Old 03-26-2005, 06:18 PM   #15
mandolindave's Avatar
Hey Janet,
My friends have tried everything and they talked me in to a poly mat.
They said that water needs to be able to seep down through the mat
and down into the ground. They are light, and easy to wash and dry,
and very stain resistant. After big rains I move the mat to let the ground dry up.........Has anyone tried them in the sand???????
mandolindave is offline   Reply With Quote
Old 03-26-2005, 10:09 PM   #16
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Envrionmentally friendly rugs
Originally Posted by Rebee
We use a piece of AstroTurf. If if gets dirty, we lay it over a picnic table or the tailgate of tow vehicle and rinse it out with a hose. Takes a very short time for the water to drain from the mat and does not hurt to stow in back of truck damp and clean.
Many campgrounds are starting to require that you use a rug that won't kill the grass under it - which makes sense because without grass cover you'll get mud and sand like crazy. Astro turf doesn't qualify - you need something porous.
Tin Lizzie
Old 03-27-2005, 07:13 AM   #17
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
We use some cheap old thing we got at a home improvement warehouse around here (Menards). It grabs most if not all the sand and dirt. Whenever possible, we have the awning out so it doesn't get wet too often....but when it does, it's all fun!
I think an astroturf thing like Jack posted would be great.
Trans service ALANSD Mechanics Corner - Engines, Transmission & More... 8 08-30-2002 12:24 PM
Regarding original water tank clean out - thank you! 60stradewind Fresh Water Systems 0 08-22-2002 12:00 AM
Question re how to cut aluminum sheeting and get a clean edge... williamhenshall Ribs, Skins & Rivets 7 06-12-2002 05:58 PM
inside light lens' how to remove to clean Paul Daugherty Mechanics Corner - Engines, Transmission & More... 12 04-25-2002 10:51 PM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
