Posting a question is one way to get information. The other way is to educate yourself with the information that exists on the forum. Your question is about batteries. Enter batteries or battery in the blue box at the upper right corner of the page. That will get you a list of threads to review. Keep entering different search terms as you read through the posts. It takes a bit of work to understand the subject that you are investigating. Take note of the experts as they can help cut through the noise.
In the interim, a wet cell battery, like Walmart sells will function. What is required is to maintain it well and use it correctly. It can not be allowed to drop below 50% charge or it's life will be significantly reduced.
Your investigation should also include battery monitor, converters, golf cart batteries, and parasitic loads.
Note, if you kill an AGM with improper use, the added performance of the higher priced spread is lost. Also, there are a wide variety of places you can purchase batteries. They don't all have the same profit margin, so that issue is part of the investigation as well.
Good luck with your review and investigation. Pat
Here is a start:
http://www.airforums.com/forums/f382...ml#post2102695
