Go Back   Airstream Forums > Airstream Community Forums > Our Community > Off Topic Forum
Old 03-26-2003, 11:24 PM   #1
FrankR
Profile:
Posting reply to another post
I have just lost 3 attempts to post reply to another post. I also posted a jpg. What goes?? Can I not post images? It is very discouraging to spend the time and energy and loose all the info. The image was just 600kb and a jpg......
I also tried to just post the image and all was lost......... This is not good for me. You may notice my posts are long and complete...... Frank
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 03-27-2003, 06:04 AM   #2
BobbyW
BobbyW's Avatar
Profile:  1965 20' Globetrotter
Houston , Texas
102400 bytes or 102 kbytes is the limit on a Attached file. Your 600 kbyte file is just to big. I used to lose posts also in the early days of the Forums until I figured this out. It would be nice if the software would warn you if an attachment was to big, but it does not until you hit "Submit Reply". Then it "punishes" you by clearing the text box instead of returning you to the editor with the text intact to try again.
This is a limitation of the software. I use a Photo Editor to resize my pictures before I attach them.
-BobbyW
-BobbyW AIR# 123
-Guess what? I got a fever! And the only prescription.. is more cowbell!
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."
-Red Green
www.bobbywright.com/gallery
BobbyW is offline   Reply With Quote
Old 03-27-2003, 07:19 AM   #3
PatCrusse
PatCrusse's Avatar
Profile:
There is an easy way to solve this problem.
I have gotten in the habbit of highlighting my post, right clicking, and clicking on "copy" before I hit the "Submit" button. If something goes wrong with the post, I can hit the back button, right click, and hit "paste" so that I don't have to rewrite the entire post.
You could also use a program such as "Word" to type you post and the copy and paste it.
It's a pretty straight forward process.
Patrick
Patrick Crusse
'74 Tradewind 25', Rear Bath - Center Twin, Mostly Original except wood floors.
Tow Vehicle: '99 Dodge Ram 2500 w/ Cummins Diesel, Auto Trans. Tows great even without equilizer hitch.
PatCrusse is offline   Reply With Quote
Old 03-27-2003, 07:31 PM   #4
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
i like that cut and paste. thnx
al
wb13798 is offline   Reply With Quote
Old 03-27-2003, 09:18 PM   #5
striker
striker's Avatar
Profile:
Images: 14
Thumbs up thanks pat
thank you for the tip pat i have been having probs. lately also.
will try the copy and past next time.
striker is offline   Reply With Quote
Old 03-27-2003, 10:16 PM   #6
FrankR
Profile:
Image posting difficulties
Thank you Pat. I have just tried and used the copy and paste trick. My wife suggested I write all post in word and also copy and paste. I foolishly thot that a 6ookb image would be OK. I'm now using images about 450. These images will work. I die loose several very informative posts. Maybe they were of no value....... Thanks again, Frank
Old 03-29-2003, 09:49 AM   #7
Photobitstream
Photobitstream's Avatar
Profile:
Don't feel bad, Frank. I see this question all the time on a photography forum I help moderate. You'd think photographers would be able to figure it out on their own
As a courtesy to those of us on antiquated dialup connections, please keep your photos as small as posssible. Resize them to 640x480 or thereabouts, then save as a JPEG using level 5 compression as a starting point, and try to get the file down to 50kb to 60kb.
It is very frustrating trying to open a thread with a 100kb or larger file attached. It is even more frutrating when more than one person uploads a large file. I've had to wait five minutes for a single page to open at times.
Photobitstream is offline   Reply With Quote
Thread ID # from Post ID # jaco Forum How-To's & Support 2 02-06-2004 12:24 AM
Trouble posting replies HP9K Forum How-To's & Support 2 01-31-2004 11:47 AM
