Old 03-21-2011, 01:51 PM   #463
Carmilla's Avatar
Two Rivers , Alaska
T-Shirt Quilts
I will try and find time to take pictures of mine I made from my high school and college rowing t-shirts. I did one double sided- with identical layouts on each side. The really funny thing is, there's a layout mistake on each side that happened to match up, so it looks like it's done on purpose. I have to say the only hard thing about a t-shirt quilt is designing the layout- no two logos are the same size. That, and get yourself a really good iron on stabilizer to fuse to the knit so it doesn't stretch when you sew!!
Carmilla is offline   Reply With Quote
Old 03-21-2011, 02:34 PM   #464
1980 20' Caravelle
Coeur d alene , Idaho
Carmilla, you are 100% right about designing the layout. I spent many hours changing locations of the squares and limiting the colors. I used Pellon #911FF for the interfacing. Would love to see pictures of yours--Both sides!!!! Royce, I only used around 50 shirts so have more then that didn't make the cut. Many shirts just did not have a good color or design so still have some paint rags. Should have some more pictures next week. Don
glacierrunne is offline   Reply With Quote
Old 03-25-2011, 07:25 AM   #465
Richland , Michigan
Alumapalooza?
Is anyone in this group planning to attend Alumapalooza this year?
lmgreenfield is offline   Reply With Quote
Old 03-25-2011, 07:09 PM   #466
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
Sorry, no. Reports of it on this forum always make it seem fun. If you go, enjoy! Due to health issues with our eldest son, we no longer make "plans" which often need to be canceled last minute. Instead, we take trips when a window of good health opportunity shows itself. Our only plans currently are to spend two weeks in Grand Marais, MN, first two weeks of July. I hope to piece quilt blocks outside on the picnic table overlooking the harbor on Lake Superior. ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 03-25-2011, 07:25 PM   #467
mcair's Avatar
1988 29' Excella
Collinsville , Illinois
I am going to Alumapalooza.
mcair is offline   Reply With Quote
Old 03-26-2011, 06:52 AM   #468
Richland , Michigan
Alumapalooza?
McAir - perhaps we can meet up? My husband and I will be attending for the first time this year. I will, of course, be taking some quilting . Maxandgeorgia - it sounds as though you've found the way to cope with your need to be present for your son and your desire for travel. Good for you!
Old 03-26-2011, 08:44 AM   #469
Diego's Avatar
2018 28' Flying Cloud
Westfield , Indiana
Don and I are looking forward to it. We attended last year and had a blast. I will be commuting Tues. - Thurs. as we have had days added to the end of the school year because of the snow days we've had this year. I teach 6th grade Language Arts (used to just be called English). But I'll be there full time Thurs. afternoon - Sunday. PLEASE introduce yourself if you spot our Minuet. The Argosys are easy to spot among the silver.
Take Care,
Lana
Diego is offline   Reply With Quote
Old 03-26-2011, 08:45 AM   #470
2012 25' FB International
Evanston , Illinois
I am also going to Alumapalooza. I haven't been posting to this thread recently because I have been dealing with a hip revision and am just now getting back to normal. I even started quilting again!
Last year at Alumapalooza, several quilters found each other and had a great time chatting and sharing pictures and quilts. It would be easy to make an announcement for a time to get together to meet each other. What fun.
All the best,
Caryl
Caryl is offline   Reply With Quote
Old 03-26-2011, 09:51 AM   #471
mcair's Avatar
1988 29' Excella
I count 4 of us so far at Alumapalooza. Shouldn't be too hard to meet up. We will be on the road about 12 days total. I haven't even thought about what I might bring other than knitting. Will we have enough AC to run sewing machines? I am expecting this a boondock event and don't know how much electric we really get.
Old 03-26-2011, 10:08 AM   #472
Evanston , Illinois
I just copied this from the Alumapalooza FAQ site. I doubt if sewing machines will work with 3-amp power unless they work on 12 volts, but an electrical expert should answer this one:
Q: What utilities will I get on-site?
A: Alumapalooza 2011 will offer 3-amp AC power, and access to water and dump station. If you wish to hook up to water, bring 100 feet of water hose and a Y-connector. Trailers will be “daisy chained” to a central water supply.
Q: Can I get 30-amp electric to run my air conditioner?
A: Sorry, no, but you can elect to park in the generator section and provide your own power. Be sure to check the “Generator section” option when you register. Note that generator sites will not have electrical connections supplied, so if you park in those spaces, you’re on your own for power.
Q: What’s the 3-amp power hookup good for?
A: It’s for keeping your battery charged. Use only 12-volt lights and appliances, and you’ll be fine. Fridges should be on “propane” setting during the event.
Old 03-27-2011, 01:28 PM   #473
1995 30' Limited
Ashland , Missouri
Diego-Lana, I wish we could attend since it sounds like you'll have a quilters' gathering. I'd especially like to see your Argosy. We have a '78 Minuet partially disassembled (interior) in our barn. We've begun putting down a laminate stone-look floor and I'm torn between redoing uphostery and keeping the side couch and the front dinette or replacing the dinette with another couch. Putting up and taking down the dinette daily is not something we'd enjoy, I fear. Would you believe I've been all winter mulling over this without reaching a decision yet? What arrangement do you have inside in your Argosy? Btw, I see you're a LA teacher. Until retirement four years ago, I taught middle school 8th grade LA. Loved it then, but oh! I'm glad to be home sewing and quilting more now All of you, have fun at the "palooza!" ~G
maxandgeorgia
WDCU
Old 03-28-2011, 07:07 AM   #474
1973 Argosy 26
Fort Payne , Alabama
Grandbaby's small quilt I hand quilted this week. She is almost 2 & loved the bright colors. Would love to see what you all are working on this week. We will be installing the new converter on the Argosy this week.
bbnaugher is offline   Reply With Quote
Old 03-28-2011, 06:43 PM   #475
Diego's Avatar
Westfield , Indiana
Max and Georgia,
Yes, last year at "palooza" I met Caryl, who posts here and another quilter (don't know if she is on the forum or not). It was fun to meet and make so many new friends.
Don just put a new floor in our Minuet last weekend. It's a plastic or rubber like floor, called Allure by Home Depot that looks like hand scraped wood planks, but totally impervious to water. Sounds cheap looking, but it's not at all - I love the way it looks. There is some flex to our floor, so Don's not sure how the planks will hold together, so only time will tell with that.
I spent the weekend working on the cushions (I posted a pic of the material here earlier) and that is still a work in progress, but they're coming along. We are going to try using the gaucho for our bed instead of the dinette and see how that works. Pushing it back against the wall during the day and throwing the comforter over it doesn't seem like it will be a big thing.
Wow, we'll have to get together and talk teacher talk! I am very close to retiring. So tempting to let it all go and be able to sew all I want. It won't be long. Tough decision to know when to retire these days.
Good luck on your Minuet. Hope to see you down the road when you are able to get away.
Lana
Old 03-29-2011, 07:10 AM   #476
Jezibels's Avatar
1966 24' Tradewind
Chicago , Illinois
BBNaugher - Fabulous Quilt I really love the bright colors!
Happy Trails!
Jezibels is offline   Reply With Quote
quilting
New to Airstreams mike001 General Repair Forum 36 06-12-2011 06:22 PM
Why are Airstreams better? tschamp Our Community 20 07-06-2010 04:40 PM
Where 'O where are the airstreams at.... till Our Community 3 02-09-2004 05:31 PM
Where were all the Airstreams? sjptak Our Community 18 06-21-2003 11:42 PM
Where are Airstreams Jenturnr Airstream Motorhome Forums 4 06-17-2003 12:44 PM
