Old 01-26-2016, 08:10 AM   #1
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Pictures Posting Sideways
Good Morning,
Does anyone have advice on how to get pictures to post right side up in the Classifieds section? I have posted my Airstream for sale and am not able to get the pictures to post right side up.
Any input is appreciated.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 01-26-2016, 08:32 AM   #2
Bruce B's Avatar
2012 16' International
Jamestown , Rhode Island
It seems to be kind of random... It just happened to a picture I posted in the "Best Portable Grill" thread...
Ask a moderator? I know they are installing some new features/software to the site. It is probably a result of this.
BB
Bruce B is offline   Reply With Quote
Old 01-26-2016, 08:35 AM   #3
in the rising sun toaster
1956 26' Cruiser/Overlander
Wimberley , Texas
Rotate them first, save each in their correct position, then upload these newly saved images. There are many image editors available that rotate, some are free or nearly so, e.g. IrfanView, Photoshop Express. Some already-on-board apps for iOS or Android devices have editing features, among them the rotation tool you need, and also a cropping tool, and brightener/sharpener/etc/etc. Going forward, you may also want to always hold your camera so that no rotation corrections will ever be needed.
rsjmcg is offline   Reply With Quote
Old 01-26-2016, 08:42 AM   #4
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Make sure to reduce the size of your photos to 1 megabyte or less. Then they will post as you see them on your computer.
tsunami is offline   Reply With Quote
Old 01-26-2016, 09:18 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are using an Apple product and sending the pictures from it that may e the problem. For some unexplained reason this is a known problem when using Apple.
2004 Excursion 4x4
Old 01-26-2016, 12:33 PM   #6
Wimberley , Texas
Some details: If OP or anyone interested is using an iOS device e.g. iPhones, iPod Touches, iPads then the recommended solution is always take photos with the Home button at bottom/down, especially if taking photos that will be be sent/shared to a non-iOS site, like this forum, or if to be sent by e.g. email to a non-iOS device. iOS devices are quite accurate at correctly determining which way is "up" no matter how actually held in the hands, so these devices will display all photos correctly (i.e. up is always up) even though the actual saved photo is in any one of the other three possible orientations: Home at left, Home at right, Home at top. Try this yourself if you have an iOS device...take the same photo 4 times but rotate your device 90 degrees before each. All 4 will display on your device correctly, i.e. up remains up in all four photos despite that you sequentially rotated the camera device 90 degrees before taking each photo. Now, Email these 4 photos to yourself and, using a non-iOS device e.g. a Windows computer, see that each of the 4 photos was actually saved by your iOS device in *each* of those 4 different/sequential orientations you changed to when you took them. So, Unless you just want/like to use a rotating-image-editing tool (and these are very handy), keep that Home button at the bottom when taking to-be-shared photos and you'll avoid ever posting photos that appear wrong, i.e. sideways or upsidedown, once they've been posted.
Old 01-26-2016, 02:14 PM   #7
NWGetaways's Avatar
2012 22' FB Sport
2003 19' Bambi
Port Townsend , Washington
This quote is from Windows XP, don't know if it's handled any better on later releases:
Some camera manufacturers set the JPEG EXIF Orientation flag based on an orientation sensor built into the camera. This image attribute is currently not supported by Windows Explorer or the imaging applications that ship with Windows.
Where it says "some" that should read "all", including all smart phones.
https://en.wikipedia.org/wiki/Exchan...ge_file_format
Bottom line: it's not Apple or iOS that's messing up, it's the forum software.
If you have an image editing program you can usually force the orientation by rotating the image there and re-saving it.
NWGetaways is offline   Reply With Quote
Old 01-26-2016, 02:15 PM   #8
Lily&Me's Avatar
Normal , Illinois
Reducing the size of the photo works every time for me, posting from my IPad.
Maggie
Old 01-26-2016, 02:17 PM   #9
NWGetaways's Avatar
2012 22' FB Sport
2003 19' Bambi
^ and that's because your image editing software re-saved the photo in the "correct" orientation.
moving a 34' trailer sideways BradS General Repair Forum 60 03-07-2012 12:10 AM
A/C leak only with sideways rain Bowmans Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 10-07-2011 11:47 AM
Proposing a 19' Bambi floorplan -- sideways bed CanoeStream 2005 and newer - Bambi all models 42 03-20-2007 08:13 AM
Posting pictures of 68 Safari niss1679 Forum Admin, News and Member Account Info 5 09-15-2006 10:00 PM
sideways toilet bowl? lesliedow Sinks, Showers & Toilets 3 08-22-2005 10:28 AM
