Old 09-11-2008, 05:00 PM   #1
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
Kerosene 1-K and Coleman Lantern
Hi all,
Can Kerosene 1-k be used in a Coleman lantern that normally uses the white gas type of fuel, I don't think so but the guy at Gander Mountain said it could (they were out of coleman fuel thanks to hurricane Ike). Just want someone to tell me what I think I already know.
thanks
James
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 09-11-2008, 05:12 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Coleman lantern fuel is a special blend that most closely resembles white gas, not #1 fuel oil (kerosene).
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 09-11-2008, 05:14 PM   #3
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
nope, not unless it is a multi fuel device in which case I am unsure
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 09-11-2008, 05:15 PM   #4
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
James,
DO NOT use any kind of kerosene in a Coleman lantern that usually uses naphtha (white gas)!!!!! That is unles you want to ruin a perfectly good Coleman lantern.
I think you can run unleaded gas in a Coleman lantern if it is set up for it. See the following link on the Coleman site...
Coleman® FAQ - Can I use unleaded gasoline when Coleman® Fuel is recommended?
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 09-11-2008, 05:40 PM   #5
2007 25' Classic
Hydes
James ,you might want to look into these lanterns. I've had several for years and as far as I know they are the only multi-fuel lanterns. Really high quality. Petromax Lanterns- Britelyt Lanterns- Britelyt Multifuel Products
craftsman is offline   Reply With Quote
Old 09-11-2008, 05:42 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
AFAIK there are five types of liquid fuel lanterns; LP, Kerosene, White Gas (Coleman fuel), Dual Fuel (white gas and leaded gas) and multi fuel. I don't believe Coleman makes any multi fuel lanterns. The last one I had was a Petromax and they ain't cheap!
And in answer to the OP's question. Most Coleman lanterns don't burn Kerosene. They do make a kerosene mantle lantern but you would know if you had one.
Aaron
WBCCI #XXXX AIR #2495
Old 09-11-2008, 06:13 PM   #7
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
no kero in a coleman unless you have one of the wwII models that were designed to burn kero or leaded gas.
there are true kero models that were sold mostly in canada in the 50's, they are easy to spot as they have oversized generator tubes and are red in color.
(i have one amongst the 20 or so lanterns in my collection)
i would suggest unleaded gasoline as a replacement for the naptha. IF it is one of the dual fuel models sold lately, they are easy to spot as they are silver.
john
you call them ferrets, i call them weasels.
Old 09-11-2008, 06:23 PM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
the third photo in this thread is the true dual fuel model.
http://www.airforums.com/forums/f161...rns-17333.html
john
Old 09-11-2008, 08:46 PM   #9
GO Bob's Avatar
1982 34' Limited
1975 31' Sovereign
Grovetown , Georgia
Years ago I stored kero in an old coleman can and forgot about it. I filled a lantern and a stove with it. I had a hard time trying to light the lantern and when it did a pyro show insued. Not to be detoured I burned match after match then the the large flame and the smell of the hair that burned off my arms.
Yes it can be done but unless it it designed for it, don't !
"Humans get a lot done,not because we're smart, but because we have thumbs so we can make coffee." Flash Rosenburg
"Decaffinated coffee is the devil's blend."
GO Bob is offline   Reply With Quote
Old 09-11-2008, 09:00 PM   #10
1970 27' Overlander
Houston , Texas
Thanks guys, I knew that guy did not know what he was selling, or maybe he did cause I have a jug. I should have got the hint when it was all that was left on the shelf . Thank goodness for a decent movie collection because there is nothing but panic the public non-stop Ike coverage on local tv, its amazing.
James
____________
1970 Overlander
Old 09-11-2008, 09:04 PM   #11
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Read the owners manuel. My stove is a 3 fuel stove and I think my lantern is also. I am going to check in the A.M Both coleman
mustang is offline   Reply With Quote
Old 09-11-2008, 09:33 PM   #12
1999 25' Safari
Fairburn , Georgia
I have a Coleman lantern purchased in the late '60s which burns ONLY kerosene. It uses a different mantle (larger than a gas mantle) and has a built in fuel pre-heater to turn the kero into a gaseous state that will burn. The light output is much more than a gas lantern and the heat output is about that of a kerosene stove. It feels good on a cool day! Just some semi-useless info -----
JackMac is offline   Reply With Quote
Old 09-12-2008, 02:25 AM   #13
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
john
Hey john,
Coleman still sells the Kerosene lanterns, but now they are green I bought one a while back when my local Coleman Outlet store was going out of business. One can never have too many lanterns
Aaron
Old 09-12-2008, 05:43 AM   #14
Well Preserved
1993 21' Sovereign
James
If your tow vehicle is a diesel, you can put the jug in the tank and burn it with no problem. #1 (kerosene) fuel oil is light diesel fuel, and while I'm not sure about modern times, up until a couple of years ago the cold weather formula of #2 diesel fuel (the stuff you normally put in the tank) contained an amount of #1, it contains more aromatics, and ignites a little faster. It is also useful as a solvent, or degreaser. Don't try to light a campfire with it...
Kit to use Trailer Propane for lantern/grill sigv LP Gas, Piping, Tanks & Regulators 10 12-24-2007 11:46 AM
Coleman vs Carrier Swanny Furnaces, Heaters, Fireplaces & Air Conditioning 12 05-21-2007 06:49 PM
Airstream-o-Lantern! A-Merry-Can Our Community 13 11-01-2006 09:51 AM
Gas lantern in '67 Safari - need info airdrmr General Interior Topics 10 08-07-2006 12:36 AM
Carrier vs. Coleman? ipso_facto Furnaces, Heaters, Fireplaces & Air Conditioning 2 07-19-2005 08:51 PM
