Old 04-03-2015, 11:00 PM   #1
bloomington , California
Exclamation Need Info by Tom A.M.
I know I am not going to be welcomed by many but, I was offered a 1971 silver stream empress trailer for FREE. ( Yes, I know this is Airstream forum) I have to pick up in the AM. Anyways I cannot find any real info on airstreams. This trailer has a dent in the lower rear corner with a tear in it. The panels are rivited on so I am not sure if it can be fixed or is worth being fixed. If anyone can help me with info I would greatly appreciate it.
Thank you in advance.
I don't mean to offend anyone either I am desperate for some info.
champrider is offline   Reply With Quote
Old 04-03-2015, 11:25 PM   #2
2007 22' International CCD
It's fixable by drilling out the rivets and replacing the panel with a new one. If the panel has a simple curve it's fairly easy. A compound curve is a bear.
You can use "Olympic type rivets" if you have no access to the interior in that area. For free it's probably well worth the effort.
Check brakes, axles and lights before you tow it.
Search the forums on panel repair techniques. There are many who do it.
KE4GNK/AE
Old 04-03-2015, 11:29 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
It's probably a "Silver Streak" - and we do welcome "vintage kin" here. There are half a dozen aluminum trailers that were similar to Airstream that are now no longer in production.
Generally flat panels can easily be replaced if the alloys are still made - even if they are not panels can be replaced with the closest match though of course they will never match perfectly.
As far as your trailer is concerned - first FREE is the right price. Even if it's not worth rebuilding it can definitely be used as a parts trailer for another vintage unit that is missing windows, appliances, trim pieces, etc. Evaluate it, and flip it if it's beyond reasonable repair.
A trailer that old is likely to have severe floor and frame damage if it has sat out in the weather - gaskets and sealers fail over time, windows get broken and mice and other critters make it their habitat. If on the other hand it's been in a barn or better yet, climate controlled storage it could be a complete gem. Without pictures no one can really give you a realistic appraisal of what you're in for when you pick it up.
IF (big IF) the frame is sound you'll probably still need new tires and clip on running lights to tow it home - AND go slow. If the frame is rusted badly - you need a flat bed trailer or tow truck to get it to your workshop/garage or yard. Know your zoning regs before you put in a residential neighborhood - especially in the yard.
If you do not have experience doing a frame off rebuild - do spend some time reading the renovation threads on this forum. About the worst thing you can do is a "make it pretty" renovation without understanding what structural, electrical, plumbing and propane issues might be. You end up having to rip up the whole thing and do it over.
Good luck, Paula
Old 04-04-2015, 06:55 AM   #4
Exclamation Believe it or not there are silver stream trailers
This is what kept confusing me when I looked up the trailer. There is a silver Streak and a Silver Stream. This particular trailer is a 71 Silver Stream Empress. The only thing I have found close is a 68 Silver Stream. Other than that I really cant find any info on silver stream. However in the Classifieds on this site there is a 68 that looks pretty much identical. I am trying to locate a couple of the pics so I can send them this way.
Old 04-04-2015, 09:19 AM   #5
heres the pics
pics I have. I don't have one of the rear where its dented, O
Please give your honest opinion for me to pick this up or not. Its almost an 80 mi trip one way.
ID:	235558   Click image for larger version
ID:	235560   Click image for larger version
Old 04-04-2015, 09:21 AM   #6
BTW the tarp is covering air vent on roof where it was broken
Old 04-04-2015, 01:22 PM   #7
It does not look real bad. For free, take it.
KE4GNK/AE
Tom Tom One GPS Version 3 wingfoot321 Electronics & Connectivity 11 01-08-2012 09:56 AM
Tom Hanks Airstream Moonshot Our Community 34 04-06-2009 12:38 PM
Tom at Perfect Polish airstreamcaravel Cleaning, Stripping & Polishing 1 09-16-2003 11:47 PM
