Old 11-10-2010, 09:13 AM   #1
1953 Flying Cloud
1953 Flying's Avatar
1953 21' Flying Cloud
West Sacramento , California
Images: 8
Landscaping Idea's needed
Howdy All,
Well this year my family and I helped stimulate the economy and purchased a new how home. What I need is help with ideas on how to make my new front yard Airstream friendly. You see I have this really soft fill dirt that slopes up about 2 1/2 to 3 feet about a 45 degree angle. Not thinking I tried to push the Stream up the slope into it's new home and now I have ruts in the lawn . In order for me to get her up there I have to use plywood sheets to help prevent making more or bigger ruts. Using plywood is just a pain I would not like to do each time I decide to go and come back. I have seen where people have just put strips of cement where the tires go, but I was looking for ideas of a little more fancy. I have attached some pics, not the best but should give an idea of what I'm dealing with.
Thanks for any input you may have,
ID:	114885   Click image for larger version
ID:	114887   Click image for larger version
Custom driver license Pet ID's.
www.petidforme.com/105
1953 Flying is offline   Reply With Quote
Old 11-10-2010, 09:43 AM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Instead of plain concrete maybe you could use a dye in the mix and use a stamping process, like the look of stone. Lots of patios are done that way and it could look very nice. Or pavers but with the soft soil pavers might sink over time. Set the concrete low so it would be easier to mow over. Just a thought.
blmitch5 is offline   Reply With Quote
Old 11-10-2010, 10:13 AM   #3
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
A lot of work, but one could remove the topsoil and add a layer of red dirt and compact it, then replace a moderate layer of topsoil and regrow the grass. This makes a "hidden" driveway.
This method is used around commercial buildings that are not surrounded by parking lots to allow fire apparatus access.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 11-10-2010, 10:32 AM   #4
1977 Argosy 24
Milltown , Wisconsin
Some cemeteries use a type of plastic paver with holes in it that goes under the grass/sod so that you can't see it, but it supports the weight across a much bigger area so you can drive over it with no ruts.
ventport is offline   Reply With Quote
Old 11-10-2010, 12:00 PM   #5
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
You could purchase one of those plastic castings (not very expensive). You fille the casting with concrete and move it to the next spot and pour more concrete in the casting until job is complete. They come in all types of patterns. Here is just one. One web site attached.
Concrete or Cement Molds For Garden, Pond, Walkways, Ornamental and Exterior Wall Hanging
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 11-10-2010, 12:05 PM   #6
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Here is another type - might be better
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 11-10-2010, 12:32 PM   #7
1973 31' Excella 500
Spring Green , Wisconsin
Turfstone
Here is a product, Turfstone, which we've used for "invisible" driveways such as fire lanes, maintenance drives, etc. in lawn areas. You lay the stones and plant grass in the open spaces. It soon blends in and you can hardly tell it is there,yet you have a solid drive. Turfstone Pavers - turf stone paver shapes These will hold up a fire truck, so I know they'll support an Airstream.
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Old 11-10-2010, 12:33 PM   #8
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Decorative Block Pattern
We are considering a storage building in our back yard and it will require 60+ feet of "driveway."
I plan to have the contractor dig below the surface of the grass and pour a rough outline of the ribbon-style driveway that the trailer will follow when I back it into the garage. The ribbon will be a foundation of sorts in order to support the weight of the trailer and TV. All that will be below ground level.
After that we'll use concrete blocks on edge (some concrete bocks have decorative web patterns) and that will bring the driveway ribbons back up to ground level.
Then I fill the voids with soil and plant grass. The concrete block will tend to disappear within the grass. You cannot hide the concrete entirely but it will tend to disappear. With colored concrete (as suggested above) it would go even further to diguise the driveway.
Search the internet. I know there are other options. Many municipalities are insisting on less hard surfaced driveways in order to reduce water runoff so I know there is a market.
Here's one to look at:
Permeable and Porous Concrete Pavers - The Concrete Network
Lucius
Lucius and Danielle
1992 29' Excella Classic
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is online now   Reply With Quote
Old 11-10-2010, 12:59 PM   #9
Kevin245's Avatar
Originally Posted by driftless View Post
Originally Posted by nvestysly View Post
These are fairly common in parts of Europe where they're used as driveways and parking spaces. The ones we've seen blend in well.
Good luck,
Kevin
Eleanor Roosevelt
Old 11-10-2010, 01:27 PM   #10
Just a couple additional thoughts on the Turfstone pavers. You will need to construct a pad of compacted crushed gravel or stone beneath them or they won't be stable. Much like you would install a gravel base under patio pavers. Without the base you will see settlement and movement of the blocks under loaded conditions.
The concrete blocks on edge idea is interesting, but to get any strength at all, they need to be supported on compacted crushed stone as well. On edge they only have a wall thickness of about an inch or so, which creates a very small surface area to support the load of the trailer. Sitting on soil, they would most likely sink to some extent, leaving you with an uneven surface.
Lew TAC #WI-6
Old 11-10-2010, 03:09 PM   #11
1953 Flying Cloud
Images: 8
This sounds like this easiest way to fix my problem and still make it look nice. Turfstone Pavers - Has any one ever installed them and if so was it any harder then rebuilding a Airstream?
Old 11-10-2010, 04:25 PM   #12
I've specified them on several projects, and watched them being installed. Watching them being installed was a lot easier than even keeping an Airstream maintained!!
The last one we put in about five years ago was strong enough for a 60,000 pound fire truck. And, I couldn't find the name of the product, but it was made of pvc, was similar to Turfstone and much lighter. I think it went on 8" of compacted crushed stone over a fabric stabilization mat which combined gave it the strength.
Usually the manufacturer's web site gives directions for installation.
Lew TAC #WI-6
Old 11-11-2010, 04:31 PM   #13
Vintage Kin
Fort Worth , Texas
I watched a TURFSTONE install being done a dozen years ago. As with most things, prep is all. To do it properly (or any other approach) may require re-grading much of the yard to work well with the driveway, and for all other landscaping. Avoiding the look of a service entrance will not be easy.
An overall site plan may be the best approach. Landscape architecture books and software would be where I started (after securing a top notch survey and utility easement schemata) so as to have plenty to doodle with.
Year One might be the above tools/records. Year Two might be fence staining and espaliered trees or vines on fence and house wall, plus something for other utilities service.
Etc
Good luck
Need bathroom mirror sliding stay idea's bmklawt Cabinets, Counter Tops & Furnishings 4 02-26-2009 04:24 AM
Help needed, please! Taxman Classic Motorhomes 0 12-25-2006 07:46 PM
help needed freeofecho Our Community 2 03-14-2006 09:38 PM
Your opinion is needed!! thenewkid64 Our Community 61 09-26-2005 01:36 PM
New axles needed or not? FrenchBern Axles 9 07-12-2005 07:54 AM
