Old 09-13-2018, 04:35 PM   #1
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Problems could be worse.
This poor family of full timers are having a hard time dealing with Heartland RV.
That only has a 1 year warranty.
https://4radicalroadschoolersandafat...t-us-homeless/
GMFL is online now   Reply With Quote
Old 09-13-2018, 05:04 PM   #2
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
After reading this account I guess having a screw come loose on my AS from time to time is not that big of an issue. So sad!
Who owns Heartland?
Old 09-13-2018, 05:11 PM   #3
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
I’ll give you one guess........
Heartland RVs is an American manufacturer of recreational vehicles located in Elkhart, Indiana and a subsidiary of Thor Industries.
Old 09-13-2018, 05:27 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Something there does not sound right. Looks like that thing was dropped or something...
AtomicNo13 is online now   Reply With Quote
Old 09-13-2018, 05:28 PM   #5
UncleBad's Avatar
2018 28' Tommy Bahama
Oro Valley , Arizona
So who makes the frames in our Airstreams?
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Old 09-13-2018, 06:25 PM   #6
2017 23' International
hendersonville , North Carolina
Frame Failure
Looks like a Total loss. Couple of questions come to mind. Were you within weights limits for the axle rating? Cat Scale ticket would be handy to have to prove to manufacturer that unit was not overloaded. How much tire pressure? How much weight transfer back to the trailer from WD hitch? Your pictured tow vehicle has a pretty stiff rear axle suspension. Was it to stiff and helped overstress the frame? You stated that you had a crack fixed early on in trailers life. After repair did you Cat Scale loaded rig to make sure within all stated limits? When something fails to this degree there is usually a reason. If all weights were within specs, and you can prove that, and on one of the rough roads you said you had experienced a one time hit in a large pothole started the ball rolling for the frame failure, you may have a case. In any case, most, if not all manufacturers, state in there literature that the unit is not intended for full time living. Yes, that is the lawyers speaking, but that is the way it is. Hope you find a suitable replacement as I doubt your Heartland can be fixed.
uraljohn is online now   Reply With Quote
Old 09-15-2018, 02:17 PM   #7
r carl's Avatar
Lin , Ne
Looks as if that camper was airborne and landed hard.
Old 09-15-2018, 09:16 PM   #8
2007 22' International CCD
And was a bit sideways when it landed based on the bend in the axle mounting plate. Not encouraging. I canít prove overloaded, but thatís the way Iíd bet.
rmkrum is online now   Reply With Quote
Old 09-15-2018, 11:09 PM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Not buying their story.
Hi, sorry to hear about this poor trailer, but I wouldn't touch it. "A few pot holes"????? Were the pot holes three feet deep? My opinion is that this trailer was severely abused. If someone could show me at least ten more exactly like this, you will never convince me that the worst made trailer in the World would just fall apart like this one. I would like to see these people's next trailer after 3.5 years of use.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-16-2018, 05:45 AM   #10
2013 20' Flying Cloud
Westerly , Rhode Island
Lots of people are eager to believe every sob story about some poor innocent victim wronged by an evil corporation and others are willing to take advantage of that fact when telling their side of a story. Sounds to me like Heartland probably diagnosed the problem accurately. Not sure how else that corner piece could possible get bent up and forward unless they backed into a tree limb or other overhanging object. That would also push the trailer down, bend the running grear and start the whole process of falling apart.
smithcreek is offline   Reply With Quote
It could be worse. Isuzusweet Classic Motorhomes 3 01-15-2016 12:36 PM
It could have been worse.......... Robbie R. Off Topic Forum 15 12-10-2009 10:16 AM
Problems Problems Problems pjude General Motorhome Topics 6 09-03-2007 07:25 AM
If you think it is bad, it is probably worse j54mark General Repair Forum 5 09-27-2003 05:54 PM
Fleas and worse cjholloway The Pet Forum 4 08-09-2003 05:39 PM
