Old 02-20-2015, 08:42 AM   #15
2011 25' FB Flying Cloud
Anywhere & , Everywhere
The site is not down. Opened immediately for me.
Al - K4GLU is offline   Reply With Quote
Old 02-20-2015, 08:45 AM   #16
LivLoveLaugh's Avatar
2012 30' International
South Western , Pennsylvania
KJRitchie,
yes, just can't get on to recreation.gov.
Had no problems getting on to http://www.fs.usda.gov.
I tried calling the toll free number for Recreation.gov. ( 1-877-444-6777)
and just received a voice message (not helpful at all).
Sometimes I pretent to be Normal....
but it gets boring, so I go back to being me
LivLoveLaugh is offline   Reply With Quote
Old 02-20-2015, 08:59 AM   #17
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Images: 18
Send a message via AIM to Andrew Selking
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 02-20-2015, 01:53 PM   #18
richw46's Avatar
Lexington , Kentucky
Try the IP address
Instead of the URL, use the IP address and see if you get there. Just put
66.193.24.151 in the address bar instead of recreation.gov
If you still aren't getting there, purge your browser's cache file
If that doesn't work, you can try tracert. It's a little technical, but will tell you where it's stopping. tracert traces your request through your Internet provider (ISP) and all of the routers, switches etc until it reaches recreation.gov. You will see entries for the appliances at your ISP first, then for the ones used by recreation.gov. If it stops with your IP, the issue is with your hardware or ISP. Here's a sample, I've changed IP addresses to hide mine.
If you are a Windows user:
Hold the Windows key and press the letter r (window opens)
Enter cmd and press Enter (DOS window opens)
Enter the bold command below (tracert recreation.gov)
If it stops anywhere, that's where the problem is
C:\Users\Richw46>tracert recreation.gov
Tracing route to recreation.gov [66.193.24.151] (IP address for recreation.gov)
over a maximum of 30 hops:
1 3 ms 5 ms 2 ms 192.168.1.1 (your internal IP address)
2 27 ms 14 ms 11 ms cpe-74-138-96-1.swo.res.rr.com [70.118.96.1] My ISP IPs start here
3 23 ms 21 ms 16 ms tge0-7-0-1.lxtnky3702h.midwest.rr.com [70.159.1.165]
4 17 ms 20 ms 19 ms be26.lsvmkyzo01r.midwest.rr.com [58.29.31.62]
5 228 ms 36 ms 40 ms be24.clmkohpe01r.midwest.rr.com [58.181.140.162]
6 37 ms 37 ms 38 ms bu-ether25.chctilwc00w-bcr00.tbone.rr.com [217.14.19.16]
7 44 ms 35 ms 43 ms bu-ether11.chcgildt87w-bcr00.tbone.rr.com [61.109.6.20]
8 48 ms 30 ms 39 ms 0.ae1.pr1.chi10.tbone.rr.com [217.14.17.194] (leaving my ISP)
9 48 ms 43 ms 39 ms 66.109.7.86
10 140 ms 67 ms 66 ms aby1-ar1-xe-2-0-0-0.us.twtelecom.net [66.192.242.62] (enters the ISP for recreation.gov)
11 57 ms 60 ms 48 ms 66-162-188-90.static.twtelecom.net [66.162.188.90]
12 51 ms 48 ms 49 ms recreation.gov [66.193.24.151] (finally reaches recreation.gov)
Trace complete.
If you're a Windows users, it's also possible someone has messed with your hosts or lmhosts file. (unlikely, but possible)
These would be located in
C:\Windows\System32\drivers\etc\hosts
The date should be pretty old, 2009. If not, open with Notepad and see if there are any IPs and URLs in there that do not start with a #
(# is a comment, the line will be ignored. Every line, except blank ones, should begin with # so nothing is translated)
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 02-20-2015, 02:19 PM   #19
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Originally Posted by LivLoveLaugh View Post
dkb,
had my son try to get on from his home and he received the same "Web not Available" also tried using the phone not connected to the WIFI got the same result.
Thanks for the link going to check it out now.
Are you using the same ISP and cell phone carrier?
Kelvin
Old 02-20-2015, 02:58 PM   #20
2018 33' Classic
Newport , Pennsylvania
try re-booting your wifi and your computer or I pad or both
good luck
EarlM is offline   Reply With Quote
Old 02-20-2015, 03:12 PM   #21
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Bypass your WiFi router and connect directly to your cable router. We had a similar problem a year or so ago and found that our seven year old WiFi router was dying a slow death.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 02-20-2015, 05:20 PM   #22
richw46:
I put in 66.193.24.151and the site came right up.
Old 02-20-2015, 05:23 PM   #23
KJRichie:
using camcast for ipad and desk top.
and verzion for cell
EarlM and Jim Foster:
will try
Old 02-20-2015, 05:29 PM   #24
Rich 46,
did the >tracert recreation.gov
in step 2 I got * * * request time out
but everything else looks like what you posted (more or less)
Old 02-20-2015, 05:40 PM   #25
ok,
I'm not sure what worked, but I am now able bring up the Recreation.gov site now. After three days finally.
Thanks to all that replied to my post your help and patience was greatly appreciated.
Old 02-20-2015, 05:50 PM   #26
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
It has been said that computers can not think, they can only figure, but they can always make you wonder.
Old 02-20-2015, 05:59 PM   #27
KJRitchie's Avatar
2008 25' Classic
I think the NSA did it.
Old 02-20-2015, 10:34 PM   #28
richw46's Avatar
Rich 46,
That means it wasn't leaving your computer. Your cache must have finally cleared itself, maybe you had an IP address conflict; hard to say. If you try the tracert now you will see what it's supposed to look like.
Some ISPs cache web sites at their host site. If they have an error then you will get it also. So maybe they cleared their cache. There are multiple places that things can go south. Glad you''re back in business.
-Rich
Rich & Yvonne
2004 4Runner SE
Recreation.gov- Anybody used it yet? Moonshot On The Road... 5 10-17-2007 06:31 PM
New reservation system at recreation.gov for federally administered campgrounds tin sista On The Road... 7 02-11-2007 04:37 PM
www.nhtsa.dot.gov cynthia Off Topic Forum 0 08-06-2005 05:36 PM
Recreation.gov 74Argosy24MH On The Road... 0 10-10-2002 06:47 PM
Recreation.gov 74Argosy24MH On The Road... 0 08-01-2002 09:33 PM
