amount of work to reinstall the old refrigerator as it is to install a new one. I bought a new Dometic RM2820 last fall. It's currently seasoning inside my shop.
Old 04-19-2011, 08:41 PM   #10
Ottawa , ON
I don't have a choice, my TT only came with a 120V unit. It works fine, but I want one to stay cool while we travel.
I've been considering the RM 2820, Splitrock. If you had the choice of models to do again, would you still go with that one? I can't really tell any difference from the specs, except for small size differences.
Old 04-19-2011, 09:23 PM   #11
Splitrock's Avatar
I think the reason I picked this one is it was the recommended replacement. The size works. I wanted a pilotless ignition, electronic control dual gas/electric power. It's on the pallet still wrapped in shipping plastic in the shop. It's gonna be mid summer or so before it gets installed. I can't recommend it . . . yet. I got it from Palomino. I can recommend them:-)
Gary
Old 04-19-2011, 09:52 PM   #12
Ottawa , ON
Yes, no pilot will be a plus, and I suppose that the electronic control should be a stable item by now. It seemed for a while like most of the refer complaints were for bad boards.
Old 04-19-2011, 10:30 PM   #13
Splitrock's Avatar
To the original poster:
Not sure if this helps. It's from my copy files.
Name:	DOMETIC REFRIGERATOR BURNER.jpg
I have a service manual for RM2612 to RM2852 in PDF if it's needed I'll post it.
Gary
Question: Can you keep the refrigerator on while towing? Scott J-24 Refrigerators 59 11-25-2015 08:53 PM
Refrigerator control cratered Pahaska General Appliance Topics 6 04-22-2011 06:59 PM
Compact Home Refrigerator or RV Refrigerator? Truebrit Refrigerators 26 04-05-2011 01:30 PM
3 refrigerator installation questions Lothlorian Refrigerators 16 03-06-2011 09:40 AM
