Old 06-29-2012, 07:45 AM   #1
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
Latest Recalls
I thought I would start a thread to post info on the latest recalls going out. You can sign up for these recalls notices at Home | National Highway Traffic Safety Administration (NHTSA).
Looks like a few different brands of tires are out there made from a bad batch of rubber compound.
NHTSA Campaign ID Number: 12T011
Synopsis:
TBC Corporation (TBC) is recalling certain Sigma Stampede Radial SUV tires, size P265/70R17, equipped with DOT code UTT6TX60112. Contaminated rubber may have been used in the tread compound which could result in tread separation. Tread separation can result in loss of vehicle control, increasing the risk of a vehicle crash. TBC will notify owners, and dealers will replace the tires free of charge. Free mounting and balancing will also be included, as applicable. The recall is expected to begin on July 2, 2012. Owners may contact TBC at 1-901-363-8030. TBC‚s recall number is 156.
NHTSA Campaign ID Number: 12T010
Synopsis:
Cooper Tire & Rubber Company (Cooper) is recalling certain Cooper brand Discoverer H/T tires, sizes LT235/85R16 and P265/70R17; Discoverer LSX, size 265/70R17; and Mastercraft Courser HTR, size LT235/85R16. Also included in this recall are tires branded as Del-Nat Delta A/S Sierradial or National A/S Commando, size 265/70R17; Pep Boys Definity Dakota H/T, size P265/70R17; and TBC Sigma Stampede Radial SUV, size P265/70R17. Contaminated rubber may have been used in the tread compound which could result in tread separation. Tread separation can result in loss of vehicle control, increasing the risk of a vehicle crash. Cooper will notify owners, and dealers will replace the tires free of charge. Free mounting and balancing will also be included, as applicable. The recall began on June 15, 2012. Owners may contact Cooper Tire & Rubber Company‚s Consumer Relations Department at 1-800-854-6288. Cooper‚s recall number is 156.
NHTSA Campaign ID Number: 12T013
Synopsis:
Pep Boys is recalling certain Definity Dakota H/T tires, size P265/70R17, equipped with DOT code UTT6PA70112. Contaminated rubber may have been used in the tread compound which could result in tread separation. Tread separation can result in loss of vehicle control, increasing the risk of a vehicle crash. Pep Boys will notify owners, and dealers will replace the tires free of charge. Free mounting and balancing will also be included, as applicable. The recall is expected to begin on July 9, 2012. Owners may contact Pep Boys 1-215-430-9169. Pep Boys‚ recall number is 156.
The NSA -- The only part of the government that listens.
newroswell is offline   Reply With Quote
Old 07-07-2012, 12:02 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 61
This is a good history of past recalls.
RVRESOLVE: 2005-11-06
Pick your choice of year detail from the left column.
Interesting reading.
Dave
Old 07-19-2012, 12:37 PM   #3
masseyfarm's Avatar
Images: 61
Airstream Recalls
This site may be of interest.
AIRSTREAM Recalls & Defects | AIRSTREAM Problems & Service Bulletins
ENTER in your unit on the page and it will bring up the problems
Dave
Most Recent Recalls
VehicleComponentManufacterer2001-2004 AIRSTREAM CLASSIC EQUIPMENT Recall
2001-2004 AIRSTREAM CLASSICEQUIPMENT
Units affected: 16AIRSTREAM, INC.
Report Date: 2010-09-16Summary: AIRSTREAM IS RECALLING CERTAIN MODEL YEAR 2001-2004 34" CLASSIC TRAVEL TRAILERS EQUIPPED WITH DIMPLEX ELECTRAFLAME, SYMPHONY, OR OPTIFLAME BRANDED ELECTRIC FIREPLACES, STOVES, AND FIREPLACE INSERTS. THE PLUG IN REMOTE CONTROL RECEIVER FOR THE FIREPLACE CAN OVERHEAT.
2005-2009 AIRSTREAM CLASSIC SERVICE BRAKES, HYDRAULIC Recall
2005-2009 AIRSTREAM CLASSICSERVICE BRAKES, HYDRAULIC
Units affected: 737AIRSTREAM, INC.
Report Date: 2010-07-22Summary: AIRSTREAM IS RECALLING CERTAIN MODEL YEAR 2005-2009 CLASSIC TRAVEL TRAILERS MANUFACTURED FROM MARCH 2005 THROUGH APRIL 2009 AND EQUIPPED WITH HYDRAULIC BRAKE CONTROLLER BY ACTIVE TECHNOLOGIES. IT IS POSSIBLE THAT THE BRAKE CONTROLLER CAN FAIL UNEXPECTEDLY CAUSING THE BRAKES ON THE TRAILER TO LOCK UP OR TO FAIL COMPLETELY.
2010 AIRSTREAM FLYING CLOUD POWER TRAIN:AXLE ASSEMBLY Recall
2010 AIRSTREAM FLYING CLOUDPOWER TRAIN:AXLE ASSEMBLY
Units affected: 15AIRSTREAM, INC.
Report Date: 2010-03-04Summary: AIRSTREAM IS RECALLING CERTAIN MODEL YEAR 2010 FLYING CLOUD TRAVEL TRAILERS. THESE VEHICLES WERE BUILT WITH AXLES RATED AT 3,800 LBS. THE VEHICLES SHOULD HAVE BEEN BUILT WITH AXLES RATED AT 4,400 LBS.
