Old 03-07-2008, 10:05 AM   #15
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
My answer would be - take it easy going home and begin your search for a more appropriate tow vehicle. Yours is not adequate for the trailer. But it likely will get you home if you watch yourself.
Congrats on the new beauty.
Pat
pmclemore is offline   Reply With Quote
Old 03-09-2008, 12:18 PM   #16
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Glad Ya Made It!!
You'll get a good idea about your tv on the trip home.
As others have already said, the off-road set up may be it's biggest
drawback. I've checked your photo gallery, the Airstream looks sooper!!
I couldn't open the truck photo's in your posts though.
Has anyone else had the same problem?
“We were young and knew nothing...now we're old and everyone else knows everything.”
RLC
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
"Tahawus"
Old 03-09-2008, 01:11 PM   #17
greg_n_'s Avatar
1978 31' Sovereign
, Indiana
Images: 11
Hiya Robert,
I think I figured out how to upload some more pics... I just uploaded pics of the truck and have planned to purchase the following to install onto the truck to tow our Soveriegn - tell me if I'm nuts or should just buy a different TV:
1. Putnam Reciever HItch: Class 4
2. Equalizer Weight Distribution Hitch: 10 or 12K capacity
3. Fireside Ride Rite Suspension helper add on
4. Ride Rite - Level II Command center for add on suspension helper
5. P-3 Tekonsha Brake Controller
The above system upgrades will cost me about $850-950 bucks vs. 9-10K on a different TV...
.... Thanks for all your guys and gals help it is really appreciated
here is a link to our photo gallery: http://www.airforums.com/photos/brow...0&userid=27440
greg_n_ is offline   Reply With Quote
Old 03-09-2008, 03:03 PM   #18
_
hi greg
i c u r trying to outfit the 150 for towing.
here are some of basic thoughts...
-the 302 is marginal power, tranny and cooling system are too.
-the over sized tires work against towing in several ways.
-moreso given the short wheel base with those big tires...
-the truck in original form probably had adequate payload and towing capacity, although up hill might be slow...
-if rear suspension has been beefed up that may not be a bonus, depends on what was done.
-using manually adjusted air bags WITH a w/d hitch isn't usually advised
-the bags don't increase towing capacity and conflict with proper spring bar adjustments...
-how are the brakes on this truck? u will need 8 GOOD brakes for tennessee.
now perhaps u will rarely tow and take only short trips, and find the truck is adequate....
rodney used a similar truck with an older/lighter/ shorter trailer, before opting for a 3/4 ton with diesel...
http://www.airforums.com/forums/523461-post73.html
http://www.airforums.com/forums/f463...tml#post425684
http://www.airforums.com/forums/f463...150-21062.html
there are LOTS of 1/2 ton options for your 5-6k trailer to consider...
and that might be worthwhile before spending too much on the 302.
of course the brake controller can be used with other tow vehicles...
but u really shouldn't need a 10-12k hitch for this trailer, get one that matches the trailer mass/tongue weight.
cheers
2air'
Old 03-09-2008, 03:28 PM   #19
greg_n_'s Avatar
1978 31' Sovereign
, Indiana
Images: 11
Groovy... Thanks....
I did post my truck for sale on Ebay the other day. I think you are right on the nose with this, So - I am hoping to get a more appropriate TV in the near future.
If the truck does not sell this round on ebay I may just put a hitch appropriate for the trailer on it and get the other stuff minus the airbag suspention... All the other stuff I can transfere to my new TV.
You guys have been awsome with the input.
Old 03-09-2008, 05:22 PM   #20
Thumbs up Right Decision Me Thinks
I think you did make the right decision with your truck. The 150 would
work much better as a long bed. The added wheelbase would add a great
deal in your comfort level while towing. Looks like you've done some good
research on what equipment your going to need. This Forum is THE best
resource. Do your Homework and take notes, they come in handy when
dealing with over zealous salespeople. Remember you don't have to spend
a lot, just what matches your needs and what you are comfortable with.
Stream-on
RLC
RLC
"Tahawus"
Old 03-10-2008, 08:46 AM   #21
1975 25' Tradewind
Central , California
I am a former F-150 owner and now own a GMC 2500. My understanding is that the F-150 is not rated to tow a trailer this big. Check the max tow weight and compare it to the weight of your trailer. Remember that water is over 7 lbs per gallon and you will be adding a lot of weight when you pack for a trip.
The suspension breaks and bearings in the F-150 may not be built for this much of a load. Check first. Safe travels.
Pepsi is offline   Reply With Quote
Old 03-10-2008, 09:10 AM   #22
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
You just might happen to have on the '85 150, something a lot of us don't have: Vacuum! That trailer might have vacuum disc brakes, like my 78 31' Excella. Don't let mechanic Bob steal your disc brakes and put in some drum brakes. If your vacuum/hydraulic activator behind the propane tanks don't work, there are electric models that will push the hydraulic.
NevadaGeo is offline   Reply With Quote
Old 03-10-2008, 09:38 AM   #23
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Robert,
I've been seeing this on a number of threads lately. Not all threads.
Dave
Fyrzowt is offline   Reply With Quote
Old 07-22-2008, 02:23 AM   #24
trevisgardne's Avatar
1973 31' Sovereign
Maryville , Tennessee
My 73 Sovereign weighs 7720 packed for camping. I (stupidly) have towed everything under the sun with at least a dozen different F100/F150s. I recommend an upgrade.
trevisgardne is offline   Reply With Quote
My 1st Airstream Rooster2 1966-68 Caravel 3 10-15-2006 06:04 AM
1st Trip w/ new Airstream a success classic67 On The Road... 2 08-12-2006 11:08 AM
Just bought my first Airstream joyegail Member Introductions 6 05-29-2006 10:06 AM
Got my 1st Airstream hookedonclassic Our Community 12 09-25-2005 06:22 PM
1st Airstream Dealership to open in Kentucky nds Commercial Listings 0 01-06-2004 11:28 AM
