Old 02-15-2008, 11:46 AM   #1
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
Question Portable, Battery Powered AC
Anyone own / try one of these? If so, what do you think of it?
Cabela's -- 02 Cool Box&#8482 Portable/Rechargeable Air Conditioner
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 02-15-2008, 11:52 AM   #2
Sounds great.
But, where will you get all the ice?
Since it's also apparently a "mister," it will quickly cause a "musty" smell in the trailer, and/or mold.
Old 02-15-2008, 11:54 AM   #3
N2XBW's Avatar
BRADENTON, On The Picturesque and Sunny West Coast of Florida, , USA, PLANET EARTH, MILKY WAY, LOCAL GROUP, SPIRALING SLOWLY THROUGH THE UNIVERSE
I haven't tried it but it sure LOOKS interesting for the price. [Thank You China]
Just keep in mind that as with any AC, it will have to have a vent to the outside. The heat has to go somewhere!
John / N2XBW
These aren't the droids you're looking for.
You can go about your business.
Move along.
N2XBW is offline   Reply With Quote
Old 02-15-2008, 11:59 AM   #4
myboyburt's Avatar
1993 25' Excella
Images: 12
Sounds great.
No worries,
We always bring a ton of ice.
Using the mister is an option, from what I have read about this machine.
We have a brand new AC unit on our rig, I'm only interested in this machine for boondocking in really hot weather as our generator isn't big enough to run our AC.
Michelle & Leon
New England Unit
Old 02-15-2008, 12:37 PM   #5
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
I think it is an ICE maker with a fan. To rid itself of the melt water it uses it as a evaporative swamp cooler.
But this is all speculative.
It would be great if it works!
Michael
ArtStream is offline   Reply With Quote
Old 02-15-2008, 12:37 PM   #6
Central , Mississippi
...We always bring a ton of ice....
No need for a ton,
27 lbs per hour for the equivalent of a 5000 BTU window unit
(I might of messed that up but it's close )
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-15-2008, 12:48 PM   #7
myboyburt's Avatar
1993 25' Excella
Images: 12
[quote=HiHoAgRV][quote=myboyburt]...We always bring a ton of ice....
No need for a ton,
Too funny!
Anyway, I just placed an order with Cabelas for this unit. We will use it this summer when we boondock and I will report back on it's value (or lack of).
What I'm hoping it will do is reduce the warmth in the bedroom area (twins layout, back of rig) as we can close this section off from the rest of the trailer. I'm thinking we would only use it during breezeless, muggy nights.
Michelle & Leon
New England Unit
Old 02-15-2008, 01:38 PM   #8
1966 26' Overlander
Prosser , Washington
Have used.
I used this unit in a tent trailer.
My direct description: Fancy humidifier. It uses ice instead of water. Or you can just put water in there. They also make these in a tall standup electric model. It is like a swamp cooler.
It will cool a small space, worked ok in the tent trailer.
NWOverlander is offline   Reply With Quote
Old 02-15-2008, 01:46 PM   #9
myboyburt's Avatar
1993 25' Excella
Images: 12
Thanks!
This gives me hope that it will work in the bedroom area of our trailer. I'm not expecting the same results as our using our roof top AC, I just want to be able to cool down the space enough to be able to fall asleep.
Michelle & Leon
New England Unit
Old 02-15-2008, 01:54 PM   #10
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
We use a 1957 swamp cooler in our FC. It works reasonably well. We've only used it where it's been very hot and very dry so moisture in the air was actually a blessing. It's 12v so works pretty much anywhere.
I have nothing but positive things to say about it.
I do make sure it is cleaned and dry before storing it so that mold is not an issue.
I like the look of this one and it appears to be a bit smaller than ours. For the price I may have to order one to compare.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 02-15-2008, 02:41 PM   #11
1966 26' Overlander
Taller Version
This is the one we got for our bedroom at home when the a/c went down on us last year. It worked great. If you are hook up to power, this will work great.
Same principle as the one at cabela's, just larger.
CV-600 Super Cool Evaporative Cooler - SPECIAL SHIPPING PRICE
Old 02-15-2008, 03:19 PM   #12
myboyburt's Avatar
1993 25' Excella
Images: 12
Very interesting, and it claims to use about the same power as a 60 watt light bulb so it could be plugged right into our onboard inverter and run off our batteries.
Michelle & Leon
New England Unit
Old 02-15-2008, 04:20 PM   #13
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Probably will work great in very low humidity areas, like Arizona. In Arkansas, however, or anywhere it gets to 100 degrees and 95% humidity, it will just make you sticky is my bet.
Good luck, though.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Diesel Powered Trailer SmokelessJoe LP Gas, Piping, Tanks & Regulators 95 07-09-2011 09:13 PM
Propane Powered EU2000i Pick Generators & Solar Power 35 05-04-2010 03:21 PM
Powered Trailer Dollies... GolfStream Tow Vehicles 18 03-05-2008 04:09 PM
Powered vents Roadtoaster Roof Vents, Skylights & Fans 4 05-15-2006 12:03 PM
'94-34' Cummings powered MH Tarheel General Motorhome Topics 1 06-10-2004 06:26 PM