2003-2005 AIRSTREAM 355XL SERVICE BRAKES, HYDRAULIC Recall
2003-2005 AIRSTREAM 355XLSERVICE BRAKES, HYDRAULIC
Units affected: 6AIRSTREAM, INC.
Report Date: 2009-06-10Summary: AIRSTREAM IS RECALLING 6 MY 2003-2006 35XL, AND 355XL MOTOR HOMES EQUIPPED WITH AXLES THAT INCLUDE BOSCH ZOPS OR ZOHT PIN SLIDE HYDRAULIC DISC BRAKES. WHEN COMBINED WITH OCCASIONAL OR SEASONAL VEHICLE OPERATION MAY EXPERIENCE CALIPERS STICKING IN THE APPLIED POSITION. THIS CAN RESULT IN ABNORMAL HEAT GENERATION AT THE WHEEL END CAUSING BRAKE DRAG. THE DRIVER WOULD NORMALLY HAVE WARNING OF THE BRAKE DRAG IF UNDETECTED BY THE DRIVER.
2003-2005 AIRSTREAM 35XL SERVICE BRAKES, HYDRAULIC Recall
2003-2005 AIRSTREAM 35XLSERVICE BRAKES, HYDRAULIC
2002-2009 AIRSTREAM BAMBI EXTERIOR LIGHTING Recall
2002-2009 AIRSTREAM BAMBIEXTERIOR LIGHTING
Units affected: 2052AIRSTREAM, INC.
Report Date: 2009-05-15Summary: AIRSTREAM IS RECALLING 2,052 MY 2002-2009 BAMBI, INTERNATIONAL, SAFARI, 75TH ANNIVERSARY, DWR, AND OCEAN BREEZE TRAVEL TRAILERS FOR FAILING TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THE TRAVEL TRAILERS WERE BUILT WITHOUT REAR REFLEX REFLECTORS.
2002-2009 AIRSTREAM SAFARI EXTERIOR LIGHTING Recall
2002-2009 AIRSTREAM SAFARIEXTERIOR LIGHTING
2002-2009 AIRSTREAM 75TH ANNIVERSARY EXTERIOR LIGHTING Recall
2002-2009 AIRSTREAM 75TH ANNIVERSARYEXTERIOR LIGHTING
2002-2009 AIRSTREAM DWR EXTERIOR LIGHTING Recall
2002-2009 AIRSTREAM DWREXTERIOR LIGHTING
2002-2009 AIRSTREAM OCEAN BREEZE EXTERIOR LIGHTING Recall
2002-2009 AIRSTREAM OCEAN BREEZEEXTERIOR LIGHTING
Old 07-19-2012, 12:54 PM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
This thread is a great idea. Thanks guys.
I never received any recall info about rear reflectors. I'll contact Airstream.
Gene
Old 07-19-2012, 01:04 PM   #5
masseyfarm's Avatar
Images: 61
One suspects the recalls are posted on the management coffee room blackboard ?????? I doubt much mail is sent out detailing them?
Dave
Old 07-20-2012, 08:30 AM   #6
Chief Chili Cook
newroswell's Avatar
Dave, great find. I'm suppose to have 4400lb axles and my VIN isn't showing a recall. I think I better get under there and look for a part number on the axles themselves though!
Old 08-15-2014, 05:59 PM   #7
richinny's Avatar
2011 34' Classic
VORNADO RECALL:
Recalled Vornado Space Heaters Can Melt, May Cause Fires - DailyFinance
Ricky
Old 08-15-2014, 07:49 PM   #8
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Gene
Gene...we did a get a recall notice letter that included two small squares of reflective tape to add to the back of the rig below the tail lights. I thought that was a pretty lame "solution" to the problem.
We did not use them. I bought strips of red and white reflective tape like you see on the bumpers of trucks and applied to the rear bumper...it not only looks great but no one is going to miss seeing the back end our Bambi in the dark when they shine their headlights on it.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 09-23-2014, 10:41 AM   #9
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Airstreaminterstate2013-2014
RECALL Subject : Propane System may Vent
Report Receipt Date: DEC 18, 2013
NHTSA Campaign Number: 13V632000
Component(s): UNKNOWN OR OTHER
Potential Number of Units Affected: 552
All Products Associated with this Recall
Vehicle MakeModelModel Year(s)
AIRSTREAMINTERSTATE2013-2014
Details
2 Associated Documents
Manufacturer: Airstream, Inc.
SUMMARY:
Airstream, Inc. (Airstream) is recalling 2013-2014 Airstream Interstate recereational vehicles manufactured August 2012 through October 2013. In the affected vehicles, the installation of the propane tank and the regulator may damage the regulator, allowing propane to escape out of the safety release vent if it experiences an over pressurized condition.
CONSEQUENCE:
If the vehicle is parked in an enclosed storage area, in the presence of an ignition source, the escaping propane can collect and potentially cause a fire and or explosion to occur.
REMEDY:
Airstream will notify owners, and dealers will replace the regulator on the propane tank, free of charge. The recall in expected to begin by early February 2014. Owners may contact the Airstream Warranty/Service Department by phone at 1-937-596-6111.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to Home | Safercar -- National Highway Traffic Safety Administration (NHTSA).
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
