Old 04-08-2004, 04:41 PM   #1
Gwen's Avatar
Images: 12
Just One More What's It Question...
Can someone tell me what this white thingamajig-bob is in front of the reflector?
Name:	Cilla in AS 009.jpg
Gwen is offline   Reply With Quote
Old 04-08-2004, 04:57 PM   #2
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
That so-called thing-a-ma-bobber is a rear light indicator for when you're towing your rig. It tells you in the mirror if all of your lights are working when you apply the brakes or use the turn signal. Pretty cool feature especially if you're traveling by yourself.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 04-08-2004, 05:11 PM   #3
Gwen's Avatar
Images: 12
Thing-a-ma-bobber
Thank You flyfshr!
Old 04-08-2004, 07:06 PM   #4
It's call a "tail light monitor."
It works by using fiber optics.
Tri Axle Question HowieE Axles 30 10-27-2004 08:44 PM
Oil in Generator Question flyfisher Generators & Solar Power 4 12-29-2003 03:50 PM
Question regarding GVWR joshua32064 Tow Vehicles 6 10-19-2003 07:57 PM
Rust Question drober05 Airstream Motorhome Forums 6 10-05-2003 02:09 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
