Old 05-17-2018, 09:10 PM   #1
Scottsdale , Arizona
Living in Arizona
I'm just now putting my 2008 Airstream on the road and need help. Living in a hot weather climate should I be using standard rv/marine batteries of those that seem like a lot of money (gel/etc). Any advice since the 25" Safari SE is stored in my back yard.
jimdaher is offline   Reply With Quote
Old 05-17-2018, 09:19 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I am a big fan of Lifeline AGM batteries. Installed one in my last Airstream and it was working great when I sold the trailer 10 years later. Most of those years were in Phoenix.
To get the most out of the battery, I installed a PD 9245 converter when I installed the battery.
My latest trailer has Lifeline AGMs and a PD 9245 as well.
Richard
Old 05-18-2018, 08:19 AM   #3
Thanks much I'll check some pricing now that it appears it may be worth it. How do you store them?
Old 05-18-2018, 09:31 AM   #4
1976 31' Sovereign
Oswego , Illinois
I would compare life of marine bat. with agm and prices what ones to buy.
Old 05-18-2018, 09:38 AM   #5
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Posting a question is one way to get information. The other way is to educate yourself with the information that exists on the forum. Your question is about batteries. Enter batteries or battery in the blue box at the upper right corner of the page. That will get you a list of threads to review. Keep entering different search terms as you read through the posts. It takes a bit of work to understand the subject that you are investigating. Take note of the experts as they can help cut through the noise.
In the interim, a wet cell battery, like Walmart sells will function. What is required is to maintain it well and use it correctly. It can not be allowed to drop below 50% charge or it's life will be significantly reduced.
Your investigation should also include battery monitor, converters, golf cart batteries, and parasitic loads.
Note, if you kill an AGM with improper use, the added performance of the higher priced spread is lost. Also, there are a wide variety of places you can purchase batteries. They don't all have the same profit margin, so that issue is part of the investigation as well.
Good luck with your review and investigation. Pat
Here is a start: http://www.airforums.com/forums/f382...ml#post2102695
Old 05-18-2018, 10:00 AM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I don't see hot climate as being much of a factor in battery choice.
Old 05-18-2018, 12:41 PM   #7
PKI
PKI's Avatar
Maybe, hot weather can evaporate more electrolite if over charge is an issue - key up the converter threads. Certainly will result in more fan use. May mean less overnight heating and the associated blower electrical load from the furnace. However hot in the day at altitude gets you cold at night and some furnace use. Might mean more use of the coach at a full hookup site or more generator use or more storage until the cool weather shows up or opportunity to justify solar. As is often said, it depends. ASs are not four season trailers and hot is one of those seasons in which it is not designed to excell. Function yes, with AC, but not excell. But mostly it just depends on use, which is owner controlled or ignored to preference. Pat
Living in 34' AS Fulltime - Living My Parent's Dream.... bugnot1 Member Introductions 14 12-21-2010 08:40 AM
Winter Living Rubyslipper Winter Living 98 06-23-2007 04:49 PM
1985 'L' Shape Living Room ZenRVer 1984 -1986 Excella 0 08-11-2003 04:38 AM
Biggest living room 31' or less darkStar Our Community 4 07-04-2003 03:01 AM
To use or not to use: living in our Airstream TinRoof General Appliance Topics 2 08-09-2002 12:11 PM
