Old 02-24-2010, 05:42 PM   #1
2011 27' FB Flying Cloud
Bradenton and Saluda , Florida & North Carolina
Pee UUUU
Hi All, couldn't think of a better place to ask this question. We recently purchased a pantry cabinet (1950's or so) that we brought home and immediately opened it to begin cleaning and the smell was awful. A chemical, oil type smell. It is completely painted off white inside. Immediately, obsessive compusive here, I started removing shelves and got out the Kilz. Painted two layers of paint and put it back together.
Well, it still stinks! How do you get odors out of a wood cabinet? There is no obvious signs of puddles of anything inside, it just smells like an old oil furnace. We really need to use this cabinet, and the antique dealer has a "no return/exchange" policy. Help!!! Need to use the cabinet!
Nancy
ncbambi is offline   Reply With Quote
Old 02-24-2010, 05:48 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
If I understand you correctly, you painted over the old paint that probably had the smell soaked into it or was at least over the smell?
Vaughan
Old 02-24-2010, 05:55 PM   #3
Yep, painted over the existing paint and whatever was smelling up the cabinet. Completely washed the inside surfaces before painting though. Any ideas?
Old 02-24-2010, 06:05 PM   #4
1983 34' Excella
1967 24' Tradewind
Images: 32
Unfortunately the only thing I can think of would be to remove all the paint/finish and thoroughly bleach it. I would take it outside and sponge full-strength bleach over it several times, concentrating on the joints where smells could have soaked in. Allow to soak for half an hour or more. Then rinse and allow to dry completely, several days. Check for smells then. If that doesn't do it, I am out of ideas.
Stripping is not an easy thing, but at least now you have two more fresh coats of Kilz to take off.
Vaughan
Old 02-24-2010, 06:43 PM   #5
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
dont forget
Don't forget to wash the outside and the bottom of the outside under the cabinet. The backs of the cabinets are usually different wood that may be cheaper and not as durable. Make sure you wash that throroughly as well. Did you also paint the bottom of the shelves??
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 02-24-2010, 07:14 PM   #6
yes, painted all sides of the shelves and all of the interior surface.
Au Revoir Pee-Wee mistermike Our Community 13 01-02-2011 04:00 PM
I pee a lot at night. Is a bambi too small for me? Goldilocks Airstream Lifestyle 65 02-05-2009 02:17 PM
Demographics Question for Pee-Wee... digger bear WBCCI Forum 2 10-21-2008 10:45 AM
Attention, Something is Wrong and Needs Correction, by Pee Wee PeeWee WBCCI Forum 11 09-27-2008 09:03 PM
