Old 06-29-2007, 12:05 PM   #15
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Exclamation
You can make somethings fool proof, but you can't make anything d___fool proof.
The La Times article seemed a lot like a vendetta to me. Not informed and not balanced.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-29-2007, 12:07 PM   #16
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Where are those 1950's Drivers Education Films when you need them?
Old 06-29-2007, 12:18 PM   #17
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You mean like "Blood Flows Red on the Highway?" If more newly minted drivers had to watch them, it MIGHT make a small difference. I will take a small difference, over no difference, any day.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 06-29-2007, 02:20 PM   #18
bhayden's Avatar
1978 24' Argosy 24
Woodinville , Washington
I don't recall my LA Times login and don't want to bother with it right now but did they really say "surge brakes would prevent sway"? When set up correctly I think surge brakes can work effectively IF the tow vehicle is well within it's limits. If you're pushing the max trailering weight then electric brakes are a must. In general I'd have to say surge brakes are a contibutor to sway and if incorrectly adjusted are worse than nothing at all because by the very nature in which they work they are prone to setting up an oscillation.
-Bernie
bhayden is offline   Reply With Quote
Equalizer hitch and sway control Rod Pease Airstream Trailer Forums 15 04-07-2006 11:00 AM
ABS and Hydralic trailer brakes rschulz Brakes & Brake Controllers 1 04-17-2004 03:15 PM
testing the elec brakes? Rog0525 Brakes & Brake Controllers 3 06-11-2002 03:02 PM
conversion from vacuum/disk to electric brakes excelladep Brakes & Brake Controllers 2 05-30-2002 11:54 AM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
