Old 04-03-2007, 01:09 AM   #1
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Non Airstream aluminum repair help needed
During hurricane Cecil my two '50's Aluminum Tiki torches blew down.
There is a bowl shaped bottom with a pressed in non removable top piece.
When they fell they were dented on one side and now there is a non airtight section at the dent.
I see my options as taking it to a body shop for repair or finding a product that will seal that section. It must be impervious to the fluids inside the torch and to the flame should the breeze blow the flame to that section. The section is about 4-5 inches from the wick. There is only a hairline gap at the affected parts.
Anybody have a solution to this?
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 04-03-2007, 06:45 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Gas tank repair expoy. Buy it in sticks at an automotive repair shop. Not pretty but it works. It is a two part system you mix together. You will have to get the oil off the lamp first before it will stick. Follow directions included.
Old 04-03-2007, 07:45 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
CG,
I have used SikaFlex for a number of non=Airstream repairs and the stuff is impervious to a lot of chemicals once it is set up and fully cured. It comes in a perfectly matching aluminum color.........give it a try! It's also an excellent adhesive.
Old 04-09-2007, 12:25 AM   #4
Originally Posted by lewster
CG,
Where do I get it? Would camping world carry it?
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 04-09-2007, 07:05 AM   #5
lewster's Avatar
GC,
It's not easy to find, but the Airstream store on the web site has it. When you order it, be sure that you get a fresh tube that is NOT close to the expiration date. The stuff seems to really adhere (pun intended) to the expiration dates on the label!
Old 04-09-2007, 09:49 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Several members and I have used Austin Hardware -- fairly painless. Ditto on the gray being a good match to aluminum. Austin Hardware and Supply: Product: 'Sikaflex®-221'
5 meter Langford Nahanni
Old 04-09-2007, 01:31 PM   #7
bobchevy89's Avatar
1977 24' Argosy 24
Inverness , Florida
I use a product called PC7 you can get it at ace hardware .mix both parts and apply , before it sets you can wet your fingers and smooth it out . when dried you can drill and tap it.
just want to camp happy
bobchevy89 is offline   Reply With Quote
Old 04-09-2007, 08:41 PM   #8
lewster's Avatar
Sounds a lot like 'JB WELD'
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 07:19 PM
Airstream History pjtaia Our Community 1 08-24-2002 04:28 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 06:49 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 03:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 02:31 PM
