Old 02-20-2014, 07:21 AM   #1
2014 16' Sport
Route 66 , Arizona
preventing wasp nests underneath
It'll be our first spring/summer with the Bambi. Yesterday while checking spare tire underneath I noticed tiny gaps in the enclosed underbelly. My fear is wasps can get in and build enormous nests without getting noticed. And once there, how the heck would ya get 'em out?
Need to do a more thorough check, perhaps they can all be sealed with duct tape. Interested in hearing whatever solutions and/or preventive measures that have worked for you guys.
Skooter is offline   Reply With Quote
Old 02-20-2014, 07:35 AM   #2
dznf0g's Avatar
Oswego , Illinois
I went under the AS a couple years ago and sealed small openings with Sikaflex sealer. I also used stainless steel pot scrubbers to plug the frame ends. I think duct tape will only last awhile and is a mess to try and re-tape after it has degraded.
-Rich-
Old 02-20-2014, 09:46 AM   #3
Lily&Me's Avatar
Normal , Illinois
We had years ago wasps in the propane intake for the generator.
After that mess was roto-rootered out, doug put mesh screening on there, which has worked great.
Maggie
Old 02-20-2014, 09:51 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Maggie
Screen mesh to keep out wasps needs to be #4 mesh at the largest (4 wires to the inch), with #5 or #6 (5 or 6 wires to the inch) being better.
For a furnace or other LP exhaust, a dome-shaped screen is required. You need to keep the same or larger equivalent opening size to the original exhaust. A flat screen obstructs part of the exhaust area because of the wires filling some of the exhaust surface area. A dome shape has a larger surface area, to make up for part of that surface being wire.
But for openings where you don't have combustion happening, a flat mesh— or as dznf0g suggested, steel wool— should do the trick nicely.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-20-2014, 09:56 AM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Metal foil tape (actual adhesive backed foil) is very durable. I have used this for temporary patches on semi trailers that lasted for several years, and were still working great when removed for trailer repair and paint.
Available at Lowes and Home Depot for about $12 for a 55 yard roll.
Old 02-20-2014, 09:56 AM   #6
dznf0g's Avatar
Oswego , Illinois
regular steel wool rusts and doesn't like aluminum (you Interstate folks may not have as big an issue). Stainless wool (or scrubbers) are best IMO.
-Rich-
Old 02-20-2014, 12:33 PM   #7
richw46's Avatar
Lexington , Kentucky
How about putting eucalyptus leaves in these areas. Would that discourage them? You'd have to remember to take them out of the furnace area in the fall and replace everything in the spring again.
richw46 is offline   Reply With Quote
Old 02-20-2014, 07:32 PM   #8
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Brass wool works as well and I think I got it on Amazon.
Floor -underneath a Great Surprise mocus Repairing/Replacing Floor &/or Frame 6 11-09-2013 03:03 PM
'69 caravel - front subfloor rot with a swimming pool underneath! Modern South Repairing/Replacing Floor &/or Frame 3 02-26-2013 03:34 PM
Rats and Mice and Bees, "OH MY" NorCal Bambi General Repair Forum 34 08-26-2012 06:50 PM
'79 Sovereign rear bath dripping water underneath!! al franklin Sinks, Showers & Toilets 9 08-03-2011 04:07 PM
